2024-10-09, 04:22 PM
		Hi All - new user here, I'm running OpenMediaVault which is hosting my JellyFin docker file. I followed the guide to add the /dev/dri line to the file and I enabled VAAPI and/or QSV on the dashboard but when I check the log files it does not appear to be working, something about no VA to output to. I'll do my best to give info below of the configs. Any help would be appreciated.
docker file in OMV:
# https://hub.docker.com/r/linuxserver/jellyfin
container_name: jellyfin
environment:
- PUID=1000
- PGID=100
- TZ=Etc/UTC
- JELLYFIN_PublishedServerUrl=192.168.1.5 #optional
- /srv/dev-disk-by-uuid-51bdfb34-5814-488d-857e-66d9fab524ab/media/Library config
config
- /srv/dev-disk-by-uuid-51bdfb34-5814-488d-857e-66d9fab524ab/media/tvshows data/tvshows
data/tvshows
- /srv/dev-disk-by-uuid-51bdfb34-5814-488d-857e-66d9fab524ab/media/movies data/movies
data/movies
devices:
- /dev/dri/renderD128 dev/dri/renderD128
dev/dri/renderD128
ports:
- 8096:8096
- 8920:8920 #optional
- 7359:7359/udp #optional
- 1900:1900/udp #optional
restart: unless-stopped
jellyfin log file as an example:
"{"Protocol":0,"Id":"ddccb0df0ac3601b4088e3eeaef6b4df","Path":"/data/movies/Source.Code.2011.1080p/Source.Code.2011.1080p.WebRip.EAC3.5.1.x265-Lootera.mkv","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"mkv","Size":2049491663,"Name":"Source.Code.2011.1080p.WebRip.EAC3.5.1.x265-Lootera","IsRemote":false,"ETag":"4626df8d9fd1b61c7c95313dade29303","RunTimeTicks":55728000000,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":false,"LiveStreamId":null,"BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":0,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":"hevc","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"","VideoRange":1,"VideoRangeType":1,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"1080p HEVC SDR","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":2942135,"BitDepth":10,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"Profile":"Main 10","Type":1,"AspectRatio":"16:9","Index":0,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuv420p10le","Level":120,"IsAnamorphic":false},{"Codec":"eac3","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"","VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":"Default","LocalizedForced":null,"LocalizedExternal":"External","LocalizedHearingImpaired":null,"DisplayTitle":"English - Dolby Digital\u002B - 5.1","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"5.1","BitRate":256000,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":0,"AspectRatio":null,"Index":1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"subrip","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"","VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"English - SUBRIP","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":0,"Width":0,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":2,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"mjpeg","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":"bt470bg","ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/90000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":null,"NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":8,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1425,"Width":950,"AverageFrameRate":null,"RealFrameRate":90000,"Profile":"Progressive","Type":3,"AspectRatio":"2:3","Index":3,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuvj420p","Level":-99,"IsAnamorphic":false}],"MediaAttachments":[{"Codec":"mjpeg","CodecTag":"[0][0][0][0]","Comment":null,"Index":3,"FileName":"cover.jpg","MimeType":"image/jpeg","DeliveryUrl":null}],"Formats":[],"Bitrate":3198135,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":0,"TranscodingContainer":null,"AnalyzeDurationMs":null,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null}
/usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -probesize 1G -noautorotate -i file:"/data/movies/Source.Code.2011.1080p/Source.Code.2011.1080p.WebRip.EAC3.5.1.x265-Lootera.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_vaapi -rc_mode VBR -b:v 1244000 -maxrate 1244000 -bufsize 2488000 -profile:v:0 high -sei -a53_cc -force_key_frames:0 "expr:gte(t,n_forced*3)" -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,720)/2)*2:trunc(ow/a/2)*2,format=nv12,hwupload_vaapi" -codec:a:0 copy -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type fmp4 -hls_fmp4_init_filename "e67a164256a51bba39920804f417889c-1.mp4" -start_number 0 -hls_segment_filename "/config/cache/transcodes/e67a164256a51bba39920804f417889c%d.mp4" -hls_playlist_type vod -hls_list_size 0 -y "/config/cache/transcodes/e67a164256a51bba39920804f417889c.m3u8"
ffmpeg version 6.0.1-Jellyfin Copyright © 2000-2023 the FFmpeg developers
built with gcc 13 (Ubuntu 13.2.0-23ubuntu4)
configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-opencl --enable-libdrm --enable-libxml2 --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libsvtav1 --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=amd64 --enable-libshaderc --enable-libplacebo --enable-vulkan --enable-vaapi --enable-amf --enable-libvpl --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc
libavutil 58. 2.100 / 58. 2.100
libavcodec 60. 3.100 / 60. 3.100
libavformat 60. 3.100 / 60. 3.100
libavdevice 60. 1.100 / 60. 1.100
libavfilter 9. 3.100 / 9. 3.100
libswscale 7. 1.100 / 7. 1.100
libswresample 4. 10.100 / 4. 10.100
libpostproc 57. 1.100 / 57. 1.100
Input #0, matroska,webm, from 'file data/movies/Source.Code.2011.1080p/Source.Code.2011.1080p.WebRip.EAC3.5.1.x265-Lootera.mkv':
Metadata:
title :
encoder : libebml v1.4.5 + libmatroska v1.7.1
Duration: 01:32:52.80, start: 0.000000, bitrate: 2942 kb/s
Chapters:
Chapter #0:0: start 0.000000, end 5572.800000
Metadata:
title : Chapter 1
Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default)
Metadata:
title :
Stream #0:1(eng): Audio: eac3, 48000 Hz, 5.1(side), fltp, 256 kb/s
Metadata:
title :
Stream #0:2(eng): Subtitle: subrip
Metadata:
title :
Stream #0:3: Video: mjpeg (Progressive), yuvj420p(pc, bt470bg/unknown/unknown), 950x1425 [SAR 1:1 DAR 2:3], 90k tbr, 90k tbn (attached pic)
Metadata:
filename : cover.jpg
mimetype : image/jpeg
Stream mapping:
Stream #0:0 -> #0:0 (hevc (native) -> h264 (h264_vaapi))
Stream #0:1 -> #0:1 (copy)
[AVHWDeviceContext @ 0x557fb103f480] No VA display found for any default device.
[AVFilterGraph @ 0x557fb17e7200] Error initializing filters
Error reinitializing filters!
Failed to inject frame into filter network: Invalid argument
Error while processing the decoded data for stream #0:0
Conversion failed!
docker file in OMV:
environment:
- PUID=1000
- PGID=100
- TZ=Etc/UTC
 config
config- /srv/dev-disk-by-uuid-51bdfb34-5814-488d-857e-66d9fab524ab/media/tvshows
 data/tvshows
data/tvshows- /srv/dev-disk-by-uuid-51bdfb34-5814-488d-857e-66d9fab524ab/media/movies
 data/movies
data/moviesdevices:
 dev/dri/renderD128
dev/dri/renderD128ports:
- 8096:8096
data/movies/Source.Code.2011.1080p/Source.Code.2011.1080p.WebRip.EAC3.5.1.x265-Lootera.mkv':Metadata:
title :
Chapters:
Metadata:
title : Chapter 1
Metadata:
title :
Metadata:
title :
Metadata:
title :
Metadata:
Stream mapping:
Conversion failed!
