    Jellyfin Forum Support Troubleshooting Playback error: h264 file with AC3 audio will not playback on swiftfin
    Pages (3): « Previous 1 2 3
    linuxnoob0009
    Country:Denmark
    #21
    2024-10-10, 01:56 PM
    (2024-10-10, 11:59 AM)TheDreadPirate Wrote: Do you have remuxing enabled?
    that is the user setting "allow video playback that requires conversion without reencoding", right?
    That is enabled. Just  tried disabling but same result.
    2024-10-10, 05:41 PM
    If you've replaced the video with new version, make sure you re-scan the library.
    linuxnoob0009
    Country:Denmark
    #23
    2024-10-11, 12:28 PM
    (2024-10-10, 05:41 PM)TheDreadPirate Wrote: If you've replaced the video with new version, make sure you re-scan the library.
    thanks, i did after every operation. Tried installing Plex and it plays the file fine, no transcode.
    2024-10-11, 01:25 PM
    Go ahead and report an issue on Swiftfin's git. I just noticed that there was a release 3 days ago that may explain the multiple Swiftfin related threads.
    https://github.com/jellyfin/Swiftfin/issues
