    Jellyfin Forum Support Troubleshooting HW acceleration doesn' work with h264 coded videos
    lordmarck
    Country:Italy
    #11
    2023-11-30, 09:25 PM
    I did some test and turns out that if I lower the quality more it switches to the gpu. I had to go down to 480 3Mbps and when i go bach up it returns to cpu.
    2023-11-30, 09:28 PM
    How much CPU usage are we talking? What you are describing doesn't make sense.
    lordmarck
    Country:Italy
    #13
    2023-11-30, 09:32 PM (This post was last modified: 2023-11-30, 09:34 PM by lordmarck.)
    the log is for the right activity. How do I upload to sourcebin?
    25-30% on a ryzen 3 3100
    https://sourceb.in/
    Copy and paste, click save. It will generate a link. Provide the link here.
    lordmarck
    Country:Italy
    #15
    2023-11-30, 09:38 PM
    (2023-11-30, 09:23 PM)TheDreadPirate Wrote:
    (2023-11-30, 09:15 PM)lordmarck Wrote: that's weird. I was definitely watching at lower res.
    the video is at 1080 60 Mbps an i was watching at 720 8 mbps
    Make sure you are selecting the ffmpeg log that corresponds to that activity.  Also, upload the log to sourcebin instead of pasting it directly in a post here.
    (2023-11-30, 09:34 PM)TheDreadPirate Wrote: https://sourceb.in/
    copy that thanks
    2023-11-30, 09:58 PM
    (2023-11-30, 09:32 PM)lordmarck Wrote: the log is for the right activity. How do I upload to sourcebin?
    I missed this edit.  25-30% on a Ryzen 3100 is definitely NOT video transcoding.  If it was video transcoding it would be at or close to 100%.  25-30% is definitely consistent with an audio only transcode.
    lordmarck
    Country:Italy
    #17
    2023-11-30, 10:05 PM (This post was last modified: 2023-11-30, 10:07 PM by lordmarck. Edited 1 time in total.)
    ok. So it doesn't transcode video at all unless it's under a certain quality?
    2023-11-30, 10:10 PM
    I know the quality selector mentions resolutions, but the bit rate specified is the only thing that matters.
    The video in the log you shared has a bit rate of about 3.6Mbps.
    Duration: 01:43:14.05, start: 0.000000, bitrate: 3653 kb/s
    Stream #0:0: Video: h264 (High), yuv420p(progressive), 1920x808 [SAR 1:1 DAR 240:101], 23.98 fps, 23.98 tbr, 1k tbn (default)
    You would have to select a bit rate below that before it is transcoded.
    lordmarck
    Country:Italy
    #19
    2023-11-30, 10:34 PM
    ahh ok! thank you so much for your time and patience!!!
