    Jellyfin Forum Support General Questions difference between nginx and ddns service
    Online
    2024-11-16, 01:55 AM
    Yes. You have to configure connections on 443 to get proxied to jellyfin port 8096. If your config resembles your earlier config, that hasn't been done.
    https://jellyfin.org/docs/general/networ...ig-example
    Drake97
    Threads: 31
    Country:Chile
    #12
    2024-11-16, 02:03 AM
    (2024-11-16, 01:55 AM)TheDreadPirate Wrote: Yes.  You have to configure connections on 443 to get proxied to jellyfin port 8096.  If your config resembles your earlier config, that hasn't been done.
    yep, this is my jellyfin file, I changed my ddns server to MY_DOMAIN so as not to expose it to other people
    https://pastebin.com/kZ4cgcDW
    Jellyfin 10.11.11
    Ubuntu Desktop 24.04.4 LTS
    Intel i3-12100
    16GB DDR4 2400MHz
    OS-DRIVE: WDC PC SN720 256GB
    Storage (JF Library): 40TB JBOD
    Online
    2024-11-16, 02:11 AM
    Is your computer's host name "jellyfin"? If not, change "set $jellyfin jellyfin;" to "set $jellyfin {insert LAN IP};"
    Drake97
    Threads: 31
    Country:Chile
    #14
    2024-11-16, 02:50 AM
    (2024-11-16, 02:11 AM)TheDreadPirate Wrote: Is your computer's host name "jellyfin"?  If not, change "set $jellyfin jellyfin;" to "set $jellyfin {insert LAN IP};"
    I did that and i dont know, i can't get results,
    I am going to think with time tomorrow because something is happening and I am not getting it even if I do everything to the letter and follow your indications, I feel that I am close to achieve it but sometimes things do not work out the first time what you want.
    I really appreciate your help
    Greetings.
    Jellyfin 10.11.11
    Intel i3-12100
    16GB DDR4 2400MHz
