    Jellyfin Forum Support Troubleshooting Jellyfin not starting up after upgrading to 10.9.0
    Flaring0281
    Country:Netherlands
    #11
    2024-05-13, 02:50 PM
    For anyone else with the same problem, it seems that this entry in the network.xml file was the culprit:
    <LocalNetworkAddresses>
    <string>192.168.2.180</string>
    </LocalNetworkAddresses>
    Not sure why this stopped working in v10.9, but replacing it with <LocalNetworkAddresses /> fixed it for me.
    #12
    2024-05-13, 03:06 PM (This post was last modified: 2024-05-13, 03:07 PM by Efficient_Good_5784. Edited 1 time in total.)
    (2024-05-13, 02:50 PM)Flaring0281 Wrote: For anyone else with the same problem, it seems that this entry in the network.xml file was the culprit:
    I'm not understanding the last part. Do you mean the replacement would be like this?:
    I'm confused as that doesn't follow the way to end the tags.
    Flaring0281
    Country:Netherlands
    #13
    2024-05-13, 04:30 PM
    No I mean that replacing the entirety of
    With just <LocalNetworkAddresses /> fixed it for me.
    #14
    2024-05-13, 04:43 PM
    Ok, thanks for explaining.
    Duvel
    Threads: 7
    Country:Belgium
    #15
    2024-05-13, 05:02 PM (This post was last modified: 2024-05-13, 05:31 PM by Duvel. Edited 3 times in total.)
    More or less the same issue : Jellyfin is unresponsive on local http://ip:port after upgrading docker image from 10.8.13 to 10.9.1
    I notably notice a lot of pluggin errors in the logs
    [2024-05-13 18:18:04.000 +02:00] [INF] Running query planner optimizations in the database... This might take a while
    [2024-05-13 18:18:04.218 +02:00] [INF] Disposing "CoreAppHost"
    [2024-05-13 18:18:04.246 +02:00] [INF] Disposing "DlnaEntryPoint"
    [2024-05-13 18:18:04.292 +02:00] [INF] Disposing PlayToManager
    [2024-05-13 18:18:04.325 +02:00] [INF] Disposing DeviceDiscovery
    [2024-05-13 18:18:04.382 +02:00] [INF] Disposing SsdpCommunicationsServer
    [2024-05-13 18:18:04.382 +02:00] [INF] "SsdpCommunicationsServer" disposing _BroadcastListenSocket
    [2024-05-13 18:18:04.694 +02:00] [INF] "SsdpCommunicationsServer" Disposing 2 sendSockets
    [2024-05-13 18:18:04.694 +02:00] [INF] "SsdpCommunicationsServer" disposing sendSocket from "0.0.0.0"
    [2024-05-13 18:18:04.694 +02:00] [INF] "SsdpCommunicationsServer" disposing sendSocket from "127.0.0.1"
    [2024-05-13 18:18:04.694 +02:00] [INF] Disposing "SchedulesDirect"
    [2024-05-13 18:18:04.695 +02:00] [INF] Disposing "LibraryChangedNotifier"
    [2024-05-13 18:18:04.719 +02:00] [INF] Disposing "UdpServerEntryPoint"
    [2024-05-13 18:18:04.722 +02:00] [INF] Disposing "UserDataChangeNotifier"
    [2024-05-13 18:18:04.732 +02:00] [INF] Disposing "EntryPoint"
    [2024-05-13 18:18:04.733 +02:00] [INF] Disposing "NotificationEntryPoint"
    [2024-05-13 18:18:04.788 +02:00] [INF] Disposing "LibraryMonitorStartup"
    [2024-05-13 18:18:04.788 +02:00] [INF] Disposing "DeviceAccessEntryPoint"
    [2024-05-13 18:18:04.797 +02:00] [INF] Disposing "TvdbMissingEpisodeProvider"
    [2024-05-13 18:18:04.797 +02:00] [INF] Disposing "EmbyTV"
    [2024-05-13 18:18:04.918 +02:00] [INF] Disposing "RecordingNotifier"
    [2024-05-13 18:18:04.939 +02:00] [INF] Disposing "MusicBrainzAlbumProvider"
    [2024-05-13 18:18:04.954 +02:00] [INF] Disposing "TMDbBoxSetManager"
    [2024-05-13 18:18:04.954 +02:00] [INF] Disposing "EventMonitorEntryPoint"
    [2024-05-13 18:18:04.982 +02:00] [INF] Disposing "ExternalPortForwarding"
    [2024-05-13 18:18:04.983 +02:00] [INF] Stopping NAT discovery
    [2024-05-13 18:18:05.473 +02:00] [INF] WS "109.133.232.254" closed
    [2024-05-13 18:20:55.205 +02:00] [INF] Jellyfin version: "10.9.1"
    [2024-05-13 18:20:55.259 +02:00] [INF] Environment Variables: ["[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]"]
    [2024-05-13 18:20:55.261 +02:00] [INF] Arguments: ["/jellyfin/jellyfin.dll", "--ffmpeg", "/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    [2024-05-13 18:20:55.262 +02:00] [INF] Operating system: "Debian GNU/Linux 12 (bookworm)"
    [2024-05-13 18:20:55.262 +02:00] [INF] Architecture: X64
    [2024-05-13 18:20:55.263 +02:00] [INF] 64-Bit Process: True
    [2024-05-13 18:20:55.263 +02:00] [INF] User Interactive: True
    [2024-05-13 18:20:55.263 +02:00] [INF] Processor count: 4
    [2024-05-13 18:20:55.263 +02:00] [INF] Program data path: "/var/lib/jellyfin"
    [2024-05-13 18:20:55.263 +02:00] [INF] Log directory path: "/var/log/jellyfin"
    [2024-05-13 18:20:55.263 +02:00] [INF] Config directory path: "/etc/jellyfin"
    [2024-05-13 18:20:55.263 +02:00] [INF] Cache path: "/var/cache/jellyfin"
    [2024-05-13 18:20:55.263 +02:00] [INF] Web resources path: "/jellyfin/jellyfin-web"
    [2024-05-13 18:20:55.263 +02:00] [INF] Application directory: "/jellyfin/"
    [2024-05-13 18:20:55.412 +02:00] [INF] Applying migration '"MigrateMusicBrainzTimeout"'
    [2024-05-13 18:20:55.447 +02:00] [INF] Migration '"MigrateMusicBrainzTimeout"' applied successfully
    [2024-05-13 18:20:55.448 +02:00] [INF] Applying migration '"MigrateNetworkConfiguration"'
    [2024-05-13 18:20:55.468 +02:00] [INF] Migration '"MigrateNetworkConfiguration"' applied successfully
    [2024-05-13 18:20:55.482 +02:00] [INF] Setting cache path: "/var/cache/jellyfin"
    [2024-05-13 18:20:55.561 +02:00] [INF] Loading assemblies
    [2024-05-13 18:20:55.593 +02:00] [INF] Loaded assembly "Jellyfin.Plugin.AniDB, Version=7.0.0.0, Culture=neutral, PublicKeyToken=null" from "/var/lib/jellyfin/plugins/AniDB_7.0.0.0/Jellyfin.Plugin.AniDB.dll"
    [2024-05-13 18:20:55.597 +02:00] [ERR] Failed to load assembly "/var/lib/jellyfin/plugins/Bookshelf_10.0.0.0/Jellyfin.Plugin.Bookshelf.dll". This error occurs when a plugin references an incompatible version of one of the shared libraries. Disabling plugin
    System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types.
    Could not load type 'MediaBrowser.Common.Plugins.IPluginServiceRegistrator' from assembly 'MediaBrowser.Common, Version=10.9.1.0, Culture=neutral, PublicKeyToken=null'.
      at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
      at System.Reflection.RuntimeModule.GetTypes()
      at Emby.Server.Implementations.Plugins.PluginManager.LoadAssemblies()+MoveNext()
    System.TypeLoadException: Could not load type 'MediaBrowser.Common.Plugins.IPluginServiceRegistrator' from assembly 'MediaBrowser.Common, Version=10.9.1.0, Culture=neutral, PublicKeyToken=null'.
    [2024-05-13 18:20:55.637 +02:00] [INF] Loaded assembly "BouncyCastle.Crypto, Version=1.8.8.0, Culture=neutral, PublicKeyToken=0e99375e54769942" from "/var/lib/jellyfin/plugins/Email_9.0.0.0/BouncyCastle.Crypto.dll"
    [2024-05-13 18:20:55.645 +02:00] [INF] Loaded assembly "MimeKit, Version=2.10.0.0, Culture=neutral, PublicKeyToken=bede1c8a46c66814" from "/var/lib/jellyfin/plugins/Email_9.0.0.0/MimeKit.dll"
    [2024-05-13 18:20:55.658 +02:00] [INF] Loaded assembly "MailKit, Version=2.10.0.0, Culture=neutral, PublicKeyToken=4e064fe7c44a8f1b" from "/var/lib/jellyfin/plugins/Email_9.0.0.0/MailKit.dll"
    [2024-05-13 18:20:55.658 +02:00] [ERR] Failed to load assembly "/var/lib/jellyfin/plugins/Email_9.0.0.0/MediaBrowser.Plugins.SmtpNotifications.dll". This error occurs when a plugin references an incompatible version of one of the shared libraries. Disabling plugin
    Could not load type 'MediaBrowser.Controller.Notifications.INotificationService' from assembly 'MediaBrowser.Controller, Version=10.9.1.0, Culture=neutral, PublicKeyToken=null'.
    System.TypeLoadException: Could not load type 'MediaBrowser.Controller.Notifications.INotificationService' from assembly 'MediaBrowser.Controller, Version=10.9.1.0, Culture=neutral, PublicKeyToken=null'.
    [2024-05-13 18:20:55.660 +02:00] [INF] Loaded assembly "Jellyfin.Plugin.Fanart, Version=10.0.0.0, Culture=neutral, PublicKeyToken=null" from "/var/lib/jellyfin/plugins/Fanart_10.0.0.0/Jellyfin.Plugin.Fanart.dll"
    [2024-05-13 18:20:55.667 +02:00] [INF] Loaded assembly "Novell.Directory.Ldap.NETStandard, Version=3.6.0.0, Culture=neutral, PublicKeyToken=510c34e9dec7f86f" from "/var/lib/jellyfin/plugins/LDAP Authentication_17.0.0.0/Novell.Directory.Ldap.NETStandard.dll"
    [2024-05-13 18:20:55.667 +02:00] [INF] Loaded assembly "LDAP-Auth, Version=17.0.0.0, Culture=neutral, PublicKeyToken=null" from "/var/lib/jellyfin/plugins/LDAP Authentication_17.0.0.0/LDAP-Auth.dll"
    [2024-05-13 18:20:55.668 +02:00] [ERR] Failed to load assembly "/var/lib/jellyfin/plugins/OPDS_4.0.0.0/Jellyfin.Plugin.Opds.dll". This error occurs when a plugin references an incompatible version of one of the shared libraries. Disabling plugin
    [2024-05-13 18:20:55.671 +02:00] [INF] Loaded assembly "Jellyfin.Plugin.OpenSubtitles, Version=19.0.0.0, Culture=neutral, PublicKeyToken=null" from "/var/lib/jellyfin/plugins/Open Subtitles_19.0.0.0/Jellyfin.Plugin.OpenSubtitles.dll"
    [2024-05-13 18:20:55.673 +02:00] [ERR] Failed to load assembly "/var/lib/jellyfin/plugins/Playback Reporting_13.0.0.0/Jellyfin.Plugin.PlaybackReporting.dll". This error occurs when a plugin references an incompatible version of one of the shared libraries. Disabling plugin
    Could not load type 'MediaBrowser.Controller.Plugins.IServerEntryPoint' from assembly 'MediaBrowser.Controller, Version=10.9.1.0, Culture=neutral, PublicKeyToken=null'.
    Could not load file or assembly 'SQLitePCL.pretty, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'. The system cannot find the file specified.
    System.TypeLoadException: Could not load type 'MediaBrowser.Controller.Plugins.IServerEntryPoint' from assembly 'MediaBrowser.Controller, Version=10.9.1.0, Culture=neutral, PublicKeyToken=null'.
    System.IO.FileNotFoundException: Could not load file or assembly 'SQLitePCL.pretty, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'. The system cannot find the file specified.
    File name: 'SQLitePCL.pretty, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'
    [2024-05-13 18:20:55.676 +02:00] [INF] Loaded assembly "Jellyfin.Plugin.Reports, Version=15.0.0.0, Culture=neutral, PublicKeyToken=null" from "/var/lib/jellyfin/plugins/Reports_15.0.0.0/Jellyfin.Plugin.Reports.dll"
    [2024-05-13 18:20:55.678 +02:00] [INF] Loaded assembly "Jellyfin.Plugin.SkinManager, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null" from "/var/lib/jellyfin/plugins/Skin Manager_2.0.1/Jellyfin.Plugin.SkinManager.dll"
    [2024-05-13 18:20:55.681 +02:00] [ERR] Failed to load assembly "/var/lib/jellyfin/plugins/TheTVDB_10.0.0.0/Jellyfin.Plugin.Tvdb.dll". This error occurs when a plugin references an incompatible version of one of the shared libraries. Disabling plugin
    [2024-05-13 18:20:55.682 +02:00] [ERR] Failed to load assembly "/var/lib/jellyfin/plugins/TMDb Box Sets_10.0.0.0/Jellyfin.Plugin.TMDbBoxSets.dll". This error occurs when a plugin references an incompatible version of one of the shared libraries. Disabling plugin
    [2024-05-13 18:20:55.693 +02:00] [INF] Loaded assembly "Polly, Version=7.0.0.0, Culture=neutral, PublicKeyToken=c8a3ffc3f8f825cc" from "/var/lib/jellyfin/plugins/TVmaze_10.0.0.0/Polly.dll"
    [2024-05-13 18:20:55.695 +02:00] [INF] Loaded assembly "Flurl.Http, Version=3.0.1.0, Culture=neutral, PublicKeyToken=null" from "/var/lib/jellyfin/plugins/TVmaze_10.0.0.0/Flurl.Http.dll"
    [2024-05-13 18:20:55.696 +02:00] [INF] Loaded assembly "Flurl, Version=3.0.1.0, Culture=neutral, PublicKeyToken=null" from "/var/lib/jellyfin/plugins/TVmaze_10.0.0.0/Flurl.dll"
    [2024-05-13 18:20:55.697 +02:00] [INF] Loaded assembly "Jellyfin.Plugin.TvMaze, Version=10.0.0.0, Culture=neutral, PublicKeyToken=null" from "/var/lib/jellyfin/plugins/TVmaze_10.0.0.0/Jellyfin.Plugin.TvMaze.dll"
    [2024-05-13 18:20:55.697 +02:00] [INF] Loaded assembly "TvMaze.Api.Client, Version=0.1.72.0, Culture=neutral, PublicKeyToken=null" from "/var/lib/jellyfin/plugins/TVmaze_10.0.0.0/TvMaze.Api.Client.dll"
    [2024-05-13 18:20:55.747 +02:00] [INF] Defined LAN addresses: ["192.168.2.0/24", "192.168.1.0/24", "172.20.0.0/16", "172.22.0.0/16"]
    [2024-05-13 18:20:55.747 +02:00] [INF] Defined LAN exclusions: []
    [2024-05-13 18:20:55.747 +02:00] [INF] Using LAN addresses: ["192.168.2.0/24", "192.168.1.0/24", "172.20.0.0/16", "172.22.0.0/16"]
    [2024-05-13 18:20:55.750 +02:00] [INF] Using bind addresses: []
    [2024-05-13 18:20:55.750 +02:00] [INF] Remote IP filter is "Allowlist"
    [2024-05-13 18:20:55.750 +02:00] [INF] Filter list: []
    [2024-05-13 18:20:56.813 +02:00] [INF] There are pending EFCore migrations in the database. Applying... (This may take a while, do not stop Jellyfin)
    [2024-05-13 18:20:56.972 +02:00] [INF] EFCore migrations applied successfully
    [2024-05-13 18:21:06.717 +02:00] [INF] Loaded plugin: "AniDB" "7.0.0.0"
    [2024-05-13 18:21:06.719 +02:00] [INF] Loaded plugin: "Fanart" "10.0.0.0"
    [2024-05-13 18:21:06.719 +02:00] [INF] Loaded plugin: "LDAP-Auth" "17.0.0.0"
    [2024-05-13 18:21:06.720 +02:00] [INF] Loaded plugin: "Open Subtitles" "19.0.0.0"
    [2024-05-13 18:21:06.721 +02:00] [INF] Loaded plugin: "Reports" "15.0.0.0"
    [2024-05-13 18:21:06.721 +02:00] [INF] Loaded plugin: "Skin Manager" "2.0.1"
    [2024-05-13 18:21:06.722 +02:00] [INF] Loaded plugin: "TVmaze" "10.0.0.0"
    [2024-05-13 18:21:06.722 +02:00] [INF] Loaded plugin: "TMDb" "10.9.1.0"
    [2024-05-13 18:21:06.723 +02:00] [INF] Loaded plugin: "Studio Images" "10.9.1.0"
    [2024-05-13 18:21:06.723 +02:00] [INF] Loaded plugin: "OMDb" "10.9.1.0"
    [2024-05-13 18:21:06.733 +02:00] [INF] Loaded plugin: "MusicBrainz" "10.9.1.0"
    [2024-05-13 18:21:06.733 +02:00] [INF] Loaded plugin: "AudioDB" "10.9.1.0"
    [2024-05-13 18:21:06.776 +02:00] [INF] Applying migration '"FixPlaylistOwner"'
    [2024-05-13 18:21:07.081 +02:00] [INF] Migration '"FixPlaylistOwner"' applied successfully
    [2024-05-13 18:21:07.082 +02:00] [INF] Applying migration '"MigrateRatingLevels"'
    [2024-05-13 18:21:07.337 +02:00] [INF] Library database backed up to "/var/lib/jellyfin/data/library.db.bak1"
    [2024-05-13 18:21:07.337 +02:00] [INF] Recalculating parental rating levels based on rating string.
    [2024-05-13 18:21:10.190 +02:00] [INF] Migration '"MigrateRatingLevels"' applied successfully
    [2024-05-13 18:21:10.192 +02:00] [INF] Applying migration '"AddDefaultCastReceivers"'
    [2024-05-13 18:21:10.192 +02:00] [INF] Saving system configuration
    [2024-05-13 18:21:10.193 +02:00] [INF] Setting cache path: "/var/cache/jellyfin"
    [2024-05-13 18:21:10.194 +02:00] [INF] Migration '"AddDefaultCastReceivers"' applied successfully
    [2024-05-13 18:21:10.195 +02:00] [INF] Applying migration '"UpdateDefaultPluginRepository10.9"'
    [2024-05-13 18:21:10.195 +02:00] [INF] Saving system configuration
    [2024-05-13 18:21:10.196 +02:00] [INF] Setting cache path: "/var/cache/jellyfin"
    [2024-05-13 18:21:10.196 +02:00] [INF] Migration '"UpdateDefaultPluginRepository10.9"' applied successfully
    [2024-05-13 18:21:10.206 +02:00] [WRN] Using an in-memory repository. Keys will not be persisted to storage.
    [2024-05-13 18:21:10.206 +02:00] [WRN] Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
    [2024-05-13 18:21:10.227 +02:00] [WRN] No XML encryptor configured. Key {efce069b-de66-498c-b39f-afa8195e26d9} may be persisted to storage in unencrypted form.
    [2024-05-13 18:21:10.269 +02:00] [INF] Starting NAT discovery
    [2024-05-13 18:21:10.704 +02:00] [WRN] The WebRootPath was not found: "/wwwroot". Static files may be unavailable.
    [2024-05-13 18:21:10.727 +02:00] [INF] Running startup tasks
    [2024-05-13 18:21:10.738 +02:00] [INF] Daily trigger for "Générer des images Trickplay" set to fire at 2024-05-14 03:00:00.000 +02:00, which is 08:38:49.2613059 from now.
    [2024-05-13 18:21:10.747 +02:00] [INF] Daily trigger for "Extraire les images de chapitre" set to fire at 2024-05-14 02:00:00.000 +02:00, which is 07:38:49.2525864 from now.
    [2024-05-13 18:21:10.781 +02:00] [INF] Found ffmpeg version "6.0.1"
    [2024-05-13 18:21:10.824 +02:00] [INF] Available "decoders": ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
    [2024-05-13 18:21:10.843 +02:00] [INF] Available "encoders": ["libsvtav1", "av1_nvenc", "av1_qsv", "av1_amf", "av1_vaapi", "libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mjpeg_qsv", "mjpeg_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "alac", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
    [2024-05-13 18:21:10.870 +02:00] [INF] Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "libplacebo", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_vulkan", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "scale_vulkan", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
    [2024-05-13 18:21:10.941 +02:00] [INF] Watching directory "/media/plex/movies"
    [2024-05-13 18:21:10.974 +02:00] [INF] Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
    [2024-05-13 18:21:11.168 +02:00] [INF] Watching directory "/media/plex/musique"
    [2024-05-13 18:21:11.178 +02:00] [INF] Watching directory "/media/plex/nanards"
    [2024-05-13 18:21:11.203 +02:00] [INF] FFmpeg: "/usr/lib/jellyfin-ffmpeg/ffmpeg"
    [2024-05-13 18:21:11.204 +02:00] [INF] ServerId: "2961cac6981a4cf7bdba123798d8bcbc"
    [2024-05-13 18:21:11.204 +02:00] [INF] Core startup complete
    [2024-05-13 18:21:11.204 +02:00] [INF] Startup complete 0:00:16.211421
    [2024-05-13 18:21:12.314 +02:00] [INF] Watching directory "/media/plex/da/films"
    [2024-05-13 18:21:12.316 +02:00] [INF] Watching directory "/media/plex/spectacles"
    [2024-05-13 18:21:13.784 +02:00] [INF] Item in "Conan the Barbarian Collection" cannot be found at "/media/plex/movies/Conan the Destroyer (1984)/Conan le Destructeur.avi"
    [2024-05-13 18:21:13.787 +02:00] [INF] Item in "Captain Marvel Collection" cannot be found at "/media/plex/movies/The Marvels (2023) [imdb-tt10676048]/The Marvels (2023) [imdb-tt10676048] WEBRip-1080p.mkv"
    [2024-05-13 18:21:13.789 +02:00] [INF] Item in "Trainspotting Collection" cannot be found at "/media/plex/movies/Trainspotting (1996)/Trainspotting.avi"
    [2024-05-13 18:21:13.790 +02:00] [INF] Item in "The Twilight Collection" cannot be found at "/media/plex/movies/The Twilight Saga - Breaking Dawn - Part 1 (2011)/Twilight-chapitre 4- Revelation Part 1.avi"
    [2024-05-13 18:21:13.790 +02:00] [INF] Item in "The Twilight Collection" cannot be found at "/media/plex/movies/The Twilight Saga - Breaking Dawn - Part 2 (2012)/Twilight-chapitre 4- Revelation Part 2.avi"
    After that a lot of [INF], and then
    [2024-05-13 18:21:13.807 +02:00] [INF] "Nettoyer les collections et les listes de lecture" Completed after 0 minute(s) and 0 seconds
    [2024-05-13 18:21:14.306 +02:00] [WRN] Unable to find linked item at path "/media/plex/movies/Conan the Destroyer (1984)/Conan le Destructeur.avi"
    [2024-05-13 18:21:14.317 +02:00] [ERR] Error in metadata saver
    System.IO.IOException: The process cannot access the file '/var/lib/jellyfin/data/collections/Conan the Barbarian Collection [boxset]/collection.xml' because it is being used by another process.
      at Microsoft.Win32.SafeHandles.SafeFileHandle.Init(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize, Int64& fileLength, UnixFileMode& filePermissions)
      at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize, UnixFileMode openPermissions, Int64& fileLength, UnixFileMode& filePermissions, Boolean failForSymlink, Boolean& wasSymlink, Func`4 createOpenException)
      at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize, Nullable`1 unixCreateMode)
      at System.IO.FileStream..ctor(String path, FileStreamOptions options)
      at MediaBrowser.LocalMetadata.Savers.BaseXmlSaver.SaveAsync(BaseItem item, CancellationToken cancellationToken)
      at MediaBrowser.Providers.Manager.ProviderManager.SaveMetadataAsync(BaseItem item, ItemUpdateType updateType, IEnumerable`1 savers)
    [2024-05-13 18:21:14.985 +02:00] [INF] Watching directory "/media/plex/docus"
    [2024-05-13 18:21:15.461 +02:00] [INF] Watching directory "/media/plex/series_VO"
    [2024-05-13 18:21:16.299 +02:00] [INF] Watching directory "/media/plex/da_tele"
    [2024-05-13 18:21:17.572 +02:00] [INF] Plugin "installed": "AniDB" "8.0.0.0"
    [2024-05-13 18:21:17.702 +02:00] [INF] App needs to be restarted.
    [2024-05-13 18:21:17.901 +02:00] [INF] Plugin "installed": "Bookshelf" "11.0.0.0"
    [2024-05-13 18:21:17.922 +02:00] [INF] App needs to be restarted.
    [2024-05-13 18:21:18.195 +02:00] [INF] Plugin "installed": "Fanart" "11.0.0.0"
    [2024-05-13 18:21:18.210 +02:00] [INF] App needs to be restarted.
    [2024-05-13 18:21:18.577 +02:00] [INF] Plugin "installed": "OPDS" "5.0.0.0"
    [2024-05-13 18:21:18.593 +02:00] [INF] App needs to be restarted.
    [2024-05-13 18:21:18.862 +02:00] [INF] Plugin "installed": "Open Subtitles" "20.0.0.0"
    [2024-05-13 18:21:18.884 +02:00] [INF] App needs to be restarted.
    [2024-05-13 18:21:19.171 +02:00] [INF] Plugin "installed": "Playback Reporting" "14.0.0.0"
    [2024-05-13 18:21:19.193 +02:00] [INF] App needs to be restarted.
    [2024-05-13 18:21:19.629 +02:00] [INF] Plugin "installed": "Reports" "17.0.0.0"
    [2024-05-13 18:21:19.648 +02:00] [INF] App needs to be restarted.
    [2024-05-13 18:21:19.898 +02:00] [INF] Plugin "installed": "TheTVDB" "11.0.0.0"
    [2024-05-13 18:21:19.907 +02:00] [INF] App needs to be restarted.
    [2024-05-13 18:21:19.919 +02:00] [INF] Watching directory "/media/plex/books"
    [2024-05-13 18:21:20.041 +02:00] [INF] Plugin "installed": "TMDb Box Sets" "11.0.0.0"
    [2024-05-13 18:21:20.047 +02:00] [INF] App needs to be restarted.
    [2024-05-13 18:21:20.322 +02:00] [INF] Plugin "installed": "TVmaze" "11.0.0.0"
    [2024-05-13 18:21:20.333 +02:00] [INF] App needs to be restarted.
    [2024-05-13 18:21:20.333 +02:00] [INF] "Mettre à jour les extensions" Completed after 0 minute(s) and 5 seconds
    [2024-05-13 18:21:21.611 +02:00] [INF] Watching directory "/media/plex/series"
    ANd then nothing. I let it like that  during 20 minutes and the server was still unreachable so I decided to stop it in order to rollback (I had a backup)
    [2024-05-13 18:44:18.192 +02:00] [INF] Sending shutdown notifications
    [2024-05-13 18:44:18.205 +02:00] [INF] Stopping NAT discovery
    [2024-05-13 18:44:18.210 +02:00] [INF] Running query planner optimizations in the database... This might take a while
    [2024-05-13 18:44:18.220 +02:00] [INF] Stopping directory watching for path "/media/plex/da/films"
    [2024-05-13 18:44:18.221 +02:00] [INF] Stopping directory watching for path "/media/plex/books"
    [2024-05-13 18:44:18.231 +02:00] [INF] Stopping directory watching for path "/media/plex/series_VO"
    [2024-05-13 18:44:18.231 +02:00] [INF] Stopping directory watching for path "/media/plex/da_tele"
    [2024-05-13 18:44:18.232 +02:00] [INF] Stopping directory watching for path "/media/plex/movies"
    [2024-05-13 18:44:18.237 +02:00] [INF] Stopping directory watching for path "/media/plex/spectacles"
    [2024-05-13 18:44:18.237 +02:00] [INF] Stopping directory watching for path "/media/plex/nanards"
    [2024-05-13 18:44:18.237 +02:00] [INF] Stopping directory watching for path "/media/plex/musique"
    [2024-05-13 18:44:18.239 +02:00] [INF] Stopping directory watching for path "/media/plex/docus"
    [2024-05-13 18:44:18.240 +02:00] [INF] Stopping directory watching for path "/media/plex/series"
    [2024-05-13 18:44:18.245 +02:00] [INF] Disposing "CoreAppHost"
    [2024-05-13 18:44:18.245 +02:00] [INF] Disposing "MusicBrainzArtistProvider"
    [2024-05-13 18:44:18.245 +02:00] [INF] Disposing "MusicBrainzAlbumProvider"
    [2024-05-13 18:44:18.246 +02:00] [INF] Disposing "DotNetRuntimeStatsCollector"
    [2024-05-13 18:44:18.246 +02:00] [INF] Disposing "PluginManager"
    I thus restarted my image 10.8.13 until I have an explanation, fix or guideline
    On a side note, this IMHO is an horrible idea:
    Unsure if its new but I never noticed french translations in mùy logs before. It is way better for all of us to output all logs in english and not their translations
    Duvel
    Threads: 7
    Country:Belgium
    #16
    2024-05-13, 05:21 PM (This post was last modified: 2024-05-13, 05:23 PM by Duvel. Edited 2 times in total.)
    regarding the tip from Flaring, I indeed have this in my Network.xml
      <LocalNetworkSubnets>
        <string>192.168.2.0/24</string>
        <string>192.168.1.0/24</string>
        <string>172.20.0.0/16</string>
        <string>172.22.0.0/16</string>
      </LocalNetworkSubnets>
        <string>192.168.2.4</string>
      <KnownProxies>
        <string>192.168.2.10</string>
      </KnownProxies>
    Am I supposed  to get rid of the LocalNetworkAddresses part as suggested ?? I dont see the same errors he had in my logs so unsure if it is the same root cause on my side
    I also backuped the broken 10.9.1 folder prior to rollback so i can start from it again to try but I dont want to have disruptions for nothing as I currently have users watching stuff on the 10.8.13, So I prefer to wait for some dev advices  Smiling-face
    Sarinz
    Country:India
    #17
    2024-05-14, 05:27 PM
    (2024-05-13, 12:06 PM)TheDreadPirate Wrote: @Sarinz Do you have a backup from 10.8.13?
    I don't have 10.8.13 one but I have an image before I moved it to docker, I'm planning to mount that image, copy the configs, metadata,etc and set docker image tag to 10.8.13,
    hopefully, it should get me out of current predicament. I really want to try out the new version. Anyways thanks for the guidance Smiling-face
    2024-05-14, 05:53 PM
    You cannot use non-docker jellyfin data and configs with a docker config.
    riddertommie
    Country:Netherlands
    #19
    2024-05-16, 11:01 AM
    Hi, sorry for my late reaction, busy week.
    I deleted config/config/network.xml and after a reboot it was again ok. As soon if i change the settings of the local networks and reboot. it is stuck again.
    Question for those who have also done this (delete network.xml) i now have a problem that the jellyfin kodi plugin does not sync automatic if i ended a episode , recognizable?
    @Flaring0281, do you still want my log file? log file?
    Duvel
    Threads: 7
    Country:Belgium
    #20
    2024-05-16, 11:20 AM
    is there anything planned to fix that network config issue ?
