    Jellyfin Forum Support Troubleshooting Jellyfin Tone Mapping Problems
    Jellyfin can have some strange tone mapping things happen
    therealgamer9982
    2024-09-13, 02:40 PM
    (2024-09-12, 08:48 PM)TheDreadPirate Wrote: @nyanmisaka - Do you have any ideas?
    Here is a log from today, maybe it will reveal something?
    https://pastebin.com/rMShexS2
    nyanmisaka
    #22
    2024-09-13, 03:02 PM
    Quote: vainfo: Driver version: Mesa Gallium driver 24.0.9 for AMD Radeon RX 6700 XT (radeonsi, navi22, LLVM 15.0.7, DRM 3.42, 5.15.0-119-generic)
    IIRC some distro's older amdgpu firmware may cause decoding issues on RDNA2.
    Is there any chance to update the firmware and update the linux kernel to 6.1/6.6 LTS?
    therealgamer9982
    2024-09-13, 03:06 PM
    Currently I am on Linux Mint 21.3, and I also don't really know how to do that. However, I would be willing to run the commands once I get back from my trip.
    2024-09-13, 03:19 PM (This post was last modified: 2024-09-13, 03:20 PM by TheDreadPirate. Edited 1 time in total.)
    You could also upgrade your install to Mint 22, which would upgrade the kernel and AMD firmware.
    https://blog.linuxmint.com/?p=4732
    therealgamer9982
    2024-09-13, 05:34 PM (This post was last modified: 2024-09-13, 05:34 PM by therealgamer9982.)
    (2024-09-13, 03:19 PM)TheDreadPirate Wrote: You could also upgrade your install to Mint 22, which would upgrade the kernel and AMD firmware.
    Will upgrading to LM 22, cause any sort of problems that I should know of?
    2024-09-13, 05:42 PM
    Keep in mind that upgrading from 21.3 to 22 is pretty much "apt upgrade+++". It's not like upgrading Windows where it is almost completely overhauling and replacing everything. Linux upgrades are mostly just upgrading versions of packages you already have installed.
    I updated from Ubuntu 22.04 to 24.04 seamlessly earlier this year. Took less than 30 minutes, IIRC.
    therealgamer9982
    2024-09-14, 06:33 PM
    (2024-09-13, 05:42 PM)TheDreadPirate Wrote: Keep in mind that upgrading from 21.3 to 22 is pretty much "apt upgrade+++".  It's not like upgrading Windows where it is almost completely overhauling and replacing everything.  Linux upgrades are mostly just upgrading versions of packages you already have installed.
    Hey, so I was looking on the website on what GPUs you guys recommend, and it says AMD is not recommended. Why is that?
    2024-09-14, 07:09 PM
    Primarily quality. And especially for pre-RDNA GPU inconsistent performance and codec support between models.
    therealgamer9982
    2024-09-15, 09:32 PM
    (2024-09-14, 07:09 PM)TheDreadPirate Wrote: Primarily quality.  And especially for pre-RDNA GPU inconsistent performance and codec support between models.
    So, here we are again. Now the transcoding just dosent want to work again. (Mind you, for some reason, I had to re-install jellyfin so that was strange)
    Transcode Log: https://pastebin.com/75jPpZ03
    Reg Log: https://pastebin.com/bhX1B5kU
    therealgamer9982
    2024-09-15, 11:07 PM (This post was last modified: 2024-09-15, 11:27 PM by therealgamer9982. Edited 1 time in total.)
    I am an idiot. I forgot to enable tone mapping.
    But now we are back to it glitching!
