    Jellyfin Forum Support Troubleshooting Buffering with Ethernet cable
    Yorai1212
    2024-08-29, 09:27 AM
    Hey. I had a lot of buffering in Jellyfin (Direct Play) with large files (4K at around 50GB+) on my TV. Which is reasonable I understand. Since I didn't have an Ethernet cable connected from my PC to my TV.
    My setup is Windows 10, Jellyfin installed on my system drive (SSD) and my movies/shows on HDD.
    I've recently bought a network switch so that I can have my PC connected to the switch and also my TV connected to the switch.
    It basically fixed almost all of the buffering, especially the seeking (10 seconds back / forward is now pretty quick). But it still buffers at times, randomly / not randomly (every other minute). Especially with these big files, 40-50GB+ stuff. Almost never with stuff below 40-50GB
    I don't know what to do anymore really.. any help would be appreciated!  Upside-down-face
    Jellyfin version 10.9.9. But I just updated to 10.9.10 though, haven't tested the new version yet, however.
    My gear is;
    CPU: AMD Ryzen 7 5800X 8-Core Processor
    RAM: DDR4 32GB
    Motherboard: B550M DS3H
    GPU: AMD Radeon RX 6800 XT
    2024-08-29, 03:31 PM
    Since it is direct playing, the issue is likely client side. What client are you using to play content on your TV?
    Yorai1212
    2024-08-29, 04:38 PM
    (2024-08-29, 03:31 PM)TheDreadPirate Wrote: Since it is direct playing, the issue is likely client side.  What client are you using to play content on your TV?
    Sorry, I don't get your question.
    [Image: obrXkdq.png]
    This is for the server (AMD64).
    On my TV (Sony A90k OLED 42), it's the normal app from the Google play store, it's a Google TV operating system.
    2024-08-29, 06:05 PM
    Manufacturers cut costs on Ethernet ports in TVs by limiting them to a 100 Mbps connection, even in high-end models. You might actually get a faster connection through Wi-Fi. I recommend buying a USB 3.0 to Gigabit Ethernet adapter.
    Yorai1212
    2024-08-30, 11:01 AM
    (2024-08-29, 06:05 PM)theguymadmax Wrote: Manufacturers cut costs on Ethernet ports in TVs by limiting them to a 100 Mbps connection, even in high-end models. You might actually get a faster connection through Wi-Fi. I recommend buying a USB 3.0 to Gigabit Ethernet adapter.
    Not something I need. The last movie I watched (which was buffering) was in around 68.1mb/s.
    Yorai1212
    2024-09-03, 10:00 AM
    Anyone knows?
    Yorai1212
    2024-10-24, 06:10 PM (This post was last modified: 2024-10-24, 06:10 PM by Yorai1212. Edited 1 time in total.)
    Okay so I got an adapter (Cable Matters' one), seems to work perfectly. You were right.
    I didn't even think about peak bitrate. Only thought about average bitrate.
