    Jellyfin Forum Support Troubleshooting Jellyfin become unresponsive, and will not start after reboot
    jsnotlout1
    2024-10-04, 10:18 PM (This post was last modified: 2024-10-04, 10:20 PM by jsnotlout1. Edited 1 time in total.)
    I was alerted by my family that the jellyfin server was not allowing anyone to log in. So after trying to solve the problem, I chose to reboot the server, but now it will not start at all. I have a theory, that all of this is caused directly by a failed release upgrade that didn't fully complete. The jellyfin server has not been updating itself via apt-get properly
    Based on the frequency of issues like this, I am assuming that my server itself is messed up, That being the case, is there any way to backup the jellyfin config files so I can restore most of to a fresh server and jellyfin instance?
    2024-10-04, 11:21 PM (This post was last modified: 2024-10-04, 11:21 PM by TheDreadPirate.)
    Share the output of this command via pastebin.
    sudo journalctl -u jellyfin -n 200 --no-pager
    Also, what distro are you using?
    jsnotlout1
    2024-10-04, 11:27 PM
    (2024-10-04, 11:21 PM)TheDreadPirate Wrote: Share the output of this command via pastebin.
    I am using ubuntu 24.04.1 LTS
    command:
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at System.Xml.XmlTextReaderImpl.Throw(Exception e)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at System.Xml.XmlReader.MoveToContent()
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMigrationOptions.Read4_MigrationOptions()
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at System.Reflection.MethodBaseInvoker.InvokeWithNoArgs(Object obj, BindingFlags invokeAttr)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    --- End of inner exception stack trace ---
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromStream(Type type, Stream stream)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromFile(Type type, String file)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at Jellyfin.Server.Migrations.MigrationRunner.RunPreStartup(ServerApplicationPaths appPaths, ILoggerFactory loggerFactory)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at Jellyfin.Server.Program.StartApp(StartupOptions options)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:    at Jellyfin.Server.Program.<Main>(String[] args)
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]: Unhandled exception. System.InvalidOperationException: There is an error in XML document (0, 0).
    Oct 04 21:33:13 flintlockwood jellyfin[1339796]:  ---> System.Xml.XmlException: Root element is missing.
    Oct 04 21:33:14 flintlockwood systemd[1]: jellyfin.service: Main process exited, code=dumped, status=6/ABRT
    Oct 04 21:33:14 flintlockwood systemd[1]: jellyfin.service: Failed with result 'core-dump'.
    Oct 04 21:33:14 flintlockwood systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 2.
    Oct 04 21:33:14 flintlockwood systemd[1]: Started jellyfin.service - Jellyfin Media Server.
    Oct 04 21:33:14 flintlockwood (jellyfin)[1339845]: jellyfin.service: Referenced but unset environment variable evaluates to an empty string: JELLYFIN_NOWEBAPP_OPT, JELLYFIN_SERVICE_OPT
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Jellyfin version: 10.9.7
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Environment Variables: ["[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]", "[JELLYFIN_ARGS, $JELLYFIN_WEB_OPT $JELLYFIN_FFMPEG_OPT $JELLYFIN_SERVICE_OPT $JELLYFIN_NOWEBAPP_OPT $JELLFIN_ADDITIONAL_OPTS --datadir $JELLYFIN_DATA_DIR --configdir $JELLYFIN_CONFIG_DIR --logdir $JELLYFIN_LOG_DIR --cachedir $JELLYFIN_CACHE_DIR]", "[JELLYFIN_WEB_OPT, --webdir=/usr/share/jellyfin/web]", "[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_FFMPEG_OPT, --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_USER, jellyfin]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_ADDITIONAL_OPTS, ]"]
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--webdir=/usr/share/jellyfin/web", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Operating system: Ubuntu 24.04.1 LTS
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Architecture: X64
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] 64-Bit Process: True
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] User Interactive: True
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Processor count: 8
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Program data path: /var/lib/jellyfin
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Log directory path: /var/log/jellyfin
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Config directory path: /etc/jellyfin
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Cache path: /var/cache/jellyfin
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Web resources path: /usr/share/jellyfin/web
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [INF] Application directory: /usr/lib/jellyfin/bin/
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: [21:33:14] [FTL] Unhandled Exception
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: System.InvalidOperationException: There is an error in XML document (0, 0).
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:  ---> System.Xml.XmlException: Root element is missing.
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at System.Xml.XmlTextReaderImpl.Throw(Exception e)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at System.Xml.XmlReader.MoveToContent()
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMigrationOptions.Read4_MigrationOptions()
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at System.Reflection.MethodBaseInvoker.InvokeWithNoArgs(Object obj, BindingFlags invokeAttr)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    --- End of inner exception stack trace ---
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromStream(Type type, Stream stream)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromFile(Type type, String file)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at Jellyfin.Server.Migrations.MigrationRunner.RunPreStartup(ServerApplicationPaths appPaths, ILoggerFactory loggerFactory)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at Jellyfin.Server.Program.StartApp(StartupOptions options)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]:    at Jellyfin.Server.Program.<Main>(String[] args)
    Oct 04 21:33:14 flintlockwood jellyfin[1339845]: Unhandled exception. System.InvalidOperationException: There is an error in XML document (0, 0).
    Oct 04 21:33:15 flintlockwood systemd[1]: jellyfin.service: Main process exited, code=dumped, status=6/ABRT
    Oct 04 21:33:15 flintlockwood systemd[1]: jellyfin.service: Failed with result 'core-dump'.
    Oct 04 21:33:15 flintlockwood systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 3.
    Oct 04 21:33:15 flintlockwood systemd[1]: Started jellyfin.service - Jellyfin Media Server.
    Oct 04 21:33:15 flintlockwood (jellyfin)[1339908]: jellyfin.service: Referenced but unset environment variable evaluates to an empty string: JELLYFIN_NOWEBAPP_OPT, JELLYFIN_SERVICE_OPT
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Jellyfin version: 10.9.7
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Environment Variables: ["[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_ARGS, $JELLYFIN_WEB_OPT $JELLYFIN_FFMPEG_OPT $JELLYFIN_SERVICE_OPT $JELLYFIN_NOWEBAPP_OPT $JELLFIN_ADDITIONAL_OPTS --datadir $JELLYFIN_DATA_DIR --configdir $JELLYFIN_CONFIG_DIR --logdir $JELLYFIN_LOG_DIR --cachedir $JELLYFIN_CACHE_DIR]", "[JELLYFIN_FFMPEG_OPT, --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_ADDITIONAL_OPTS, ]", "[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[JELLYFIN_USER, jellyfin]", "[JELLYFIN_WEB_OPT, --webdir=/usr/share/jellyfin/web]", "[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]"]
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--webdir=/usr/share/jellyfin/web", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Operating system: Ubuntu 24.04.1 LTS
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Architecture: X64
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] 64-Bit Process: True
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] User Interactive: True
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Processor count: 8
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Program data path: /var/lib/jellyfin
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Log directory path: /var/log/jellyfin
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Config directory path: /etc/jellyfin
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Cache path: /var/cache/jellyfin
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Web resources path: /usr/share/jellyfin/web
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [INF] Application directory: /usr/lib/jellyfin/bin/
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: [21:33:16] [FTL] Unhandled Exception
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: System.InvalidOperationException: There is an error in XML document (0, 0).
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:  ---> System.Xml.XmlException: Root element is missing.
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at System.Xml.XmlTextReaderImpl.Throw(Exception e)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at System.Xml.XmlReader.MoveToContent()
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMigrationOptions.Read4_MigrationOptions()
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at System.Reflection.MethodBaseInvoker.InvokeWithNoArgs(Object obj, BindingFlags invokeAttr)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    --- End of inner exception stack trace ---
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromStream(Type type, Stream stream)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromFile(Type type, String file)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at Jellyfin.Server.Migrations.MigrationRunner.RunPreStartup(ServerApplicationPaths appPaths, ILoggerFactory loggerFactory)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at Jellyfin.Server.Program.StartApp(StartupOptions options)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]:    at Jellyfin.Server.Program.<Main>(String[] args)
    Oct 04 21:33:16 flintlockwood jellyfin[1339908]: Unhandled exception. System.InvalidOperationException: There is an error in XML document (0, 0).
    Oct 04 21:33:17 flintlockwood systemd[1]: jellyfin.service: Main process exited, code=dumped, status=6/ABRT
    Oct 04 21:33:17 flintlockwood systemd[1]: jellyfin.service: Failed with result 'core-dump'.
    Oct 04 21:33:17 flintlockwood systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 4.
    Oct 04 21:33:17 flintlockwood systemd[1]: Started jellyfin.service - Jellyfin Media Server.
    Oct 04 21:33:17 flintlockwood (jellyfin)[1339950]: jellyfin.service: Referenced but unset environment variable evaluates to an empty string: JELLYFIN_NOWEBAPP_OPT, JELLYFIN_SERVICE_OPT
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Jellyfin version: 10.9.7
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Environment Variables: ["[JELLYFIN_USER, jellyfin]", "[JELLYFIN_FFMPEG_OPT, --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]", "[JELLYFIN_ARGS, $JELLYFIN_WEB_OPT $JELLYFIN_FFMPEG_OPT $JELLYFIN_SERVICE_OPT $JELLYFIN_NOWEBAPP_OPT $JELLFIN_ADDITIONAL_OPTS --datadir $JELLYFIN_DATA_DIR --configdir $JELLYFIN_CONFIG_DIR --logdir $JELLYFIN_LOG_DIR --cachedir $JELLYFIN_CACHE_DIR]", "[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_WEB_OPT, --webdir=/usr/share/jellyfin/web]", "[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[JELLYFIN_ADDITIONAL_OPTS, ]"]
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--webdir=/usr/share/jellyfin/web", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Operating system: Ubuntu 24.04.1 LTS
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Architecture: X64
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] 64-Bit Process: True
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] User Interactive: True
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Processor count: 8
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Program data path: /var/lib/jellyfin
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Log directory path: /var/log/jellyfin
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Config directory path: /etc/jellyfin
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Cache path: /var/cache/jellyfin
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Web resources path: /usr/share/jellyfin/web
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [INF] Application directory: /usr/lib/jellyfin/bin/
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: [21:33:17] [FTL] Unhandled Exception
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: System.InvalidOperationException: There is an error in XML document (0, 0).
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:  ---> System.Xml.XmlException: Root element is missing.
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at System.Xml.XmlTextReaderImpl.Throw(Exception e)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at System.Xml.XmlReader.MoveToContent()
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderMigrationOptions.Read4_MigrationOptions()
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at System.Reflection.MethodBaseInvoker.InvokeWithNoArgs(Object obj, BindingFlags invokeAttr)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    --- End of inner exception stack trace ---
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromStream(Type type, Stream stream)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at Emby.Server.Implementations.Serialization.MyXmlSerializer.DeserializeFromFile(Type type, String file)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at Jellyfin.Server.Migrations.MigrationRunner.RunPreStartup(ServerApplicationPaths appPaths, ILoggerFactory loggerFactory)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at Jellyfin.Server.Program.StartApp(StartupOptions options)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]:    at Jellyfin.Server.Program.<Main>(String[] args)
    Oct 04 21:33:17 flintlockwood jellyfin[1339950]: Unhandled exception. System.InvalidOperationException: There is an error in XML document (0, 0).
    Oct 04 21:33:18 flintlockwood systemd[1]: jellyfin.service: Main process exited, code=dumped, status=6/ABRT
    Oct 04 21:33:18 flintlockwood systemd[1]: jellyfin.service: Failed with result 'core-dump'.
    Oct 04 21:33:18 flintlockwood systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 5.
    Oct 04 21:33:18 flintlockwood systemd[1]: jellyfin.service: Start request repeated too quickly.
    Oct 04 21:33:18 flintlockwood systemd[1]: Failed to start jellyfin.service - Jellyfin Media Server.
    2024-10-04, 11:49 PM
    cd /etc/jellyfin
    sudo mkdir backup
    sudo mv *.xml backup
    sudo apt upgrade jellyfin
    If it doesn't automatically start, sudo systemctl restart jellyfin. If it fails to start again, repeat the last post and share the output of journalctl.
    jsnotlout1
    2024-10-05, 12:33 AM
    (2024-10-04, 11:49 PM)TheDreadPirate Wrote:
    cd /etc/jellyfin
    sudo mkdir backup
    There might be something wrong with my server, As far as I can tell it should have enough space. I can't expand /var while the system is booted, but it's complaining about low space. The drive still has plenty of space, and it ran all the apt updates just fine last night. So I have no idea why its full now.
    Perhaps the low space on /var is whats keeping it from starting at all?
    2024-10-05, 01:00 AM
    df -h
    jsnotlout1
    2024-10-05, 01:42 AM
    (2024-10-05, 01:00 AM)TheDreadPirate Wrote:
    df -h
    2024-10-05, 02:11 AM
    You're out of space. Your database may or may not be borked.
    jsnotlout1
    2024-10-05, 03:07 AM
    (2024-10-05, 02:11 AM)TheDreadPirate Wrote: You're out of space.  Your database may or may not be borked.
    Noted, I think it's time I accept the reality that this server needs a fresh install. I can't keep patching it up
