    Jellyfin Forum Support Troubleshooting Android TV Audio stutters on a specific track
    Buccaneer0809
    Country:France
    2024-01-20, 09:22 AM
    Hi,
    I have a really odd problem with sound, some kind of stuttering but only with english.
    My server setup : latest jellyfin within LXC container, everything works perfectly fine with hardware decoding.
    I play mkv file, with h264 1080p encoded video stream, and two AC3 audio tracks encoded the same way (english and french).
    Really nothing unusal or something my server can't handle : he never crosses 15% server load, nor 7% memory consumption.
    Audio #1
    Format                                  : AC-3
    Format/Info                              : Audio Coding 3
    Commercial name                          : Dolby Digital
    Codec ID                                : A_AC3
    Duration                                : 47 min 16 s
    Bit rate mode                            : Constant
    Bit rate                                : 448 kb/s
    Channel(s)                              : 6 channels
    Channel layout                          : L R C LFE Ls Rs
    Sampling rate                            : 48.0 kHz
    Frame rate                              : 31.250 FPS (1536 SPF)
    Compression mode                        : Lossy
    Delay relative to video                  : -5 ms
    Stream size                              : 152 MiB (12%)
    Title                                    : VFF AC3 5.1
    Language                                : French
    Service kind                            : Complete Main
    Default                                  : No
    Forced                                  : No
    I copied only one of them because mediainfo gives the same for #audio 2, besides Language and Title.
    I play them on my Android Philips smart TV with the official Jellyfin app with no subtitles.
    What I tried so far :
    - it plays fine on pc browser and phone app.
    - switched cifs to nfs storage to try to lower latency
    - fiddled with JF app settings : libVLC player, latency etc
    - here and there tried to lower some non-pertinent server quality settings, switching VAAPI to QSV etc
    Logs gives nothing relevant, neither on server nor from tv logcat
    Should I try to buy an english speaking television XD ?
    2024-01-20, 06:14 PM
    Are you using libVLC exclusively?
    Buccaneer0809
    Country:France
    2024-01-21, 08:44 AM
    I tried with both
    2024-01-21, 05:54 PM
    In Jellyfin on your Android TV, can you check the Playback settings and fiddle around with the audio settings?
    Do you have either of the bit stream settings enabled?  Disabled?  Downmixing?
