    Jellyfin Forum Support Troubleshooting Media Scanning & Identification Help with show parts
    Austin Universty
    2024-07-15, 03:51 PM
    Hi I was looking at the documentation for episode parts. What my server is doing is it is putting the episodes as two different episodes. For example, even if I have S02e02 part 1 and S02e02 part 2, it is setting the part 2 one as episode 3. Can someone give me a example of the correct way of naming the episodes so this doesn't happen?
    Thanks,
    Austin
    2024-07-15, 04:25 PM
    Can you provide the full path leading to the episodes with split parts?
    2024-07-15, 04:34 PM
    Our documentation provides examples.
    Some features like this require that you very strictly adhere to file organization.  If you aren't using season folders, do so.  And a lot of these "versions" and "parts" features are case sensitive.  So you may need to use "Part" instead of "part".
    The full file path in my example.
    /testShows/Dark Matter/Season 01/s01e02 Part 1.mp4
