    Jellyfin Forum Support Troubleshooting JF not going to LDAP for login
    fliberdygibits
    Threads: 12
    2024-01-07, 11:05 PM
    I've had LDAP setup thru authentik for a couple of weeks and it's worked fine. I'm noticing now however that JF isn't even trying to connect to the ldap server when I attempt a login even though all the tests in the ldap plugin come back successful.  I think following is the log showing where it's not connecting to ldap but I can grab a bigger section of logs if needed:
    https://pastebin.com/Sf8gzCKH
    The user I'm trying is in fact set to ldap-authentication.  I've created new test users in both authentik and jellyfin and it only ever authenticates against the local user accounts.
    JF 10.8.13 running in Docker
    fliberdygibits
    Threads: 12
    2024-01-07, 11:16 PM
    Soon as I posted I think I found the issue but I can't see how to delete my post.
    2024-01-08, 12:18 AM
    Instead of deleting the post, describe your solution for other users that have a similar problem.
    fliberdygibits
    Threads: 12
    2024-01-08, 12:30 AM
    (2024-01-08, 12:18 AM)TheDreadPirate Wrote: Instead of deleting the post, describe your solution for other users that have a similar problem.
    Sorry, my solution was don't be dumbSmiling-face
    I thought I restarted a container but I didn't....  I stopped it  I just can't read apparently.  Need more coffee.
    flash
    2024-03-30, 03:47 PM
    Hey, i saw your forum post mentioning you had authentik LDAP working with jellyfin. i was wondering if you could share you're setup config. I think I've been through every guide online but unsuccessful. My goal is to use authentik in front of my reverse proxy as middleware for my externally exposed web apps. And specifically for jellyfin to be able to work with smart tv clients where the LDAP comes in.
    I'm using traefik for reverse proxy in addition to authentik LDAP for jellyfin. I've been trying to get it to work but jellyfin has been unable to connect with the LDAP provider for some reason. and was hoping i could see a working config to see if i can narrow down what is going wrong.
    Thanks!
