    Jellyfin Forum Support General Questions Help with transcoding
    setting up new server need help with transcoding
    troothdotcom
    Threads: 22
    2024-09-25, 06:59 AM
    I recently upgraded to this  https://www.amazon.com/Beelink-Intel-N10...S94J5?th=1 and I set up Jellyfin through docker compose but now I'm not sure how to proceed to be able to use hardware acceleration. I tried chat-gpt but it just confused me more. Any and all help is greatly appreciated. Thanks!
    2024-09-25, 01:17 PM
    What OS are you running on? We have documentation for docker compose setup of Intel GPUs.
    https://jellyfin.org/docs/general/admini...ial-docker
    Pretty simple. Just add this to your compose.
    devices:
        group_add:
          - "993" # Change this to match your "render" host group id and remove this comment
    The group_add requires that you run a couple commands (documented in the link) to find the proper ID number on your system for the render group. Here is my full docker compose as an example.
      jellyfin-testing:
        image: jellyfin/jellyfin:10.9.11
        container_name: jellyfin-testing
        user: 110:110
        group_add:
          - "993" # Intel render group
        networks:
          [censored bridge name]:
            ipv4_address: 172.16.100.2
        expose:
          - 8096
          - ./jellyfin-stable-data/config:/config
          - ./jellyfin-stable-data/cache:/cache
          - /media/library:/media/library:ro
          - /media/storage2:/media/storage2
          - /media/ramdisk:/media/ramdisk
        devices:
        environment:
          - TZ=America/New_York
        restart: 'unless-stopped'
    troothdotcom
    Threads: 22
    2024-09-25, 02:46 PM
    (2024-09-25, 01:17 PM)TheDreadPirate Wrote: What OS are you running on?  We have documentation for docker compose setup of Intel GPUs.
        devices:
        group_add:
      jellyfin-testing:
        user: 110:110
        group_add:
        networks:
        expose:
          - 8096
        devices:
        environment:
    Thank you this was very detailed. I am using Ubuntu server OS and docker compose and still fairly new to all this so I am not sure what i am doing wrong but the issue I am having right now is that I don't seem to have a /dev/dri directory.  Do I have to create my own or should it have been created when downloading the drivers?
    2024-09-25, 03:03 PM
    And I'm assuming you mean you don't have a /dev/dri directory on the host.
    What version of Ubuntu? Intel's drivers are built into the Linux kernel, as long as your kernel is new enough.
    cat /etc/os-release
    uname -a
    Share the output of those two commands.
    troothdotcom
    Threads: 22
    2024-09-25, 03:13 PM
    I got it! Thanks
    i had to run sudo apt install --install-recommends linux-generic-hwe-22.04
        devices:
        group_add:
      jellyfin-testing:
        user: 110:110
        group_add:
        networks:
        expose:
          - 8096
        devices:
        environment:
    2024-09-25, 03:22 PM (This post was last modified: 2024-09-25, 03:23 PM by TheDreadPirate. Edited 2 times in total.)
    Ah. So you were on kernel 5.15 on Ubuntu 22.04. That will do it.
    troothdotcom
    Threads: 22
    2024-09-26, 02:46 PM
    Thank you so much! Finally got Jellyfin working and transcoding how I wanted. You're the best.
        devices:
        group_add:
      jellyfin-testing:
        user: 110:110
        group_add:
        networks:
        expose:
          - 8096
        devices:
        environment:
