    Jellyfin Forum Support Guides, Walkthroughs & Tutorials Guide: Running Jellyfin in Synology's DSM 7 Using Docker Compose
    • 1 Vote(s) - 5 Average
    Kurt
    Country:Portugal
    #11
    2024-05-29, 08:25 PM (This post was last modified: 2024-05-29, 09:06 PM by Kurt. Edited 2 times in total.)
    (2024-05-29, 08:03 PM)Efficient_Good_5784 Wrote: Yeah, that's it.
    You could just add each genre individually. It would be a bit more work, but it will get you to the same outcome. Though one benefit of doing it this longer way is that it will make it impossible for you to mess up and mount the top-most folder to the library.
    Now i have another problem...  Face-steam-from-nose
    I stopped JF, and edited yaml file to "- /volume1/musicConfused-facemusic:ro"/
    The project was rebuild and when i went to choose the libraries, all the folders side the main one (music) become visible. I start adding each one and at the end, when i tried to save, i received the following error:
    Even on the 1st time i set up JF, hadn't any problem. I'm feeling so dumb.
    Maybe i should delete everything and start all over again from the scratch.
    Update:
    I decided to start from the scratch and now it seems to be working (scanning all the files/folders).
    I'm a totally noob so, probably the issue was the number of times i edited the yaml file to try to make it work.
    Thanks!
    #12
    2024-05-29, 09:43 PM
    yaml files are sensitive to spacing, so it could have been that.
    Sorry about the late response. I was going to suggest that it may have been a permissions issue. Like maybe you switched the user that would run Jellyfin this time or something like that.
    Also, take advantage of containers. You're allowed to separate the important data from the rest of the service.
    So next time, make a copy of your config folder. So if you ever mess up, you can always go back. For example, Jellyfin v10.9 will make irreversible changes that won't allow your config files to go back to v10.8.13.
    With a backup, you could go back.
    Same if you mess things up, you got a backup to rely on.
    I would even say don't wait for updates to make backups too. You could manually (or with a simple script) make a copy of your config folder at set intervals. This way, you'll always know that you have some form of going back in time if things go bad.
    Kurt
    Country:Portugal
    #13
    2024-05-29, 11:28 PM
    (2024-05-29, 09:43 PM)Efficient_Good_5784 Wrote: yaml files are sensitive to spacing, so it could have been that.
    Hi again,
    No problem. I only saw your reply now.
    When i started from the scratch and decided to create a backup folder (outside of the main one for JF), and then i went to Container Manager -> Container and exported (only) the container settings. And to play safe, i also exported to my pc.
    Now it's all working like i want; just need to figure out how to access from outside of my network without having to use a VPN (like Plex and Plexamp).
    Thanks for all your time and patience!
    Haxornator
    2024-06-18, 07:05 AM
    Can anyone provide additional information on migrating from the community version of Jellyfin, to the docker version.
    I mostly want to keep my configuration.
    2024-06-18, 02:31 PM
    You'd have to find where the community version stores the jellyfin data and find /config and make a copy of it.
    XavierP56
    Country:France
    #16
    2024-09-03, 06:08 PM (This post was last modified: 2024-09-03, 07:07 PM by XavierP56. Edited 3 times in total.)
    I have followed this great tutorial, got it working.
    I set network to host, I can connect but I don't see my Chromecast Ultra.
    I'm using the embedded Web client (192.168.1.241:8096, where 192.168.1.241 is my DS423)
    I'm using Ethernet on the PC, on the DS423+, the Chromecast Ultra is also on Ethernet. All in 192.168.1.x.
    Can't understand....
    If I'm using an android client, I can see the Chromecast
    So it seems the embedded client can't see Chromecast.
    What goes wrong ?
    Thanks.
    xyu
    Country:Taiwan
    #17
    2024-09-16, 05:32 PM
    My YAML file is set up like this, and I've tried adding the volume2 bind and target to the compose file.  However, when i try to add the library in jellyfin, the library on volume2 does not show up at all.  (I ran out of space on volume 1 and would like to store my media in volume2)
    version: '3.5'
        image: jellyfin/jellyfin
        container_name: jellyfin
    #    user: uid:gid
        network_mode: 'host'
          - ./config:/config
          - ./cache:/cache
          - type: bind
            source: /volume1/Media/Movies
            target: /movies
          - type: bind
            source: /volume2/Media2/Movies
            target: /movies
          - type: bind
            source: /volume1/Media/Shows
            target: /shows
          - type: bind
            source: /volume1/Media/Books
            target: /books
            read_only: false
    Am I doing something wrong, is there another place i need to add volume2 so that jellyfin knows to look for it when adding a Library?
    quecup
    2024-11-17, 04:25 PM (This post was last modified: 2024-11-18, 05:22 AM by quecup. Edited 6 times in total.)
    (2023-12-31, 05:53 PM)Efficient_Good_5784 Wrote: This will be a short guide for Synology NAS units running DSM 7 on how to run a Jellyfin
    This worked for me up until I tried playing back any HDR content. In that case I have problems (either a fatal error on the Jellyfin player, or jerky video, depending on the options) on my DS918+
    The error goes back to tone mapping. This is when I'm playing HDR content on a non-HDR screen or on a screen that doesn't support the content's specific HDR type (DV, HDR10, etc).
    Three paths:
    1. If Enable VPP Tone mapping is enabled, then I get a "fatal player error" when I try to play HDR content
    2. If Enable Tone mapping is enabled, then my NAS CPU is near 100%, the video stutters, and it seems that hardware transcoding is bypassed and it uses software transcoding instead. Unwatchable.
    3. If none are enabled (ie. tone mapping is disabled), then the HDR content plays just fine, but has no tone mapping. So, colour is off.
    According to the Github bug thread [bug] 10.8.12 breaks transcoding with HDR content on Synology DS1019+ #10550 it seems that this is not going to be fixed. Can't be fixed. Intel's OpenCL driver no longer supports Linux 4.4.x (ie. every Synology device), and the only fix is to rollback to Jellyfin 10.8.11. This thread has good info on the problem.
    I updated my NAS today to the latest DSM 7.2.2-72806 Update 1 which still runs the 4.4.302 kernel. Given what I've read from Synology, they are not going to jump their Linux kernel forward to regain support for Intel OpenCL's current driver. Synology has officially dropped HW encoding and decoding support with the latest DSM 7.2.2-72806. Is this in reaction to Intel dropping support for Linux 4.4.x? Either way, I can't see Synology fixing this after putting out a press release saying that breaking codec support is a new and improved feature, not a bug.
    This took me a long time to figure out. Can you add to your instructions, that Synology owners who intend to HW transcode their HDR content, should use Jellyfin 10.8.11 instead of the latest version. And if they intend to go with the latest Jellyfin anyway, they should disable both tone mapping options. Otherwise, stutters and crashes will happen with every HDR video that needs transcoding.
    It seems plausible that future Jellyfin versions (with baked in Intel driver updates) could break Synology HW decoding further. Right now, it's just HDR tone mapping that's broken on versions after 10.8.11.
    As for me, I'm going to live with the bad colours for now, and possibly try pre-transcoding my HDR files with tdarr or something. That's a far future project.
    #19
    2024-12-21, 04:42 AM
    (2024-09-16, 05:32 PM)xyu Wrote: My YAML file is set up like this, and I've tried adding the volume2 bind and target to the compose file.  However, when i try to add the library in jellyfin, the library on volume2 does not show up at all.  (I ran out of space on volume 1 and would like to store my media in volume2)
    version: '3.5'
    #    user: uid:gid
          - ./config:/config
          - ./cache:/cache
          - type: bind
            target: /movies
          - type: bind
            target: /movies
          - type: bind
            target: /shows
          - type: bind
            target: /books
            read_only: false
    I don't know if you got help for this already, but your issue is that you cannot link multiple mounts to the same location.
    What you basically did is link both movie directories to appear under the same "/movies" target.
    What this does is cause an error where the container won't know which place to reference when it tries to access "/movies" internally.
    You should give the new movie directory a different target name and that new name should appear in the container.
    You can add multiple directories to a single library in Jellyfin, so make sure to do that if you want to mix it with your current movie library in Jellyfin.
    #20
    2024-12-21, 04:49 AM
    (2024-11-17, 04:25 PM)quecup Wrote: This took me a long time to figure out. Can you add to your instructions, that Synology owners who intend to HW transcode their HDR content, should use Jellyfin 10.8.11 instead of the latest version. And if they intend to go with the latest Jellyfin anyway, they should disable both tone mapping options. Otherwise, stutters and crashes will happen with every HDR video that needs transcoding.
    As time is moving on, more clients that use Jellyfin are adding hard requirements to use certain Jellyfin server versions. This is bad advice as for example the current release of the Jellyfin Android TV app doesn't support that old of a server anymore and will not work with it.
    It sucks that Synology is using an old Linux kernel that's missing the required files for HDR to properly tone map, but that's a Synology issue that they haven't acted on yet.
    Your best course of action if you are deeply into HDR content is to switch to another platform to host Jellyfin that properly supports it. Or wait until Synology updates the kernel they're using.
