    Jellyfin Forum Support Troubleshooting DoVi issues with Shield Pro 2019
    unbk
    2024-11-03, 03:23 AM
    Hi all,
    I have not been able to watch DV movies with my Shield Pro 2019 lately since my LG G3 is not being switched to DV/HDR mode.
    The player overlay (especially the seekbar) becomes semi-transparent and depending on the movie, the colors are either washed out, completely wrong or some sort of SDR fallback layer is played.
    However normal HDR10 files are played back correctly.
    The files whether in MKV or MP4 containers are played fine via the JF webOS app as at least normal HDR10.
    I have played an Avatar remux on the TV and the Shield as a quick sample.
    Media information from Jellyfin for the file:
    ffmpeg -i output:
    [matroska,webm @ 0x6410941b1900] Invalid Block Addition value 0x0 for unknown Block Addition Mapping type 68766345, name ""
    [matroska,webm @ 0x6410941b1900] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
    Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
    [matroska,webm @ 0x6410941b1900] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
    Input #0, matroska,webm, from 'Avatar (2009) [imdbid-tt0499549] - Extended [Remux-2160p][DV HDR10][AC3 5.1][HEVC].mkv':
      Metadata:
        title          : Avatar - Aufbruch nach Pandora (2009) - Extended [Remux-2160p][DV HDR10][AV3 5.1][HEVC]
        encoder        : libebml v1.4.4 + libmatroska v1.7.1
        creation_time  : 2023-12-22T18:55:45.000000Z
      Duration: 02:58:28.95, start: 0.000000, bitrate: 48339 kb/s
      Chapters:
        Chapter #0:0: start 0.000000, end 325.575000
          Metadata:
            title          : Kapitel 01
        Chapter #0:1: start 325.575000, end 612.278000
          Metadata:
            title          : Kapitel 02
        Chapter #0:2: start 612.278000, end 707.916000
          Metadata:
            title          : Kapitel 03
        Chapter #0:3: start 707.916000, end 959.208000
          Metadata:
            title          : Kapitel 04
        Chapter #0:4: start 959.208000, end 1074.782000
          Metadata:
            title          : Kapitel 05
        Chapter #0:5: start 1074.782000, end 1434.892000
          Metadata:
            title          : Kapitel 06
        Chapter #0:6: start 1434.892000, end 1674.548000
          Metadata:
            title          : Kapitel 07
        Chapter #0:7: start 1674.548000, end 1827.617000
          Metadata:
            title          : Kapitel 08
        Chapter #0:8: start 1827.617000, end 1947.904000
          Metadata:
            title          : Kapitel 09
        Chapter #0:9: start 1947.904000, end 2236.526000
          Metadata:
            title          : Kapitel 10
        Chapter #0:10: start 2236.526000, end 2348.054000
          Metadata:
            title          : Kapitel 11
        Chapter #0:11: start 2348.054000, end 2478.476000
          Metadata:
            title          : Kapitel 12
        Chapter #0:12: start 2478.476000, end 2956.912000
          Metadata:
            title          : Kapitel 13
        Chapter #0:13: start 2956.912000, end 3342.214000
          Metadata:
            title          : Kapitel 14
        Chapter #0:14: start 3342.214000, end 3669.416000
          Metadata:
            title          : Kapitel 15
        Chapter #0:15: start 3669.416000, end 4023.227000
          Metadata:
            title          : Kapitel 16
        Chapter #0:16: start 4023.227000, end 4310.222000
          Metadata:
            title          : Kapitel 17
        Chapter #0:17: start 4310.222000, end 4553.799000
          Metadata:
            title          : Kapitel 18
        Chapter #0:18: start 4553.799000, end 4958.120000
          Metadata:
            title          : Kapitel 19
        Chapter #0:19: start 4958.120000, end 5172.709000
          Metadata:
            title          : Kapitel 20
        Chapter #0:20: start 5172.709000, end 5262.299000
          Metadata:
            title          : Kapitel 21
        Chapter #0:21: start 5262.299000, end 5580.408000
          Metadata:
            title          : Kapitel 22
        Chapter #0:22: start 5580.408000, end 5857.727000
          Metadata:
            title          : Kapitel 23
        Chapter #0:23: start 5857.727000, end 6255.291000
          Metadata:
            title          : Kapitel 24
        Chapter #0:24: start 6255.291000, end 6602.596000
          Metadata:
            title          : Kapitel 25
        Chapter #0:25: start 6602.596000, end 6713.582000
          Metadata:
            title          : Kapitel 26
        Chapter #0:26: start 6713.582000, end 7110.895000
          Metadata:
            title          : Kapitel 27
        Chapter #0:27: start 7110.895000, end 7333.868000
          Metadata:
            title          : Kapitel 28
        Chapter #0:28: start 7333.868000, end 7671.664000
          Metadata:
            title          : Kapitel 29
        Chapter #0:29: start 7671.664000, end 7770.554000
          Metadata:
            title          : Kapitel 30
        Chapter #0:30: start 7770.554000, end 7956.615000
          Metadata:
            title          : Kapitel 31
        Chapter #0:31: start 7956.615000, end 8163.363000
          Metadata:
            title          : Kapitel 32
        Chapter #0:32: start 8163.363000, end 8371.655000
          Metadata:
            title          : Kapitel 33
        Chapter #0:33: start 8371.655000, end 8639.631000
          Metadata:
            title          : Kapitel 34
        Chapter #0:34: start 8639.631000, end 9005.079000
          Metadata:
            title          : Kapitel 35
        Chapter #0:35: start 9005.079000, end 9236.852000
          Metadata:
            title          : Kapitel 36
        Chapter #0:36: start 9236.852000, end 9602.259000
          Metadata:
            title          : Kapitel 37
        Chapter #0:37: start 9602.259000, end 9933.215000
          Metadata:
            title          : Kapitel 38
        Chapter #0:38: start 9933.215000, end 10008.498000
          Metadata:
            title          : Kapitel 39
        Chapter #0:39: start 10008.498000, end 10136.793000
          Metadata:
            title          : Kapitel 40
        Chapter #0:40: start 10136.793000, end 10308.590000
          Metadata:
            title          : Kapitel 41
        Chapter #0:41: start 10308.590000, end 10708.949000
          Metadata:
            title          : Kapitel 42
      Stream #0:0(ger): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default)
          Metadata:
            BPS            : 43666487
            DURATION        : 02:58:28.949000000
            NUMBER_OF_FRAMES: 256758
            NUMBER_OF_BYTES : 58452773570
            SOURCE_ID      : 001011
            _STATISTICS_WRITING_APP: mkvmerge v81.0 ('Milliontown') 64-bit
            _STATISTICS_WRITING_DATE_UTC: 2023-12-22 18:55:45
            _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID
          Side data:
            DOVI configuration record: version: 1.0, profile: 7, level: 6, rpu flag: 1, el flag: 1, bl flag: 1, compatibility id: 6
      Stream #0:1(ger): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
          Metadata:
            title          : German AC3 5.1
            BPS            : 640000
            DURATION        : 02:58:28.928000000
            NUMBER_OF_FRAMES: 334654
            NUMBER_OF_BYTES : 856714240
      Stream #0:2(eng): Audio: dts (dca) (DTS-HD MA), 48000 Hz, 5.1(side), s32p (24 bit) (default)
          Metadata:
            title          : English DTS-HD MA 5.1
            BPS            : 3969116
            DURATION        : 02:58:28.918000000
            NUMBER_OF_FRAMES: 1003961
            NUMBER_OF_BYTES : 5313117864
      Stream #0:3(ger): Subtitle: hdmv_pgs_subtitle (pgssub), 1920x1080 (default)
          Metadata:
            title          : German Forced
            BPS            : 1248
            DURATION        : 02:53:27.646000000
            NUMBER_OF_FRAMES: 189
            NUMBER_OF_BYTES : 1623885
      Stream #0:4(ger): Subtitle: hdmv_pgs_subtitle (pgssub)
          Metadata:
            title          : German
            BPS            : 26381
            DURATION        : 02:52:47.856000000
            NUMBER_OF_FRAMES: 2953
            NUMBER_OF_BYTES : 34190564
      Stream #0:5(eng): Subtitle: hdmv_pgs_subtitle (pgssub)
          Metadata:
            title          : English
            BPS            : 32535
            DURATION        : 02:54:04.808000000
            NUMBER_OF_FRAMES: 4752
            NUMBER_OF_BYTES : 42478301
      Stream #0:6(eng): Subtitle: hdmv_pgs_subtitle (pgssub), 1920x1080
          Metadata:
            title          : English Forced
            BPS            : 1088
            NUMBER_OF_BYTES : 1416439
    and my jf server log snippet:
    [2024-11-02 23:03:06.034 +01:00] [INF] User policy for "unbk". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-11-02 23:03:06.034 +01:00] [INF] RemoteClientBitrateLimit: 20000000, RemoteIP: "10.40.235.230", IsInLocalNetwork: True
    [2024-11-02 23:03:06.911 +01:00] [INF] Adding playback tracker : TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655
    [2024-11-02 23:03:06.911 +01:00] [INF] PlaybackTracker : Adding Start Event : 11/02/2024 23:03:06
    [2024-11-02 23:03:06.911 +01:00] [INF] Creating StartPlaybackTimer Task
    [2024-11-02 23:03:06.911 +01:00] [INF] StartPlaybackTimer : Entered
    [2024-11-02 23:03:07.674 +01:00] [INF] Processing playback tracker : "TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:03:26.911 +01:00] [INF] session.RemoteEndPoint : "10.40.235.230"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : event_playing_id    = "f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : event_user_id        = "3ed3d3ca6ec74e328774df987fe68b0b"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : event_user_id_int    = 1
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : session_playing_id  = "f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : session_user_id      = "3ed3d3ca6ec74e328774df987fe68b0b"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : play_method          = "DirectPlay"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : e.ClientName        = "Jellyfin Web"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : e.DeviceName        = "LG Smart TV"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : ItemName            = "Avatar - Aufbruch nach Pandora"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : ItemId              = "f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : ItemType            = "Movie"
    [2024-11-02 23:03:26.911 +01:00] [INF] StartPlaybackTimer : All matches, playback registered
    [2024-11-02 23:03:26.911 +01:00] [INF] Playback tracker found, adding playback info : "TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:03:26.911 +01:00] [INF] Saving playback tracking activity in DB
    [2024-11-02 23:03:26.967 +01:00] [INF] StartPlaybackTimer : Exited
    [2024-11-02 23:03:28.673 +01:00] [INF] Processing playback tracker : "TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:03:36.506 +01:00] [INF] "Webhook Item Added Notifier" Completed after 0 minute(s) and 0 seconds
    [2024-11-02 23:03:48.680 +01:00] [INF] Processing playback tracker : "TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:03:52.966 +01:00] [ERR] InPlayerEpisodePreviewPlugin: "Namo.Plugin.InPlayerEpisodePreview.Web.InPlayerPreview.js"
    [2024-11-02 23:03:55.172 +01:00] [INF] WS "2001:9e8:7a58:300:40e0:76ff:8d1:74aa" request
    [2024-11-02 23:04:08.702 +01:00] [INF] Processing playback tracker : "TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:04:25.298 +01:00] [WRN] WS "2001:9e8:7a58:300:40e0:76ff:8d1:74aa" error receiving data: "The remote party closed the WebSocket connection without completing the close handshake."
    [2024-11-02 23:04:25.340 +01:00] [INF] WS "2001:9e8:7a58:300:40e0:76ff:8d1:74aa" closed
    [2024-11-02 23:04:29.682 +01:00] [INF] Processing playback tracker : "TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:04:50.681 +01:00] [INF] Processing playback tracker : "TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:05:07.506 +01:00] [INF] "Webhook Item Added Notifier" Completed after 0 minute(s) and 0 seconds
    [2024-11-02 23:05:10.699 +01:00] [INF] Processing playback tracker : "TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:05:12.678 +01:00] [INF] Sending ForceKeepAlive message to 1 inactive WebSockets.
    [2024-11-02 23:05:31.698 +01:00] [INF] Processing playback tracker : "TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:05:41.504 +01:00] [INF] Playback stopped reported by app "Jellyfin Web" "10.10.0" playing "Avatar - Aufbruch nach Pandora". Stopped at "153714" ms
    [2024-11-02 23:05:41.548 +01:00] [INF] Playback stop tracker found, processing stop : "TW96aWxsYS81LjAgKFdlYjBTOyBMaW51eC9TbWFydFRWKSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvOTQuMC40NjA2LjEyOCBTYWZhcmkvNTM3LjM2IFdlYkFwcE1hbmFnZXJ8MTcwNjM1MzkwMDY4OA11-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:05:41.548 +01:00] [INF] PlaybackTracker : Adding Stop Event : 11/02/2024 23:05:41
    [2024-11-02 23:05:41.548 +01:00] [INF] Saving playback tracking activity in DB
    [2024-11-02 23:06:09.871 +01:00] [INF] User policy for "unbk". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-11-02 23:06:09.871 +01:00] [INF] RemoteClientBitrateLimit: 20000000, RemoteIP: "10.40.235.30", IsInLocalNetwork: True
    [2024-11-02 23:06:09.951 +01:00] [INF] Adding playback tracker : 5501d4b7e8818668851971274977a74105c2001c-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655
    [2024-11-02 23:06:09.951 +01:00] [INF] PlaybackTracker : Adding Start Event : 11/02/2024 23:06:09
    [2024-11-02 23:06:09.951 +01:00] [INF] Creating StartPlaybackTimer Task
    [2024-11-02 23:06:09.951 +01:00] [INF] StartPlaybackTimer : Entered
    [2024-11-02 23:06:10.938 +01:00] [INF] Processing playback tracker : "5501d4b7e8818668851971274977a74105c2001c-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:06:24.678 +01:00] [INF] Sending ForceKeepAlive message to 1 inactive WebSockets.
    [2024-11-02 23:06:29.952 +01:00] [INF] session.RemoteEndPoint : "10.40.235.30"
    [2024-11-02 23:06:29.952 +01:00] [INF] StartPlaybackTimer : event_playing_id    = "f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : event_user_id        = "3ed3d3ca6ec74e328774df987fe68b0b"
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : event_user_id_int    = 1
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : session_playing_id  = "f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : session_user_id      = "3ed3d3ca6ec74e328774df987fe68b0b"
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : play_method          = "DirectPlay"
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : e.ClientName        = "Android TV"
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : e.DeviceName        = "SHIELD-Wohnzimmer"
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : ItemName            = "Avatar - Aufbruch nach Pandora"
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : ItemId              = "f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : ItemType            = "Movie"
    [2024-11-02 23:06:29.953 +01:00] [INF] StartPlaybackTimer : All matches, playback registered
    [2024-11-02 23:06:29.953 +01:00] [INF] Playback tracker found, adding playback info : "5501d4b7e8818668851971274977a74105c2001c-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:06:29.953 +01:00] [INF] Saving playback tracking activity in DB
    [2024-11-02 23:06:30.001 +01:00] [INF] StartPlaybackTimer : Exited
    [2024-11-02 23:06:31.493 +01:00] [INF] Processing playback tracker : "5501d4b7e8818668851971274977a74105c2001c-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:06:36.677 +01:00] [INF] Sending ForceKeepAlive message to 1 inactive WebSockets.
    [2024-11-02 23:06:38.506 +01:00] [INF] "Webhook Item Added Notifier" Completed after 0 minute(s) and 0 seconds
    [2024-11-02 23:06:48.678 +01:00] [INF] Lost 1 WebSockets.
    [2024-11-02 23:06:51.501 +01:00] [INF] Processing playback tracker : "5501d4b7e8818668851971274977a74105c2001c-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:06:56.800 +01:00] [INF] Playback stopped reported by app "Android TV" "0.17.8" playing "Avatar - Aufbruch nach Pandora". Stopped at "44759" ms
    [2024-11-02 23:06:56.813 +01:00] [INF] Playback stop tracker found, processing stop : "5501d4b7e8818668851971274977a74105c2001c-3ed3d3ca6ec74e328774df987fe68b0b-f72c611821b0a893a849e7a0f014b655"
    [2024-11-02 23:06:56.813 +01:00] [INF] PlaybackTracker : Adding Stop Event : 11/02/2024 23:06:56
    [2024-11-02 23:06:56.813 +01:00] [INF] Saving playback tracking activity in DB
    DirectPlay was used correctly in both attempts, which is why I no longer know what to do.
    Does anyone have any suggestions how to fix this?
    NeonFlak
    2024-11-03, 09:58 AM
    This particular file is DV Profile 7, which the Shield can't play. There aren't actually any current streaming devices that can stream Profile 7 "multi layer".... or atleast weren't any last I checked.
    You can use DV Tool to convert Profile 7 to Profile 8 which drops the extra metadata that makes the DV file 12bit vs 10bit. There aren't many display devices, if any, that are true 12bit.
    You can also try turning on LLDV for the Shield in the dev menu to see if that does anything for you. Due to LG limitations with DV (LG expects the playing device to send LLDV anyway) this may allow you to play Profile 7 files that aren't multi layer.
    unbk
    2024-11-03, 03:01 PM
    I thought the Shield can play profile 7 but only uses the “basic” RPU DoVi metadata and not the rest of the FEL, which is enough for me as the TV can't do 12bit anyway.
    But i actually found the main issue, buried somewhere in the HDMI settings on the TV, "Deep Color" was turned off for some reason. This probably happened with the webOS 24 update.
    2024-11-03, 03:54 PM
    This is a known issue with exoplayer. I will not fallback to the HDR10 base layer. Not much Jellyfin can do, and there are numerous tickets that have been open for years on Google's git.
    I took the route that Neonflak suggested and just stripped all my DV content down to HDR10.
