    Jellyfin Forum Support General Questions No audio on fire stick on my DVD rip mkv
    I've ripped aDVD but no audio plays on Jellyfin on the firestick. Its fine on laptop.
    pollik
    2024-10-29, 03:46 PM
    I've ripped a DVD for the first time, I've used makeMKV and made some .mkv files.
    They play fine on my laptop in both VLC player and Jellyfin, but using Jellyfin on my amazon fire stick on the TV it only plays the video - no audio comes out. Weirdly this then also stops audio working for everything on the fire stick until it is reset.
    Everything else plays fine on Jellyfin on the amazon fire stick.
    Anyone got any ideas as to what I've done wrong here?
    Jellyfin tells me the .mkv has the following properties:
    Container: mkv
    Audio
    Title: Mono - English - Dolby Digital - Default
    Language: eng
    Codec: AC3
    AVC: No
    Layout: mono
    Channels: 1 ch
    Bitrate: 192 kbps
    Sample rate: 48000 Hz
    Default: Yes
    Forced: No
    External: No
    Subtitle
    Title: English - Default - DVDSUB
    Language: eng
    Codec: DVDSUB
    AVC: No
    Resolution: 720x576
    Default: Yes
    Forced: No
    External: No
    Video
    Title: 576p MPEG2VIDEO SDR
    Codec: MPEG2VIDEO
    AVC: No
    Profile: Main
    Level: 8
    Resolution: 720x576
    Aspect ratio: 4:3
    Anamorphic: No
    Interlaced: No
    Framerate: 25
    Bitrate: 5956 kbps
    Bit depth: 8 bit
    Video range: SDR
    Video range type: SDR
    Pixel format: yuv420p
    Ref frames: 1
    Audio
    Title: Mono - Nor - Dolby Digital
    Language: nor
    Codec: AC3
    AVC: No
    Layout: mono
    Channels: 1 ch
    Bitrate: 192 kbps
    Default: No
    Forced: No
    External: No
    Audio
    Title: Mono - Swedish - Dolby Digital
    Language: swe
    Codec: AC3
    AVC: No
    Layout: mono
    Channels: 1 ch
    Bitrate: 192 kbps
    Default: No
    Forced: No
    External: No
    Audio
    Title: Mono - Danish - Dolby Digital
    Language: dan
    Codec: AC3
    AVC: No
    Layout: mono
    Channels: 1 ch
    Bitrate: 192 kbps
    Default: No
    Forced: No
    External: No
    Audio
    Title: Mono - Finnish - Dolby Digital
    Language: fin
    Codec: AC3
    AVC: No
    Layout: mono
    Channels: 1 ch
    Bitrate: 192 kbps
    Default: No
    Forced: No
    External: No
    Subtitle
    Title: Nor - DVDSUB
    Language: nor
    Codec: DVDSUB
    AVC: No
    Resolution: 720x576
    Default: No
    Forced: No
    External: No
    Subtitle
    Title: Swedish - DVDSUB
    Language: swe
    Codec: DVDSUB
    AVC: No
    Resolution: 720x576
    Default: No
    Forced: No
    External: No
    Subtitle
    Title: Danish - DVDSUB
    Language: dan
    Codec: DVDSUB
    AVC: No
    Resolution: 720x576
    Default: No
    Forced: No
    External: No
    Subtitle
    Title: Finnish - DVDSUB
    Language: fin
    Codec: DVDSUB
    AVC: No
    Resolution: 720x576
    Default: No
    Forced: No
    External: No
    Subtitle
    Title: Ice - DVDSUB
    Language: ice
    Codec: DVDSUB
    AVC: No
    Resolution: 720x576
    Default: No
    Forced: No
    External: No
    Subtitle
    Title: English - DVDSUB
    Language: eng
    Codec: DVDSUB
    AVC: No
    Resolution: 720x576
    Default: No
    Forced: No
    External: No
    Audio
    Language: eng
    Codec: AC3
    AVC: No
    Layout: mono
    Channels: 1 ch
    Bitrate: 192 kbps
    Default: Yes
    Forced: No
    External: No
    2024-10-29, 04:42 PM
    Post your server and any FFmpeg logs via Pastebin. Without reviewing them, I suspect there may be an issue due to mono audio. Try going to the ATV client, then navigate to Playback -> Audio -> Audio Output, and change the setting to "Downmix to Stereo."
    pollik
    2024-10-29, 04:58 PM
    (2024-10-29, 04:42 PM)theguymadmax Wrote: I suspect there may be an issue due to mono audio. Try going to the ATV client, then navigate to Playback -> Audio -> Audio Output, and change the setting to "Downmix to Stereo."
    You are correct, that has fixed it!
    Thanks so much!
    I don't have any surround sound, but I presume this would mean it wouldn't work?
    crawdaddydoo92
    2025-01-28, 07:11 AM
    I'm having a similar issue to the original post. I'm still quite new to this media server arena so you may have to explain how to get the data/logs you want. Two of the series I've saved, so far Fresh Prince and Full House don't have the main audio working on my fire stick. Oddly enough, the audio commentary audio on a full house episode worked and I could hear the audio in the background but if I went to the audio track alone I got silence. I haven't come across a Fresh Prince with commentary yet to see if it happens there. When I play the same Fresh Prince episode, the pilot, on my Android phone, Galaxy S20, on my Ubuntu laptop in fire fox, or on my Xbox, I'd wager my tablet as well, all is fine. But, if I try to play on my fire tv stick 4k with os 6.7.0.9 I get silence. I'm not sure what transcoding settings to change but I've seen many google answers saying to go that route. I've tried a few settings in the jellyfin app on the fire tv stick and on my server via fire fox but no luck.
    Any suggestions on where to try next, or on what I can show you to get more advice?
    2025-01-28, 02:48 PM
    Can you share your full server logs via privatebin.net?
    2025-01-28, 03:09 PM
    (2025-01-28, 07:11 AM)crawdaddydoo92 Wrote: I'm having a similar issue to the original post. I'm still quite new to this media server arena so you may have to explain how to get the data/logs you want. Two of the series I've saved, so far Fresh Prince and Full House don't have the main audio working on my fire stick. Oddly enough, the audio commentary audio on a full house episode worked and I could hear the audio in the background but if I went to the audio track alone I got silence. I haven't come across a Fresh Prince with commentary yet to see if it happens there. When I play the same Fresh Prince episode, the pilot, on my Android phone, Galaxy S20, on my Ubuntu laptop in fire fox, or on my Xbox, I'd wager my tablet as well, all is fine. But, if I try to play on my fire tv stick 4k with os 6.7.0.9 I get silence. I'm not sure what transcoding settings to change but I've seen many google answers saying to go that route. I've tried a few settings in the jellyfin app on the fire tv stick and on my server via fire fox but no luck.
    In version 10.10.4, there was a bug that caused transcoded audio to be output as stereo MP3, which resulted in no audio on some devices. This issue was fixed in 10.10.5. I’d need to review the ffmpeg logs to confirm if this is the issue in your situation.
