    Jellyfin Forum Support Troubleshooting Jellyfin not starting up after upgrading to 10.9.0
    Pages (3): « Previous 1 2 3
    2024-05-16, 12:59 PM
    This PR MIGHT be related to your issue.
    https://github.com/jellyfin/jellyfin/pull/11587
    Not entirely sure.
    gingerbreadassassin
    2024-05-23, 09:34 PM
    (2024-05-12, 10:24 PM)Sarinz Wrote: I don't know what to do.. I have tried setting the image version to 10.8.13, but that gave many errors, It seemed that 10.9.0 update have changed a lot of things.
    This thread from post #3 and on basically has nothing to do with the OP's problem. I ran into this issue running jellyfin via truecharts and a failed upgrade via heavyscript from 10.8.13 -> 10.9.3. The clue is this line:
    [21:41:36] [INF] Library database backed up to /var/lib/jellyfin/data/library.db.bak40
    If you look in the /var/lib/jellyfin/data/ directory, you'll see a bunch of library.db.bak* files, though I believe the corruption (if it really is corrupt and not just a failure in the migration logic or I attempted too great a version jump) is actually in the original library.db. I solved my issue by moving the library.db* files to a backup directory. Jellyfin was then able to start, but it did have to rebuild the library. Mine did this automatically, and was done in less than 5 minutes.
    Here's roughly the commands I used:
    $ cd /var/lib/jellyfin/data
    $ mkdir librarybak
    $ mv library.db* librarybak/
    Hope others find this useful.
