    Jellyfin Forum Support General Questions Audio Track and Subtitles Names Translation
    LhuanDula
    2024-12-07, 09:39 AM
    (2024-12-06, 04:56 PM)TheDreadPirate Wrote: Run "ffprobe" on the SRT file.
    Here is the result of the ffprobe run on the srt file: https://pastebin.com/0inMhrJc
    Similarly if i run ffprobe on a movie with french audio and french embeded subtitles i get the following: https://pastebin.com/K0Y2u2p0
    For the movie it does looks like the iso code used for french is "fre" and not "fra". Is there a work around to make fre works in Jellyfin?
    #12
    2024-12-07, 04:30 PM (This post was last modified: 2024-12-07, 04:31 PM by bitmap.)
    ffmpeg -i "[input_file]" -c copy -metadata:s:s:0 title="Français" -metadata:s:s:0 language="fra" "[output_file]"
    There doesn't appear to be any metadata. You can set this for audio tracks as well, either with mkvmerge or ffmpeg:
    ffmpeg -i "[input_file]" -c copy -metadata:s:a:[track_index] title="Français" -metadata:s:a:[track_index] language="fra" "[output_file]"
    Track indices start at 0, so if French is the first audio track, the track_index would be 0. If it's the second, track_index is 1.
