    Jellyfin Forum Support Troubleshooting Jellyfin keeps fetching wrong metadata and images
    Files and folders are named correctly
    elephantLYFE
    Threads: 8
    2024-01-06, 08:07 AM
    Remember, you need to make sure you have plug ins for the DB you want to use.
    Example, i had an issue pulling from TVDB for Shows library, and realized i did not have a plugin for it installed.
    HARDWARE/SOFTWARE SPECS
    NAS: Synology DS720+
    OS: DSM 7.2-64570 Update 3
    CPU: Intel Celeron J4125 Geminilake
    RAM: 10GB
    Container Manager(Docker):20.10.23-1437
    Docker-Image: Jellyfin 10.8.10
    HDD: 2x10TB Segate IronWolf (Raid 1)
    mauri1223
    Country:Uruguay
    #12
    2024-03-19, 04:01 AM
    Hi, Any update on this? Im having a similar problem using Identify to get the correct metadata but never updates after finishing. I tried using IMDb ID but same issue.
    2024-03-19, 03:51 PM
    Which metadata provider is your primary? And what show/movie? Can you provide what the folder and file name is?
