    Jellyfin Forum Support General Questions Best operating system and processor for JellyFin?
    Pages (3): 1 2 3 Next »
    javifeer
    2023-10-11, 05:54 PM
    Hello everyone! a pleasure to be here, first of all I would like to thank the whole jellyfin team for making this possible.
    What kind of Linux distribution do you recommend for jellyfin?
    and microprocessor, intel or amd?
    Thanks in advance!
    Deleted User
    Unregistered
    2023-10-11, 06:05 PM
    take a look at https://jellyfin.org/docs/general/admini...-selection
    jellyfin runs on just about everything as far as OS so choose one you are comfortable with and that supports your requirements
    2023-10-11, 07:05 PM
    TLDR
    OS - Ubuntu (lots of documentation so easy to install and troubleshoot)
    CPU - 8th gen+ Intel CPU. The transcoding quality of QSV is straight up better then Nvidia or AMD. Especially AMD.
    maxigs
    2023-10-11, 08:46 PM (This post was last modified: 2023-10-11, 08:46 PM by maxigs. Edited 1 time in total.)
    Are there any details on this quality difference? I have seen it described in the guide as well .. right after i installed jellyfin on a newly bought mini-pc with ryzen cpu/igpu. Since i'm still within the return period, i'm wondering if it's actually worth switching.
    Currently it's a Ryzen 7 7735HS, with Radeon 680M / RDNA2.
    Would probably switch to one with 12th gen intel, maybe even i5-13500H
    Thx
    2023-10-11, 11:15 PM
    I'm with TDP.
    OS --> Ubuntu 22+ w/ Kernel to match up with your hardware/software preference (HWE kernel or bump up to 23+ if you're adventurous).
    CPU --> Intel though I'd say if you can wait and/or spend the dough, you can get encode/decode AV1 support with Meteor Lake unless you plan on getting something like an Arc A3X0.
    You can also get a really low-power processor that can knock the socks off most competitors as far as transcoding performance goes (if that's a concern). I think it's 11th gen and higher that support LPE modes, but it gets simpler with 12th gen (no fumbling with extra firmware configuration).
    Jellyfin 10.11.10 Official Docker | Ubuntu 24.04 LTS | i7-13700K | Arc A380 6 GB | 64 GB RAM | 79 TB Storage
    [Image: AP1GczPBda58ILsKKDCRtSyY9IlUsAPsBNpv5sNY...-h100-s-no]
    javifeer
    2023-10-12, 08:42 AM
    Thank you very much for your answers! I will take Intel then, what company do you recommend to set it all up on a VPS / Dedicated Server?
    Thanks once again!
    2023-10-12, 12:39 PM (This post was last modified: 2023-10-12, 12:40 PM by TheDreadPirate.)
    If you're going with a VPS, Intel server processors DO NOT have an iGPU for transcoding.
    Deleted User
    Unregistered
    2023-10-12, 02:02 PM
    it probably would have been best to lead with that, it would have changed the answers received
    "Best operating system and processor for JellyFin (on a VPS or Dedi)?"
    2023-10-12, 02:52 PM (This post was last modified: 2023-10-12, 02:52 PM by TheDreadPirate.)
    If you are going with a VPS, your media needs to be encoded for maximum compatibility. Transcoding is pretty much not an options with a VPS with no GPU. H264 main profile, 8-bit color depth for the video. Stereo AAC for the audio.
    Deleted User
    Unregistered
    2023-10-12, 02:55 PM
    @TheDreadPirate
    any experience with Cloud GPU? https://www.vultr.com/products/cloud-gpu
