    Jellyfin Forum Support General Questions Can Someone Help Me Figure Out How to Reduce Jellyfin's Memory Usage to the Same Leve
    • 1 Vote(s) - 5 Average
    Can Someone Help Me Figure Out How to Reduce Jellyfin's Memory Usage to the Same Level as Emby?
    #11
    2024-06-12, 03:11 PM (This post was last modified: 2024-06-12, 04:29 PM by Efficient_Good_5784. Edited 1 time in total.)
    I'll share what size it is on mine when I get access to it later today.
    Edit:
    I just checked the sizes of my DB files.
    They are as follows:
    • library.db = 56MB
    • library.db-wal = 106MB
    2024-06-12, 04:42 PM (This post was last modified: 2024-06-12, 04:44 PM by TheDreadPirate. Edited 1 time in total.)
    Docker stats for my test instances.
    CONTAINER ID   NAME                      CPU %     MEM USAGE / LIMIT     MEM %     NET I/O   BLOCK I/O         PIDS
    46849591f45b   jellyfin-stable-testing   0.01%     953.9MiB / 31.09GiB   3.00%     0B / 0B   1.63GB / 1.06GB   21
    e1db2e291ed3   jellyfin-unstable         0.01%     640.9MiB / 31.09GiB   2.01%     0B / 0B   3.59GB / 3.41GB   17
    My stable testing instance has the same library as my production instance, memory stats for my production instance below (package install in Ubuntu).
    chris@rat-trap:~$ ps -p 3816 -o %cpu,%mem,cmd
    %CPU %MEM CMD
    0.4  2.5 /usr/bin/jellyfin
    2.5% of 32GB is ~820MB.
    My library.db size for 250 movies, 4400 episodes, 4200 songs, 64 audiobooks, and 500 music videos is 107MB.
    chris@rat-trap:~$ ll -h /var/lib/jellyfin/data/library.db
    -rw-r--r-- 1 jellyfin jellyfin 107M Jun 12 10:12 /var/lib/jellyfin/data/library.db
    And the metadata directory is 14GB.
    chris@rat-trap:~$ du -sh /var/lib/jellyfin/metadata/
    14G     /var/lib/jellyfin/metadata/
    21tc_sea
    Country:China
    #13
    2024-06-15, 09:50 AM (This post was last modified: 2024-06-15, 09:51 AM by 21tc_sea. Edited 1 time in total.)
    (2024-06-12, 04:42 PM)TheDreadPirate Wrote: Docker stats for my test instances.
    %CPU %MEM CMD
    So this is where the problem lies! My library.db is 3.5GB, and my Jellyfin container, without any memory limit, is now occupying 15GB. If your library.db is as large as mine, I guess you would also encounter the same awkward situation as me, having to wait a long time for it to finish starting up!
    ThomasPGH
    2024-06-15, 11:04 AM
    (2024-06-12, 02:17 PM)21tc_sea Wrote: Could you please check the size of the library.db file in your config/data directory? If you mentioned that your Jellyfin memory usage is only around 900MB, I guess your library.db is probably only a few hundred MBs.
    Under Scheduled Tasks there's a task called Optimise database. When has this run last time?
    21tc_sea
    Country:China
    #15
    2024-06-17, 01:47 AM
    13 hours ago, in fact, the database optimization feature you mentioned runs once a day on my device. However, it doesn’t seem to help much. The database is indeed that large, I estimate it contains no less than 40,000 movies…
