    Jellyfin Forum Support Troubleshooting Jellyfin not starting! Please help | v10.10.3
    Hi, Noob here. My Jellyfin was working fine on my system until recently, but it suddenly stopped. I tried restarting the server multiple times, but it didn’t resolve the issue. Checking the logs revealed the following error:
    darthvader
    2024-12-16, 09:14 AM
    [2024-12-16 14:12:49.211 +05:30] [INF] [1] Main: Jellyfin version: "10.10.3"
    [2024-12-16 14:12:49.255 +05:30] [INF] [1] Main: Environment Variables: ["[JELLYFIN_LOG_DIR, <REDACTED>/jellyfin/log]"]
    [2024-12-16 14:12:49.258 +05:30] [INF] [1] Main: Arguments: ["/Applications/Jellyfin.app/Contents/MacOS/jellyfin.dll", "--webdir", "/Applications/Jellyfin.app/Contents/Resources/jellyfin-web", "--ffmpeg", "/Applications/Jellyfin.app/Contents/MacOS/ffmpeg", "--datadir", "<REDACTED>/jellyfin"]
    [2024-12-16 14:12:49.258 +05:30] [INF] [1] Main: Operating system: "Darwin 22.6.0 Darwin Kernel Version 22.6.0"
    [2024-12-16 14:12:49.258 +05:30] [INF] [1] Main: Architecture: X64
    [2024-12-16 14:12:49.259 +05:30] [INF] [1] Main: 64-Bit Process: True
    [2024-12-16 14:12:49.259 +05:30] [INF] [1] Main: User Interactive: True
    [2024-12-16 14:12:49.259 +05:30] [INF] [1] Main: Processor count: 4
    [2024-12-16 14:12:49.259 +05:30] [INF] [1] Main: Program data path: "<REDACTED>/jellyfin"
    [2024-12-16 14:12:49.259 +05:30] [INF] [1] Main: Log directory path: "<REDACTED>/jellyfin/log"
    [2024-12-16 14:12:49.259 +05:30] [INF] [1] Main: Config directory path: "<REDACTED>/jellyfin/config"
    [2024-12-16 14:12:49.259 +05:30] [INF] [1] Main: Cache path: "<REDACTED>/jellyfin/cache"
    [2024-12-16 14:12:49.260 +05:30] [INF] [1] Main: Temp directory path: "<REDACTED>/jellyfin/tmp"
    [2024-12-16 14:12:49.260 +05:30] [INF] [1] Main: Web resources path: "/Applications/Jellyfin.app/Contents/Resources/jellyfin-web"
    [2024-12-16 14:12:49.260 +05:30] [INF] [1] Main: Application directory: "/Applications/Jellyfin.app/Contents/MacOS/"
    [2024-12-16 14:12:51.986 +05:30] [FTL] [1] Main: Error while starting server
    Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 11: 'database disk image is malformed'.
      at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)
      at Microsoft.Data.Sqlite.SqliteCommand.PrepareAndEnumerateStatements()+MoveNext()
      at Microsoft.Data.Sqlite.SqliteCommand.GetStatements()+MoveNext()
      at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()
      at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)
      at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader()
      at Microsoft.Data.Sqlite.SqliteCommand.ExecuteNonQuery()
      at Emby.Server.Implementations.Data.SqliteExtensions.Execute(SqliteConnection sqliteConnection, String commandText)
      at Emby.Server.Implementations.Data.BaseSqliteRepository.GetConnection(Boolean readOnly)
      at Emby.Server.Implementations.Data.BaseSqliteRepository.Initialize()
      at Emby.Server.Implementations.Data.SqliteItemRepository.Initialize()
      at Emby.Server.Implementations.ApplicationHost.InitializeServices()
      at Jellyfin.Server.Program.StartServer(IServerApplicationPaths appPaths, StartupOptions options, IConfiguration startupConfig)
    [2024-12-16 14:12:51.994 +05:30] [INF] [1] Main: Running query planner optimizations in the database... This might take a while
    System Configuration:
    Hardware Overview:
    • Model Name: iMac
    • Model Identifier: iMac18,2
    • Processor Name: Quad-Core Intel Core i5
    • Processor Speed: 3 GHz
    • Number of Cores: 4
    • Memory: 32 GB
    Software Overview:
    • System Version: macOS Ventura 13.7.1 (22H221)
    • Kernel Version: Darwin 22.6.0
    • Secure Virtual Memory: Enabled
    • System Integrity Protection: Enabled
    • Time since boot: 1 hour, 22 minutes
    Plugings Installed:
    • [b]Artwork_1.0.0.0[/b]
    • [b]Bookshelf_11.0.0.0[/b]
    • [b]Bookshelf_12.0.0.0[/b]
    • [b]Cover Art Archive_8.0.0.0[/b]
    • [b]InfuseSync_1.5.0.0[/b]
    • [b]LrcLib_2.0.0.0[/b]
    • [b]Merge Versions_10.9.1.1[/b]
    • [b]OPDS_6.0.0.0[/b]
    • [b]Open Subtitles_20.0.0.0[/b]
    • [b]Session Cleaner_4.0.0.0[/b]
    • [b]Subtitle Extract_4.0.0.0[/b]
    • [b]TMDb Box Sets_11.0.0.0[/b]
    • [b]TVmaze_11.0.0.0[/b]
    • [b]Transcode Killer_3.0.0.0[/b]
    2024-12-16, 01:13 PM
    Go to ~/.config/jellyfin/plugins and delete the folders for InfuseSync. Then try starting Jellyfin again. We are verifying whether it is the jellyfin database that is corrupt or the InfuseSync plugin's database that is corrupt. Deleting the plugin folder does not delete the Infuse database, which is in ~/.config/jellyfin/data.
