    Pages (12): « Previous 1 … 8 9 10 11 12
    • 2 Vote(s) - 5 Average
    Threads: 12
    2026-02-12, 04:13 PM
    (2025-11-10, 05:30 PM)Ghostyjack Wrote:
    (2025-11-09, 06:06 AM)Ravn73 Wrote:
    (2025-11-05, 05:31 PM)Ghostyjack Wrote: I seem to be having the issue mentioned so it looks like this will resolve my problem on my LG TV. Unfortunately I've not sure I understand where I am supposed to use this command.
    What am I supposed to do with it?
    Which command do you mean? From the first post?
    Yes, the command in the first post.
    I am not aware of anywhere within Jellyfin to enter these, so assume this is in a console/terminal of some form.
    I'm just learning about this sort of thing, so I'm unsure where this goes.
    Currently I'm got two Jellyfin servers; My Synology DN-1522+ where I run as a container and a NUC Phantom Canyon with Windows 11* on (trialling it for the transcode capability).
    * Windows is proving problematic as the server keeps disconnecting so may change it to either Linux or Proxmox.
    You would run the command in the Windows command prompt in your case.  The ffmpeg options are the same in Windows, but you'd need to specify the full jellyfin-ffmpeg path instead of just "ffmpeg".
    Jellyfin 12.4 (Docker)
    TheJellyMan
    2026-09-10, 05:52 AM
    What can I do if I have a Dolby Vision profile 10 file that's already AV1?
    Threads: 12
    2026-09-10, 03:38 PM (This post was last modified: 2026-09-10, 03:41 PM by TheDreadPirate. Edited 1 time in total.)
    (2026-09-10, 05:52 AM)TheJellyMan Wrote: What can I do if I have a Dolby Vision profile 10 file that's already AV1?
    For the record, Dolby Vision Profile 10 is their profile specifically for AV1. However, if you did want to remove it WITHOUT re-encoding, you can add the following to your ffmpeg command.
    -bsf:v av1_metadata=remove_dovi=1
    The full command would look something like this.
    /usr/lib/jellyfin-ffmpeg/ffmpeg -fflags +genpts+igndts -i DVprofile10.mkv -map 0 -bsf:v av1_metadata=remove_dovi=1 -codec copy plainHDR10AV1.mkv
