    Jellyfin Forum Support Troubleshooting Jellyfin container not starting after disk space issue
    Autrui
    2024-08-09, 02:56 AM
    Hi,
    I've been using a Jellyfin docker container on my Openmediavault for a while, but I had an issue with my disk space that was fully filled, and after freeing space, jellyfin doesn't work anymore.
    Here is my docker compose file:
    # https://hub.docker.com/r/linuxserver/jellyfin
        container_name: jellyfin
        environment:
          - PUID=1001
          - PGID=100
          - ${DOCKER_CONFIG}/jellyfin/config:/config
          - ${DATA}/media/tv:/data/tvshows # SKIP_BACKUP
          - ${DATA}/media/movies:/data/movies # SKIP_BACKUP
          - ${DATA}/media/emp:/data/emp # SKIP_BACKUP
          - ${DATA}/media:/data # SKIP_BACKUP
          - ${DOCKER_CONFIG}/jellyfin/config/custom_scripts:/custom-cont-init.d:ro
        ports:
          - 8096:8096
          - 8920:8920 #optional
          - 7359:7359/udp #optional
          - 1900:1900/udp #optional
        restart: always
    Main: Jellyfin version: 10.9.7
    Here are the logs :
    [02:51:39] [INF] [1] Jellyfin.Server.Migrations.MigrationRunner: Applying migration 'MigrateActivityLogDatabase'
    [02:51:39] [WRN] [1] Jellyfin.Server.Migrations.Routines.MigrateActivityLogDb: Migrating the activity database may take a while, do not stop Jellyfin.
    [02:51:39] [ERR] [1] Jellyfin.Server.Migrations.MigrationRunner: Could not apply migration 'MigrateActivityLogDatabase'
    Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: 'no such table: ActivityLog'.
       at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)
       at Microsoft.Data.Sqlite.SqliteCommand.PrepareAndEnumerateStatements()+MoveNext()
       at Microsoft.Data.Sqlite.SqliteCommand.GetStatements()+MoveNext()
       at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()
       at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)
       at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader()
       at Emby.Server.Implementations.Data.SqliteExtensions.Query(SqliteConnection sqliteConnection, String commandText)+MoveNext()
       at Jellyfin.Server.Migrations.Routines.MigrateActivityLogDb.Perform()
       at Jellyfin.Server.Migrations.MigrationRunner.PerformMigrations(IMigrationRoutine[] migrations, MigrationOptions migrationOptions, Action`1 saveConfiguration, ILogger logger)
    [02:51:39] [FTL] [1] Main: Error while starting server
       at Jellyfin.Server.Migrations.MigrationRunner.Run(CoreAppHost host, ILoggerFactory loggerFactory)
       at Jellyfin.Server.Program.StartServer(IServerApplicationPaths appPaths, StartupOptions options, IConfiguration startupConfig)
    [02:51:39] [INF] [1] Main: Running query planner optimizations in the database... This might take a while
    [02:51:42] [INF] [1] Jellyfin.Server.Migrations.MigrationRunner: Applying migration 'MigrateActivityLogDatabase'
    [02:51:42] [WRN] [1] Jellyfin.Server.Migrations.Routines.MigrateActivityLogDb: Migrating the activity database may take a while, do not stop Jellyfin.
    [02:51:42] [ERR] [1] Jellyfin.Server.Migrations.MigrationRunner: Could not apply migration 'MigrateActivityLogDatabase'
    [02:51:42] [FTL] [1] Main: Error while starting server
    Can anyone help me fix this issue ? Thanks !
    2024-08-09, 04:22 AM
    If you let Jellyfin's database run out of space, there is very little to nothing you can do about it.
    Running out of space is a death sentence for databases.
    Your only options are to restore from a backup, or restart with a fresh server.
    2024-08-09, 02:26 PM
    You could try deleting the migrations.xml file located in /config in the container. But it is quite possible that your DB is not recoverable.
