    Jellyfin Forum Support General Questions Best method to fix cropped images in Jellyfin
    images i use for jellyfin sometimes are cropped. Fix?
    4kLvr80
    Threads: 8
    2023-08-12, 02:52 AM
    i was told the dimensions Jellyfin uses for images are
    vertical posters: 435x640
    horizontal 435x245
    i know that to keep the image for a library from changing you name the image poster then the picture file extension and put it in that library's folder. i tried resizing in gimp but it still didnt stop it from cropping. im attaching some images that are coming out cropped for me. hope to learn a solution from you guys. this has been driving me crazy lol
    4kLvr80
    Threads: 8
    2023-08-27, 01:19 PM
    ok can someone tell me what the accepted size for images in folders are for jellyfin? it would extremely appreciated if someone can help
    2023-08-29, 12:45 AM
    Best source I can find at the moment is this issue comment, will keep hunting momentarily: https://github.com/jellyfin/jellyfin-met...-759373678
    Jellyfin 10.11.10 Official Docker | Ubuntu 24.04 LTS | i7-13700K | Arc A380 6 GB | 64 GB RAM | 79 TB Storage
    [Image: AP1GczPBda58ILsKKDCRtSyY9IlUsAPsBNpv5sNY...-h100-s-no]
    2023-08-29, 01:43 AM
    Update: that's all I could find. That link has a fanart link in it too.
    4kLvr80
    Threads: 8
    2023-08-29, 09:59 AM
    thank you bitmap for taking the time to provide this info. this should be handy. speaking of kodi do you have a recommended video or guide for newbs at KODI? ii downloaded it on my android shield. it looks intimidating but im willing to learn. i think i heard something that youtube was or is against videos teaching how to use it? something like that was said in a video i saw. anyway thank you and if you can help with my kodi inquiry id appreciate it cause i bring it up cause from that link it looks like KODI is easier to use for using artwork for one's media on jellyfin.
    2023-08-29, 02:40 PM
    It has been probably a decade or more since I used Kodi (XBMC, maybe even a different iteration at the time) so I'm not sure I can be much help there. I know there are several folks who use the plugins here in the forum though. You might make a different topic if you have Jellyfin-centered questions. For general knowledge-building however, I'd have to point you towards their quick start guide: https://kodi.wiki/view/Quick_start_guide.
