    Jellyfin Forum Support Troubleshooting 6 ch audio not playing in web client
    6ch dolby digital acc audio is not playing in chrome,firefox etc
    BobHasNoSoul
    2023-11-06, 06:41 PM
    hey i appear to have found an issue and want to see what you all think.
    i have a movie with the following info
    direct streaming
    html video player
    http
    stream type hls
    direct streaming info:
    video: H264 (Direct)
    Audio: AAC
    container webm
    audio channels 6
    audio sample rate 48000hz
    i have tried setting the max number of streams and it wont do anything other than the movie playing without any sound at all.
    any help would be appreciated
    2023-11-06, 07:24 PM
    AAC ≠ AC-3 (DD), so I'm wondering if you could provide the full mediainfo from either Jellyfin or terminal. Additionally, when you select the max number of channels, does that trigger transcoding? If so, you should find an ffmpeg log in Dashboard > Logs that can be posted to sourcebin or pastebin that we can look at. Including your Jellyfin log would be a good idea too. Server version, host OS, type of install might be relevant as well.
    BobHasNoSoul
    2023-11-06, 09:04 PM (This post was last modified: 2023-11-06, 09:08 PM by BobHasNoSoul. Edited 1 time in total.)
    cheers for the fast response
    here is a part of jellyfins log, this is a bit too long to post here i can host the full thing for you if you think that will be useful
    [2023-11-06 20:49:10.752 +00:00] [INF] [183] Jellyfin.Api.Helpers.TranscodingJobHelper: "/usr/lib/jellyfin-ffmpeg/ffmpeg" "-analyzeduration 200M -fflags +genpts -f matroska,webm -i file:\"/mnt/mergerfs/Movies/PAW Patrol The Mighty Movie (2023)/PAW Patrol The Mighty Movie (2023).mkv\" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -bsf:v h264_mp4toannexb -start_at_zero -codec:a:0 libfdk_aac -ac 2 -ab 384000 -af \"volume=2\" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 6 -hls_segment_type mpegts -start_number 0 -hls_segment_filename \"/mnt/476GB/d7614778af7ecff809efb171d0af22b9%d.ts\" -hls_playlist_type vod -hls_list_size 0 -y \"/mnt/476GB/d7614778af7ecff809efb171d0af22b9.m3u8\""
    [2023-11-06 20:49:11.174 +00:00] [ERR] [183] Trakt.ServerMediator: Event details incomplete. Cannot process current media
    [2023-11-06 20:49:11.416 +00:00] [INF] [183] Jellyfin.Plugin.PlaybackReporting.EventMonitorEntryPoint: Processing playback tracker : "TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6MTA5LjApIEdlY2tvLzIwMTAwMTAxIEZpcmVmb3gvMTE4LjB8MTY5Nzg3NDk3MjI0Mg11-60ab2dea80724f33a0ba89f9d378f507-c9f618e03c3d15e534ba1861bd1f9eff"
    [2023-11-06 20:49:11.567 +00:00] [INF] [154] Jellyfin.Api.Helpers.TranscodingJobHelper: Stopping ffmpeg process with q command for "/mnt/476GB/d7614778af7ecff809efb171d0af22b9.m3u8"
    [2023-11-06 20:49:11.640 +00:00] [INF] [154] Jellyfin.Api.Helpers.TranscodingJobHelper: FFmpeg exited with code 0
    [2023-11-06 20:49:11.655 +00:00] [INF] [154] Jellyfin.Api.Controllers.DynamicHlsController: Current HLS implementation doesn't support non-keyframe breaks but one is requested, ignoring that request
    [2023-11-06 20:49:11.656 +00:00] [INF] [154] Jellyfin.Api.Helpers.TranscodingJobHelper: "/usr/lib/jellyfin-ffmpeg/ffmpeg" "-analyzeduration 200M -ss 00:07:12.000 -fflags +genpts -f matroska,webm -i file:\"/mnt/mergerfs/Movies/PAW Patrol The Mighty Movie (2023)/PAW Patrol The Mighty Movie (2023).mkv\" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -bsf:v h264_mp4toannexb -start_at_zero -codec:a:0 libfdk_aac -ac 2 -ab 384000 -af \"volume=2\" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 6 -hls_segment_type mpegts -start_number 72 -hls_segment_filename \"/mnt/476GB/d7614778af7ecff809efb171d0af22b9%d.ts\" -hls_playlist_type vod -hls_list_size 0 -y \"/mnt/476GB/d7614778af7ecff809efb171d0af22b9.m3u8\""
    [2023-11-06 20:49:11.697 +00:00] [INF] [188] Jellyfin.Plugin.PlaybackReporting.EventMonitorEntryPoint: Adding playback tracker : TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6MTA5LjApIEdlY2tvLzIwMTAwMTAxIEZpcmVmb3gvMTE5LjB8MTY5ODUzMzE4NzY3MA11-f2de28eebf634709bcf205142187c544-8fca3ebdef46d261ad4a18a29d4cc5f3
    [2023-11-06 20:49:11.697 +00:00] [INF] [188] Jellyfin.Plugin.PlaybackReporting.Data.PlaybackTracker: PlaybackTracker : Adding Start Event : 11/06/2023 20:49:11
    [2023-11-06 20:49:11.697 +00:00] [INF] [188] Jellyfin.Plugin.PlaybackReporting.EventMonitorEntryPoint: Creating StartPlaybackTimer Task
    [2023-11-06 20:49:11.697 +00:00] [INF] [156] Jellyfin.Plugin.PlaybackReporting.EventMonitorEntryPoint: StartPlaybackTimer : Entered
    [2023-11-06 20:49:12.174 +00:00] [ERR] [187] Trakt.ServerMediator: Event details incomplete. Cannot process current media
    [2023-11-06 20:49:12.809 +00:00] [INF] [183] Jellyfin.Plugin.PlaybackReporting.EventMonitorEntryPoint: Processing playback tracker : "TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6MTA5LjApIEdlY2tvLzIwMTAwMTAxIEZpcmVmb3gvMTE5LjB8MTY5ODUzMzE4NzY3MA11-f2de28eebf634709bcf205142187c544-8fca3ebdef46d261ad4a18a29d4cc5f3"
    and here is the log for ffmpeg
    /videos/8fca3ebd-ef46-d261-ad4a-18a29d4cc5f3/hls1/main/0.ts
    {"Protocol":0,"Id":"8fca3ebdef46d261ad4a18a29d4cc5f3","Path":"/mnt/mergerfs/Movies/PAW Patrol The Mighty Movie (2023)/PAW Patrol The Mighty Movie (2023).mkv","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"mkv,webm","Size":4963024384,"Name":"PAW Patrol The Mighty Movie (2023)","IsRemote":false,"ETag":"3f4584bce9043462f88f47483afe7ec4","RunTimeTicks":52771311616,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":false,"LiveStreamId":null,"BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":0,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":"h264","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":"bt709","ColorTransfer":"bt709","ColorPrimaries":"bt709","DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":"SDR","VideoRangeType":"SDR","VideoDoViTitle":null,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"DisplayTitle":"1080p H264 SDR","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"ChannelLayout":null,"BitRate":7523822,"BitDepth":8,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":true,"IsForced":false,"Height":800,"Width":1920,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"Profile":"High","Type":1,"AspectRatio":"2.40:1","Index":0,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":null},{"Codec":"eac3","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":null,"VideoRangeType":null,"VideoDoViTitle":null,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"DisplayTitle":"Eng - Dolby Digital\u002B - 6 ch - Default","NalLengthSize":null,"IsInterlaced":false,"IsAVC":null,"ChannelLayout":null,"BitRate":640000,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":0,"AspectRatio":null,"Index":1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"subrip","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":null,"VideoRangeType":null,"VideoDoViTitle":null,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","DisplayTitle":"Eng - SUBRIP","NalLengthSize":null,"IsInterlaced":false,"IsAVC":null,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":2,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"subrip","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"SDH","VideoRange":null,"VideoRangeType":null,"VideoDoViTitle":null,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","DisplayTitle":"SDH - Eng - SUBRIP","NalLengthSize":null,"IsInterlaced":false,"IsAVC":null,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":3,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"subrip","CodecTag":null,"Language":"fre","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":null,"VideoRangeType":null,"VideoDoViTitle":null,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","DisplayTitle":"Fre - SUBRIP","NalLengthSize":null,"IsInterlaced":false,"IsAVC":null,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":4,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null}],"MediaAttachments":[],"Formats":[],"Bitrate":8163822,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":null,"TranscodingContainer":null,"AnalyzeDurationMs":null,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null}
    /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -fflags +genpts -f matroska,webm -i file:"/mnt/mergerfs/Movies/PAW Patrol The Mighty Movie (2023)/PAW Patrol The Mighty Movie (2023).mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -bsf:v h264_mp4toannexb -start_at_zero -codec:a:0 libfdk_aac -ac 2 -ab 384000 -af "volume=2" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 6 -hls_segment_type mpegts -start_number 0 -hls_segment_filename "/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e7%d.ts" -hls_playlist_type vod -hls_list_size 0 -y "/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e7.m3u8"
    ffmpeg version 5.1.3-Jellyfin Copyright © 2000-2022 the FFmpeg developers
    built with gcc 10 (Debian 10.2.1-6)
    configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-libs=-lfftw3f --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-libdrm --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=amd64 --enable-libsvtav1 --enable-libshaderc --enable-libplacebo --enable-vulkan --enable-opencl --enable-vaapi --enable-amf --enable-libmfx --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc
    libavutil 57. 28.100 / 57. 28.100
    libavcodec 59. 37.100 / 59. 37.100
    libavformat 59. 27.100 / 59. 27.100
    libavdevice 59. 7.100 / 59. 7.100
    libavfilter 8. 44.100 / 8. 44.100
    libswscale 6. 7.100 / 6. 7.100
    libswresample 4. 7.100 / 4. 7.100
    libpostproc 56. 6.100 / 56. 6.100
    [matroska,webm @ 0x55d2400d8640] 0x00 at pos 4963023021 (0x127d1b8ad) invalid as first byte of an EBML number
    Guessed Channel Layout for Input Stream #0.1 : 5.1
    Input #0, matroska,webm, from 'fileConfused-facemnt/mergerfs/Movies/PAW Patrol The Mighty Movie (2023)/PAW Patrol The Mighty Movie (2023).mkv':
    Metadata:
    encoder : libebml v1.4.4 + libmatroska v1.7.1
    Duration: 01:27:57.13, start: 0.000000, bitrate: 7523 kb/s
    Chapters:
    Chapter #0:0: start 0.000000, end 484.234000
    Metadata:
    title : Chapter 01
    Chapter #0:1: start 484.234000, end 938.188000
    Metadata:
    title : Chapter 02
    Chapter #0:2: start 938.188000, end 1405.196000
    Metadata:
    title : Chapter 03
    Chapter #0:3: start 1405.196000, end 1885.218000
    Metadata:
    title : Chapter 04
    Chapter #0:4: start 1885.218000, end 2292.125000
    Metadata:
    title : Chapter 05
    Chapter #0:5: start 2292.125000, end 2836.878000
    Metadata:
    title : Chapter 06
    Chapter #0:6: start 2836.878000, end 3320.904000
    Metadata:
    title : Chapter 07
    Chapter #0:7: start 3320.904000, end 3853.645000
    Metadata:
    title : Chapter 08
    Chapter #0:8: start 3853.645000, end 4327.619000
    Metadata:
    title : Chapter 09
    Chapter #0:9: start 4327.619000, end 4737.696000
    Metadata:
    title : Chapter 10
    Chapter #0:10: start 4737.696000, end 5277.131000
    Metadata:
    title : Chapter 11
    Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x800 [SAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn (default) (original)
    Stream #0:1(eng): Audio: eac3, 48000 Hz, 5.1, fltp (default) (original)
    Stream #0:2(eng): Subtitle: subrip (original)
    Stream #0:3(eng): Subtitle: subrip (original) (hearing impaired)
    Metadata:
    title : SDH
    Stream #0:4(fre): Subtitle: subrip (dub)
    Stream mapping:
    Stream #0:0 -> #0:0 (copy)
    Stream #0:1 -> #0:1 (eac3 (native) -> aac (libfdk_aac))
    Output #0, hls, to '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e7.m3u8':
    Metadata:
    encoder : Lavf59.27.100
    Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x800 [SAR 1:1 DAR 12:5], q=2-31, 23.98 fps, 23.98 tbr, 90k tbn (default) (original)
    Stream #0:1: Audio: aac, 48000 Hz, stereo, s16, 384 kb/s (default) (original)
    Metadata:
    encoder : Lavc59.37.100 libfdk_aac
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e70.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e71.ts' for writing
    frame= 353 fps=0.0 q=-1.0 size=N/A time=00:00:00.07 bitrate=N/A speed=2.23x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e72.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e73.ts' for writing
    frame= 645 fps=0.0 q=-1.0 size=N/A time=00:00:12.36 bitrate=N/A speed= 23x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e74.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e75.ts' for writing
    frame= 961 fps=926 q=-1.0 size=N/A time=00:00:25.61 bitrate=N/A speed=24.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e76.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e77.ts' for writing
    frame= 1290 fps=839 q=-1.0 size=N/A time=00:00:39.37 bitrate=N/A speed=25.6x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e78.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e79.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e710.ts' for writing
    frame= 1634 fps=802 q=-1.0 size=N/A time=00:00:53.64 bitrate=N/A speed=26.3x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e711.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e712.ts' for writing
    frame= 1950 fps=768 q=-1.0 size=N/A time=00:01:06.68 bitrate=N/A speed=26.3x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e713.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e714.ts' for writing
    frame= 2238 fps=737 q=-1.0 size=N/A time=00:01:18.84 bitrate=N/A speed= 26x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e715.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e716.ts' for writing
    frame= 2550 fps=721 q=-1.0 size=N/A time=00:01:31.77 bitrate=N/A speed=25.9x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e717.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e718.ts' for writing
    frame= 2833 fps=701 q=-1.0 size=N/A time=00:01:43.54 bitrate=N/A speed=25.6x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e719.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e720.ts' for writing
    frame= 3145 fps=693 q=-1.0 size=N/A time=00:01:56.60 bitrate=N/A speed=25.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e721.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e722.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e723.ts' for writing
    frame= 3475 fps=689 q=-1.0 size=N/A time=00:02:10.51 bitrate=N/A speed=25.9x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e724.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e725.ts' for writing
    frame= 3821 fps=688 q=-1.0 size=N/A time=00:02:24.78 bitrate=N/A speed=26.1x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e726.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e727.ts' for writing
    frame= 4115 fps=680 q=-1.0 size=N/A time=00:02:37.30 bitrate=N/A speed= 26x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e728.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e729.ts' for writing
    frame= 4402 fps=672 q=-1.0 size=N/A time=00:02:49.03 bitrate=N/A speed=25.8x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e730.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e731.ts' for writing
    frame= 4694 fps=665 q=-1.0 size=N/A time=00:03:01.30 bitrate=N/A speed=25.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e732.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e733.ts' for writing
    frame= 5004 fps=662 q=-1.0 size=N/A time=00:03:14.25 bitrate=N/A speed=25.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e734.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e735.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e736.ts' for writing
    frame= 5329 fps=661 q=-1.0 size=N/A time=00:03:27.61 bitrate=N/A speed=25.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e737.ts' for writing
    frame= 5591 fps=652 q=-1.0 size=N/A time=00:03:38.57 bitrate=N/A speed=25.5x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e738.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e739.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e740.ts' for writing
    frame= 5905 fps=651 q=-1.0 size=N/A time=00:03:51.82 bitrate=N/A speed=25.6x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e741.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e742.ts' for writing
    frame= 6252 fps=653 q=-1.0 size=N/A time=00:04:06.28 bitrate=N/A speed=25.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e743.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e744.ts' for writing
    frame= 6539 fps=649 q=-1.0 size=N/A time=00:04:18.38 bitrate=N/A speed=25.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e745.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e746.ts' for writing
    frame= 6858 fps=649 q=-1.0 size=N/A time=00:04:31.63 bitrate=N/A speed=25.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e747.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e748.ts' for writing
    frame= 7181 fps=649 q=-1.0 size=N/A time=00:04:44.87 bitrate=N/A speed=25.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e749.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e750.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e751.ts' for writing
    frame= 7499 fps=648 q=-1.0 size=N/A time=00:04:58.25 bitrate=N/A speed=25.8x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e752.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e753.ts' for writing
    frame= 7815 fps=647 q=-1.0 size=N/A time=00:05:11.31 bitrate=N/A speed=25.8x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e754.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e755.ts' for writing
    frame= 8101 fps=644 q=-1.0 size=N/A time=00:05:23.32 bitrate=N/A speed=25.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e756.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e757.ts' for writing
    frame= 8412 fps=643 q=-1.0 size=N/A time=00:05:36.27 bitrate=N/A speed=25.7x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e758.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e759.ts' for writing
    frame= 8777 fps=646 q=-1.0 size=N/A time=00:05:51.56 bitrate=N/A speed=25.9x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e760.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e761.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e762.ts' for writing
    frame= 9139 fps=649 q=-1.0 size=N/A time=00:06:06.60 bitrate=N/A speed= 26x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e763.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e764.ts' for writing
    frame= 9503 fps=651 q=-1.0 size=N/A time=00:06:21.75 bitrate=N/A speed=26.2x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e765.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e766.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e767.ts' for writing
    frame= 9812 fps=650 q=-1.0 size=N/A time=00:06:34.68 bitrate=N/A speed=26.2x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e768.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e769.ts' for writing
    frame=10159 fps=652 q=-1.0 size=N/A time=00:06:49.16 bitrate=N/A speed=26.2x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e770.ts' for writing
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e771.ts' for writing
    frame=10452 fps=650 q=-1.0 size=N/A time=00:07:01.43 bitrate=N/A speed=26.2x
    [hls @ 0x55d2401008c0] Opening '/mnt/476GB/5a9136ced20f6074bb4ab15fb84518e772.ts' for writing
    the strangest thing is there are multiple other clients it works fine on, the mobile app for example including chrome on android
    here is the media info
    FFProbe:
    ffprobe version 4.4.2-0ubuntu0.22.04.1 Copyright © 2007-2021 the FFmpeg develo pers
    built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
    configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hard ened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu - -arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --e nable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcac a --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enab le-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enab le-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libop enjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbit mq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-li btwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-li bzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-li bmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprin t --enable-frei0r --enable-libx264 --enable-shared
    libavutil 56. 70.100 / 56. 70.100
    libavcodec 58.134.100 / 58.134.100
    libavformat 58. 76.100 / 58. 76.100
    libavdevice 58. 13.100 / 58. 13.100
    libavfilter 7.110.100 / 7.110.100
    libswscale 5. 9.100 / 5. 9.100
    libswresample 3. 9.100 / 3. 9.100
    libpostproc 55. 9.100 / 55. 9.100
    [matroska,webm @ 0x558de36a6e80] 0x00 at pos 4963023021 (0x127d1b8ad) invalid as first byte of an EBML number
    Input #0, matroska,webm, from 'PAW Patrol The Mighty Movie (2023).mkv':
    Metadata:
    Chapters:
    Metadata:
    title : Chapter 01
    Metadata:
    title : Chapter 02
    Metadata:
    title : Chapter 03
    Metadata:
    title : Chapter 04
    Metadata:
    title : Chapter 05
    Metadata:
    title : Chapter 06
    Metadata:
    title : Chapter 07
    Metadata:
    title : Chapter 08
    Metadata:
    title : Chapter 09
    Metadata:
    title : Chapter 10
    Metadata:
    title : Chapter 11
    Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x80 0 [SAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) (origina l)
    Stream #0:1(eng): Audio: eac3, 48000 Hz, 6 channels, fltp (default) (original)
    Metadata:
    title : SDH
    jellyfin media info:
    Audio
    Title: Eng - Dolby Digital+ - 6 ch - Default
    Language: eng
    Codec: EAC3
    Channels: 6 ch
    Bitrate: 640 kbps
    Sample rate: 48000 Hz
    Default: Yes
    Forced: No
    External: No
    Video
    Title: 1080p H264 SDR
    Codec: H264
    AVC: Yes
    Profile: High
    Level: 40
    Resolution: 1920x800
    Aspect ratio: 2.40:1
    Interlaced: No
    Framerate: 23.976025
    Bitrate: 7523 kbps
    Bit depth: 8 bit
    Video range: SDR
    Video range type: SDR
    Colour space: bt709
    Colour transfer: bt709
    Colour primaries: bt709
    Pixel format: yuv420p
    Ref frames: 1
    NAL: 4
    Subtitle
    Title: Eng - SUBRIP
    Language: eng
    Codec: SUBRIP
    Default: No
    Forced: No
    External: No
    Server Details:
    ubuntu 22.04 host running jellyfin 10.8.10 via docker jellyfin/jellyfin image
    2023-11-06, 09:18 PM
    Does the web client support more than stereo? Regardless, EAC3 is definitely not supported by any browser, AFAIK.
    And it is definitely being transcoded to stereo.
    For the record, AAC can be more than two channels. But jellyfin does not transcode audio to anything other than stereo.
    BobHasNoSoul
    2023-11-06, 09:31 PM
    im not entirely sure if it does or doesnt, i usually get stereo media but this file is 6ch so wasnt entirely sure what the issue was when i tried to play it and the lack of audio but it is really weird that the mobile web browsers do not face this issue.. almost like something inside windows browsers has a issue with it. (love the username btw)
    2023-11-06, 11:30 PM
    Install Jellyfin Media Player. I know it supports almost all audio formats. Almost certain browsers only do stereo.
