    Jellyfin Forum Development Client Development Issue Using php script for api call
    • 1 Vote(s) - 5 Average
    Need to solve issue in php script for calling endpoint of users.
    Ahmad Arif
    2024-04-28, 08:00 AM (This post was last modified: 2024-04-28, 08:02 AM by Ahmad Arif. Edited 2 times in total.)
    I make php script for calling the endpoint of user.But its still return only null.Not any response in kind of error.
    File Attachment.
    .php   index.php (Size: 12.47 KB / Downloads: 172)
    ermineglug
    2024-10-23, 05:05 AM
    (2024-04-28, 08:00 AM)Ahmad Arif Wrote: I make php script for calling the endpoint of user.But its still return only null.Not any response in kind of error.
    File Attachment.
    Hey there! Here are a few troubleshooting steps you can try to identify the problem:
    1. Check the Endpoint URL: Ensure that the URL you're calling is correct. A small typo can lead to a null response.
    2. Enable Error Reporting: Add "error_reporting(E_ALL);" and "ini_set('display_errors', 1);" at the beginning of your script to display any potential errors that might be hidden.
    3. Inspect Response: If you’re using "file_get_contents()" or "cURL", check if you're capturing the response correctly. For cURL, make sure to include "curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);" to get the response as a string instead of outputting it directly.
    4. Headers and Payload: Confirm that you’re sending the correct headers (like "Content-Type") and payload if required by the endpoint.
    5. API Authentication: If the endpoint requires authentication (like an API key or token), make sure you're passing it correctly.
    If you share your code, I might be able to provide more specific advice!
    angelapick
    2025-10-28, 08:38 AM
    Good tutorial. You helps me a lot.
