    Jellyfin Forum Support General Questions Need help With Disabling Youtube Trailers
    i'm looking for disabling youtube trailers in jellyfin-web/config.json but the line "plugins/youtubePlayer/plugin" no where to befound
    Tom
    2023-12-12, 06:59 PM (This post was last modified: 2023-12-12, 07:04 PM by Tom. Edited 1 time in total.)
    i'm looking for disabling youtube trailers but so far no luck this is the instructions I followed. here is the link https://jellyfin.org/docs/general/client...e-trailers
    Quote:By default, Jellyfin Web includes functionality to auto-load movie trailers from YouTube. This functionality is disabled within Jellyfin by default, but the resources are included in the Web config to make enabling the feature easy.
    To disable it, edit config.json and remove the line:
    in the plugins section.
    but I can't find the line "plugins/youtubePlayer/plugin" in jellyfin-web/config.json
    [Image: shot.png]
    Maybe someone know how i can solved this issue?
    Tom
    2023-12-12, 07:05 PM
    Nevermind I solved it
