2023-07-30, 06:38 PM
(This post was last modified: 2023-07-30, 06:41 PM by Gemma. Edited 1 time in total.)
[*]The version of Jellyfin you are running (e.g. 10.8.10). 10.8.10
[*]Your installation method and platform (e.g. Linux Docker, Debian repository, Windows installer, etc.). Linux docker, unraid
[*]A brief description of the issue as your thread subject, using the description for additional important context only if required
[*]We used the server in our own home on web on our PCs, on an android projector and on fire sticks plugged into lg TV.
[*]Absolutely love playing at 2x speed, we left Plex for this feature. But some files play at 2x speed on the projector with no audio and the same file will play on other systems with audio fine. We can't figure out the cause, wondering if it is possibly an encoding issue.
[*]Ideally we would be able to play any file on 2x speed with full audio. Already tried re encoding the library to the same as a file that works on the projector with no change.
[*]What client(s) you are using and how the issue manifests
[*]Projector uses android TV jellyfin app, Amazon fire one seems to be fine. Same as web on Firefox seems to be fine.
[*]2x speed works on YouTube with no issues
