    Jellyfin Forum Off Topic General Discussion Newbie in need of help for backup
    pol77
    2024-06-18, 07:31 PM
    Changed config to this:
    version: "3.9"
        image: jellyfin/jellyfin
        container_name: PolFlix
        user: 1000:1000
        network_mode: "host"
    devices:
        - /dev/nvidia0:/dev/nvidia0
        - /dev/nvidiactl:/dev/nvidiactl
          /dev/nvidia-uvm:/dev/nvidia-uvm
    environment:
          - VERSION=docker
          - PATH=/usr/local/cuda/bin:/usr/local/cuda/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
          - NVIDIA_VISIBLE_DEVICES=all
          - NVIDIA_DRIVER_CAPABILITIES=all
    ports:
          - 32666:8096
          - 32667:8920
        - /Container/jellyfin/config:/config
        - /Container/jellyfin/cache:/cache
        - /Storage/Movies:/Movies:ro
    deploy:
          resources:
            reservations:
              devices:
                - driver: nvidia
                  count: all
                  capabilities:
                    - gpu
    restart: unless-stopped
    Same error message...
    Online
    2024-06-18, 07:40 PM
    If this is an accurate copy and paste, you missed a dash on this line.
    pol77
    2024-06-18, 07:45 PM (This post was last modified: 2024-06-18, 07:47 PM by pol77. Edited 1 time in total.)
    It is and thank you. Dash added but the validation error remains.
    I have also followed your advice and created an account at the qnap forum and posted the following:
    Hi all.
    First off, I'm a total newbie to qnas, linux, containers, yaml and Jellyfin. So, please excuse the ignorance.
    I have managed to sucessfully run a container for a jellyfin server, which I created using the GUI. I quickly realized that I need a GPU so I purchased and installed a Quadro P1000.
    I installed the driver in the App Center and set it to container station mode.
    When I run this command:
    /sbin/getcfg NVIDIA_GPU_DRV Install_Path -f /etc/config/qpkg.conf -d None
    In the QNAP SSH I get the response:
    /share/ZFS530_DATA/.qpkg/NVIDIA_GPU_DRV
    But if I run it in the container terminal, I get:
    bash: /sbin/getcfg: No such file or directory
    Is there a way to correct what is needed in my current Jellyfin container to get the GPU working in it?
    I have also tried the YAML approach.
    This is what I have so far:
    version: "3.9"[/color]
    [color=#0074d9]services:[/color]
    [color=#0074d9]  jellyfin:[/color]
    [color=#0074d9]    image: jellyfin/jellyfin[/color]
    [color=#0074d9]    container_name: PolFlix[/color]
    [color=#0074d9]    user: 1000:1000[/color]
    [color=#0074d9]    network_mode: "host"[/color]
    [color=#0074d9]devices:[/color]
    [color=#0074d9]    - /dev/nvidia0:/dev/nvidia0[/color]
    [color=#0074d9]    - /dev/nvidiactl:/dev/nvidiactl[/color]
    [color=#0074d9]      /dev/nvidia-uvm:/dev/nvidia-uvm[/color]
    [color=#0074d9]environment:[/color]
    [color=#0074d9]      - VERSION=docker[/color]
    [color=#0074d9]      - PATH=/usr/local/cuda/bin:/usr/local/cuda/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin[/color]
    [color=#0074d9]      - NVIDIA_VISIBLE_DEVICES=all[/color]
    [color=#0074d9]      - NVIDIA_DRIVER_CAPABILITIES=all[/color]
    [color=#0074d9]ports:[/color]
    [color=#0074d9]      - 32666:8096[/color]
    [color=#0074d9]      - 32667:8920[/color]
    [color=#0074d9]volumes:[/color]
    [color=#0074d9]    - /Container/jellyfin/config:/config[/color]
    [color=#0074d9]    - /Container/jellyfin/cache:/cache[/color]
    [color=#0074d9]    - /Storage/Movies:/Movies:ro[/color]
    [color=#0074d9]deploy:[/color]
    [color=#0074d9]      resources:[/color]
    [color=#0074d9]        reservations:[/color]
    [color=#0074d9]          devices:[/color]
    [color=#0074d9]            - driver: nvidia[/color]
    [color=#0074d9]              count: all[/color]
    [color=#0074d9]              capabilities:[/color]
    [color=#0074d9]                - gpu[/color]
    [color=#0074d9]restart: unless-stopped
    When I try to validate it, I get the error message:
    Invalid Compose YAML Code[/color]
    [color=#0074d9]validate compose config failed: operateApp action [convert] failed: exit status 15: volumes must be a mapping
    Any help with either getting my current container to utilize my GPU or creating a yaml code to make a new container that does, will be greatly appreciated.
    I will let you know if they have any helpful informaiton.
    pol77
    2024-06-19, 06:16 AM (This post was last modified: 2024-06-19, 10:43 AM by pol77. Edited 3 times in total.)
    Good morninig from London, captain...
    A few updates...
    - The QNAP Forum has not responded.
    - I am still unable to figure out what I'm doing wrong in the yaml configuration.
    - I have found the way to pass through the GPU to the container via GUI and nvidia-smi is reporting the driver in the container terminal.
    - When I enable hardware transcoding in Jellyfin, playback fails.
    - The logs show that Jellyfin requires nvidia driver version 520.56.06 or newer while QNAP is only offering up to 515.48.07.
    - I don't think there is a way to manually install a newer nvidia driver in the QNAP NAS.
    Thank you for your help so far, I've learned loads. I still want to understand yaml configuration and how to do it right but it seems that I will not be enjoying Jellyfin on my QNAP NAS, at least until they relese a newer driver.
    EDIT: Do you know if there is a container with an earlier version of Jellyfin that supports transcoding with my version of Nvidia driver?
    Online
    2024-06-19, 03:23 PM
    You'd have to run Jellyfin 10.8.X. The minimum Nvidia driver requirement was....470? Something like that. Low enough that the 515 driver available to you is fine.
    pol77
    2024-06-19, 03:47 PM
    Thank you...
    The million dollar question is, will my config backup from the latest version work on 10.0.X?
    Online
    2024-06-19, 04:10 PM
    Negatory. Upgrading to 10.9 is one way. If you have a backup pre-10.9 you could restore to that. Otherwise you're starting over.
    #28
    2024-06-19, 04:13 PM
    (2024-06-19, 03:47 PM)pol77 Wrote: Thank you...
    No (or maybe mostly not). There were changes to the database and other files for v10.9 that will break if reverting back to older releases.
    This isn't the first time something like this happened when a new Jellyfin version was released.
    pol77
    2024-06-19, 04:15 PM
    Huge bummer... I started on 10.9... New at this... A couple of days' work to prepare my metadata... Oh well...
    In the meantime, I tried 10.8.9AMD and did not work for me. I get this error message:
    Failed to create container "PolFlix-GPU-10.8.9AMD-dup". Error message: Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #1: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'legacy'
    nvidia-container-cli: initialization error: load library failed: libnvidia-ml.so.1: cannot open shared object file: no such file or directory: unknown
    I did not have this issue on the latest version, which loaded the nvidia files without a problem. Same settings.
    Is it something that must be done manually on 10.8.X and was automated on 10.9?
    pol77
    2024-06-19, 07:00 PM (This post was last modified: 2024-06-19, 07:42 PM by pol77. Edited 4 times in total.)
    OK guys... Major breakthrough and I'm very excited.
    The positive:
    I have resolved my composer issues - it was just formatting as I'm totally ignorant. I can now create the container fine.
    I have managed to script a container and it worked with version 10.8.9 and I did hardware transcoding with my GPU!!!
    The negative:
    I still have one issue to resolve. The drive mapping for config and cache to my shared folders in the NAS seem to be read only and the container starts and stops... The only way I was able to get it to run as above was to remove the cache and config mappings and allow it to create the folders inside the container, which is not ideal as it makes it very annoying to backup and restore.
    The ugly:
    Obviously, after all the issues re resolved I will have to spend a couple of very tedious days to fix my metadata (again).
    Here is my composer file:
    version: '3'
            image: jellyfin/jellyfin:10.8.9
            user: '1000:1000'
            network_mode: host
            environment:
                - VERSION=docker
                - LD_LIBRARY_PATH=/share/ZFS530_DATA/.qpkg/NVIDIA_GPU_DRV/usr:/usr/local/nvidia/lib
            ports:
                - '32666:8096'
                - '32667:8920'
                - '/share/Container/jellyfin/config:/config'
                - '/share/Container/jellyfin/cache:/cache'
                - '/share/Storage/Movies:/Movies:ro'
                - '/opt/NVIDIA_GPU_DRV/usr:/usr/local/nvidia:ro'
            devices:
                - '/dev/nvidia0:/dev/nvidia0'
                - '/dev/nvidiactl:/dev/nvidiactl'
                - '/dev/nvidia-uvm:/dev/nvidia-uvm'
    If you guys can see why the created cache and config folders seem to be read only I would be obliged. My buess is that the mapping needs to be a bind, but I don't know the code for that. It worked as a bind when I was doing it through th eGUI.
    Edit:
    FOUND IT.
    This is the code that worked.
    version: '3'
            user: '1000:1000'
            network_mode: host
            environment:
                - VERSION=docker
            ports:
                - '32666:8096'
                - '32667:8920'
                -  type: bind
                    source: /share/Container/jellyfin/config
                    target: /config
                -  type: bind
                    source: /share/Container/jellyfin/cache
                    target: /cache
            devices:
    The only thing that did not seem to work is that I was expecting to be able to access the UI at port 32666 but it seems I can access it at 8096, which is weird but I don't care. It is all working and it is thanks to your help!
    A million thank yous and I hope other people will see this thread and get help if they are facing the same issue.
    I have also opened a case with QNAP and asked them to update the nvidia drivers! We'll see how that goes.
