    Jellyfin Forum Support Troubleshooting Problem
    Problem
    slow transcoding VC1 videos
    wenze
    2026-06-29, 08:13 PM
    Hi, I'm having trouble transcoding VC1 videos as the source (25-19fps). It doesn't matter whether I'm transcoding to H.264, H.265, or AV1.
    For comparison: MPG2 at 160–230 fps
    Docker on TrueNAS 4CPUs and 8GB Ram for the Container
    Jellyfin App Version: 10.11.11
    sudo docker exec -it ix-jellyfin-jellyfin-1 /usr/lib/jellyfin-ffmpeg/ffmpeg -v debug -init_hw_device vulkan
    ffmpeg version 7.1.4-Jellyfin Copyright (c) 2000-2026 the FFmpeg developers
      built with gcc 14 (Debian 14.2.0-19)
      configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto=auto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-opencl --enable-libdrm --enable-libxml2 --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libharfbuzz --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libsvtav1 --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=amd64 --enable-libshaderc --enable-libplacebo --enable-vulkan --enable-vaapi --enable-amf --enable-libvpl --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc
      libavutil      59. 39.100 / 59. 39.100
      libavcodec    61. 19.101 / 61. 19.101
      libavformat    61.  7.103 / 61.  7.103
      libavdevice    61.  3.100 / 61.  3.100
      libavfilter    10.  5.100 / 10.  5.100
      libswscale      8.  3.100 /  8.  3.100
      libswresample  5.  3.100 /  5.  3.100
      libpostproc    58.  3.100 / 58.  3.100
    Splitting the commandline.
    Reading option '-v' ... matched as option 'v' (set logging level) with argument 'debug'.
    Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'vulkan'.
    Finished splitting the commandline.
    Parsing a group of options: global .
    Applying option v (set logging level) with argument debug.
    Applying option init_hw_device (initialise hardware device) with argument vulkan.
    [AVHWDeviceContext @ 0x7f84be480bc0] Supported layers:
    [AVHWDeviceContext @ 0x7f84be480bc0] VK_LAYER_MESA_device_select
    [AVHWDeviceContext @ 0x7f84be480bc0] VK_LAYER_MESA_overlay
    [AVHWDeviceContext @ 0x7f84be480bc0] Using instance extension VK_KHR_portability_enumeration
    [AVHWDeviceContext @ 0x7f84be480bc0] GPU listing:
    [AVHWDeviceContext @ 0x7f84be480bc0]    0: AMD Radeon 780M Graphics (RADV PHOENIX) (integrated) (0x1900)
    [AVHWDeviceContext @ 0x7f84be480bc0] Device 0 selected: AMD Radeon 780M Graphics (RADV PHOENIX) (integrated) (0x1900)
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_push_descriptor
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_EXT_descriptor_buffer
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_EXT_physical_device_drm
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_EXT_shader_atomic_float
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_cooperative_matrix
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_EXT_shader_object
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_video_maintenance1
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_external_memory_fd
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_EXT_external_memory_dma_buf
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_EXT_image_drm_format_modifier
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_external_semaphore_fd
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_EXT_external_memory_host
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_video_queue
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_video_encode_queue
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_video_decode_queue
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_video_encode_h264
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_video_decode_h264
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_video_encode_h265
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_video_decode_h265
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device extension VK_KHR_video_decode_av1
    [AVHWDeviceContext @ 0x7f84be480bc0] Queue families:
    [AVHWDeviceContext @ 0x7f84be480bc0]    0: graphics compute transfer (queues: 1)
    [AVHWDeviceContext @ 0x7f84be480bc0]    1: compute transfer (queues: 4)
    [AVHWDeviceContext @ 0x7f84be480bc0]    2: decode (queues: 1)
    [AVHWDeviceContext @ 0x7f84be480bc0]    3: encode (queues: 1)
    [AVHWDeviceContext @ 0x7f84be480bc0]    4: sparse (queues: 1)
    [AVHWDeviceContext @ 0x7f84be480bc0] Using device: AMD Radeon 780M Graphics (RADV PHOENIX)
    [AVHWDeviceContext @ 0x7f84be480bc0] Alignments:
    [AVHWDeviceContext @ 0x7f84be480bc0]    optimalBufferCopyRowPitchAlignment: 1
    [AVHWDeviceContext @ 0x7f84be480bc0]    minMemoryMapAlignment:              4096
    [AVHWDeviceContext @ 0x7f84be480bc0]    nonCoherentAtomSize:                64
    [AVHWDeviceContext @ 0x7f84be480bc0]    minImportedHostPointerAlignment:    4096
    [AVHWDeviceContext @ 0x7f84be480bc0] Using queue family 0 (queues: 1) for graphics
    [AVHWDeviceContext @ 0x7f84be480bc0] Using queue family 1 (queues: 4) for compute transfers
    [AVHWDeviceContext @ 0x7f84be480bc0] Using queue family 2 (queues: 1) for decode
    [AVHWDeviceContext @ 0x7f84be480bc0] Using queue family 3 (queues: 1) for encode
    Successfully parsed a group of options.
    Universal media converter
    sudo docker exec -it ix-jellyfin-jellyfin-1  /usr/lib/jellyfin-ffmpeg/vainfo --display drm --device /dev/dri/renderD128
    [sudo] password for admin:
    Trying display: drm
    libva info: VA-API version 1.23.0
    libva info: Trying to open /usr/lib/jellyfin-ffmpeg/lib/dri/radeonsi_drv_video.so
    libva info: Found init function __vaDriverInit_1_23
    amdgpu: os_same_file_description couldn't determine if two DRM fds reference the same file description.
    If they do, bad things may happen!
    vainfo: VA-API version: 1.23 (libva 2.23.0)
    vainfo: Driver version: Mesa Gallium driver 25.0.7 for AMD Radeon 780M Graphics (radeonsi, phoenix, ACO, DRM 3.61, 6.12.91-production+truenas)
          VAProfileHEVCMain              : VAEntrypointEncSlice
          VAProfileHEVCMain10            : VAEntrypointEncSlice
          VAProfileAV1Profile0            : VAEntrypointVLD
          VAProfileAV1Profile0            : VAEntrypointEncSlice
    "Protocol":0,"Id":"9de7a1fc5c5118dc615be95a9454061c","Path":"/nfs/Filme/Der 13te Krieger.mkv","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"mkv","Size":17892790672,"Name":"Der 13te Krieger","IsRemote":false,"ETag":"5a54bd3b3c1e059c8efc0fe4a72e724c","RunTimeTicks":61661650000,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"UseMostCompatibleTranscodingProfile":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":false,"LiveStreamId":null,"BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":0,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":"vc1","CodecTag":"WVC1","Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"Hdr10PlusPresentFlag":null,"VideoRange":1,"VideoRangeType":1,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"1080p VC1 SDR","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":23214157,"BitDepth":8,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"ReferenceFrameRate":23.976025,"Profile":"Advanced","Type":1,"AspectRatio":"16:9","Index":0,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuv420p","Level":3,"IsAnamorphic":false},{"Codec":"dts","CodecTag":null,"Language":"deu","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"Surround 5.1","Hdr10PlusPresentFlag":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":"Standard","LocalizedForced":null,"LocalizedExternal":"Extern","LocalizedHearingImpaired":null,"DisplayTitle":"Surround 5.1 - German - DTS - Standard","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"5.1","BitRate":1536000,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":"DTS","Type":0,"AspectRatio":null,"Index":1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"dts","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"Surround 5.1","Hdr10PlusPresentFlag":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":"Standard","LocalizedForced":null,"LocalizedExternal":"Extern","LocalizedHearingImpaired":null,"DisplayTitle":"Surround 5.1 - English - DTS","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"5.1","BitRate":1536000,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":"DTS","Type":0,"AspectRatio":null,"Index":2,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"PGSSUB","CodecTag":null,"Language":"deu","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"Hdr10PlusPresentFlag":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefiniert","LocalizedDefault":"Standard","LocalizedForced":"Erzwungen","LocalizedExternal":"Extern","LocalizedHearingImpaired":"H\u00F6rgesch\u00E4digt","DisplayTitle":"German - PGSSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":3,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"PGSSUB","CodecTag":null,"Language":"deu","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"Hdr10PlusPresentFlag":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefiniert","LocalizedDefault":"Standard","LocalizedForced":"Erzwungen","LocalizedExternal":"Extern","LocalizedHearingImpaired":"H\u00F6rgesch\u00E4digt","DisplayTitle":"German - PGSSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":4,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":true,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null}],"MediaAttachments":[],"Formats":[],"Bitrate":26286157,"FallbackMaxStreamingBitrate":null,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":0,"TranscodingContainer":null,"AnalyzeDurationMs":null,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null,"HasSegments":false}
    /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -probesize 1G -ss 00:36:11.169 -noaccurate_seek -f matroska -init_hw_device drm=dr:/dev/dri/renderD128 -init_hw_device vaapi=va@dr -init_hw_device vulkan=vk@dr -filter_hw_device vk -i file:"/nfs/Filme/Der 13te Krieger.mkv" -map_metadata -1 -map_chapters -1 -threads 6 -map 0:0 -map 0:1 -map -0:s -codec:v:0 av1_vaapi -rc_mode VBR -b:v 23214157 -maxrate 23214157 -bufsize 46428314 -profile:v:0 main -force_key_frames:0 "expr:gte(t,n_forced*3)" -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,1920)/2)*2:trunc(ow/a/2)*2,format=nv12,hwupload_vaapi" -codec:a:0 libfdk_aac -ac 2 -ab 256000 -copyts -avoid_negative_ts disabled -max_muxing_queue_size 4096 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type fmp4 -hls_fmp4_init_filename "71c6d875ebfcb73676bbbd4e1072bfb7-1.mp4" -start_number 723 -hls_segment_filename "/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7%d.mp4" -hls_playlist_type vod -hls_list_size 0 -hls_segment_options movflags=+frag_discont -y "/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7.m3u8"
    Input #0, matroska,webm, from 'file:/nfs/Filme/Der 13te Krieger.mkv':
      Metadata:
        encoder        : libmakemkv v1.18.3 (1.3.10/1.5.2) x86_64-linux-gnu
        creation_time  : 2026-05-25T11:23:19.000000Z
      Duration: 01:42:46.17, start: 0.000000, bitrate: 23214 kb/s
      Chapters:
        Chapter #0:0: start 0.000000, end 217.800917
          Metadata:
            title          : Chapter 01
        Chapter #0:1: start 217.800917, end 456.122333
          Metadata:
            title          : Chapter 02
        Chapter #0:2: start 456.122333, end 816.315500
          Metadata:
            title          : Chapter 03
        Chapter #0:3: start 816.315500, end 921.754167
          Metadata:
            title          : Chapter 04
        Chapter #0:4: start 921.754167, end 1241.740500
          Metadata:
            title          : Chapter 05
        Chapter #0:5: start 1241.740500, end 1598.930667
          Metadata:
            title          : Chapter 06
        Chapter #0:6: start 1598.930667, end 1975.223250
          Metadata:
            title          : Chapter 07
        Chapter #0:7: start 1975.223250, end 2191.981458
          Metadata:
            title          : Chapter 08
        Chapter #0:8: start 2191.981458, end 2467.298167
          Metadata:
            title          : Chapter 09
        Chapter #0:9: start 2467.298167, end 2757.171083
          Metadata:
            title          : Chapter 10
        Chapter #0:10: start 2757.171083, end 3085.415667
          Metadata:
            title          : Chapter 11
        Chapter #0:11: start 3085.415667, end 3379.000625
          Metadata:
            title          : Chapter 12
        Chapter #0:12: start 3379.000625, end 3902.481917
          Metadata:
            title          : Chapter 13
        Chapter #0:13: start 3902.481917, end 4107.269833
          Metadata:
            title          : Chapter 14
        Chapter #0:14: start 4107.269833, end 4867.821292
          Metadata:
            title          : Chapter 15
        Chapter #0:15: start 4867.821292, end 5092.587500
          Metadata:
            title          : Chapter 16
        Chapter #0:16: start 5092.587500, end 5798.834708
          Metadata:
            title          : Chapter 17
        Chapter #0:17: start 5798.834708, end 6166.165333
          Metadata:
            title          : Chapter 18
      Stream #0:0(eng): Video: vc1 (Advanced) (WVC1 / 0x31435657), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn
          Metadata:
            BPS-eng        : 19953633
            DURATION-eng    : 01:42:46.160000000
            NUMBER_OF_FRAMES-eng: 147840
            NUMBER_OF_BYTES-eng: 15379661711
            SOURCE_ID-eng  : 001011
            _STATISTICS_WRITING_APP-eng: MakeMKV v1.18.3 linux(x64-release)
            _STATISTICS_WRITING_DATE_UTC-eng: 2026-05-25 11:23:19
            _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID
      Stream #0:1(deu): Audio: dts (dca) (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)
          Metadata:
            title          : Surround 5.1
            BPS-eng        : 1509000
            DURATION-eng    : 01:42:46.165333333
            NUMBER_OF_FRAMES-eng: 578078
            NUMBER_OF_BYTES-eng: 1163092936
            SOURCE_ID-eng  : 001100
      Stream #0:2(eng): Audio: dts (dca) (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s
          Metadata:
            BPS-eng        : 1509000
            SOURCE_ID-eng  : 001101
      Stream #0:3(deu): Subtitle: hdmv_pgs_subtitle (pgssub), 1920x1080
          Metadata:
            BPS-eng        : 199043
            DURATION-eng    : 01:37:07.217229166
            NUMBER_OF_FRAMES-eng: 4815
            NUMBER_OF_BYTES-eng: 144983601
            SOURCE_ID-eng  : 001200
      Stream #0:4(deu): Subtitle: hdmv_pgs_subtitle (pgssub), 1920x1080
          Metadata:
            BPS-eng        : 53745
            NUMBER_OF_BYTES-eng: 39148207
            SOURCE_ID-eng  : 001201
    Stream mapping:
      Stream #0:0 -> #0:0 (vc1 (native) -> av1 (av1_vaapi))
      Stream #0:1 -> #0:1 (dts (dca) -> aac (libfdk_aac))
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7-1.mp4' for writing
    Output #0, hls, to '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7.m3u8':
      Metadata:
        encoder        : Lavf61.7.103
      Stream #0:0: Video: av1 (Main), vaapi(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23214 kb/s, 23.98 fps, 24k tbn
          Metadata:
            encoder        : Lavc61.19.101 av1_vaapi
      Stream #0:1: Audio: aac, 48000 Hz, stereo, s16, 256 kb/s (default)
          Metadata:
            encoder        : Lavc61.19.101 libfdk_aac
          Side data:
            cpb: bitrate max/min/avg: 256000/256000/256000 buffer size: 0 vbv_delay: N/A
    frame=    5 fps=0.0 q=-0.0 size=N/A time=00:00:00.00 bitrate=N/A speed=  0x
    frame=  16 fps= 16 q=-0.0 size=N/A time=00:00:00.45 bitrate=N/A speed=0.459x
    frame=  27 fps= 18 q=-0.0 size=N/A time=00:00:00.91 bitrate=N/A speed=0.611x
    frame=  37 fps= 18 q=-0.0 size=N/A time=00:00:01.33 bitrate=N/A speed=0.667x
    frame=  48 fps= 19 q=-0.0 size=N/A time=00:00:01.79 bitrate=N/A speed=0.717x
    frame=  61 fps= 20 q=-0.0 size=N/A time=00:00:02.33 bitrate=N/A speed=0.778x
    frame=  72 fps= 21 q=-0.0 size=N/A time=00:00:02.79 bitrate=N/A speed=0.798x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7723.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 104343000 is out of range
    frame=  83 fps= 21 q=-0.0 size=N/A time=00:00:03.25 bitrate=N/A speed=0.813x
    frame=  93 fps= 21 q=-0.0 size=N/A time=00:00:03.67 bitrate=N/A speed=0.815x
    frame=  103 fps= 21 q=-0.0 size=N/A time=00:00:04.08 bitrate=N/A speed=0.817x
    frame=  111 fps= 20 q=-0.0 size=N/A time=00:00:04.42 bitrate=N/A speed=0.803x
    frame=  120 fps= 20 q=-0.0 size=N/A time=00:00:04.79 bitrate=N/A speed=0.799x
    frame=  128 fps= 20 q=-0.0 size=N/A time=00:00:05.13 bitrate=N/A speed=0.789x
    frame=  137 fps= 20 q=-0.0 size=N/A time=00:00:05.50 bitrate=N/A speed=0.786x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7724.mp4' for writing
    frame=  145 fps= 19 q=-0.0 size=N/A time=00:00:05.83 bitrate=N/A speed=0.778x
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 104487384 is out of range
    frame=  154 fps= 19 q=-0.0 size=N/A time=00:00:06.21 bitrate=N/A speed=0.776x
    frame=  164 fps= 19 q=-0.0 size=N/A time=00:00:06.63 bitrate=N/A speed=0.78x
    frame=  177 fps= 20 q=-0.0 size=N/A time=00:00:07.17 bitrate=N/A speed=0.797x
    frame=  188 fps= 20 q=-0.0 size=N/A time=00:00:07.63 bitrate=N/A speed=0.803x
    frame=  200 fps= 20 q=-0.0 size=N/A time=00:00:08.13 bitrate=N/A speed=0.813x
    frame=  212 fps= 20 q=-0.0 size=N/A time=00:00:08.63 bitrate=N/A speed=0.822x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7725.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 104630744 is out of range
    frame=  224 fps= 20 q=-0.0 size=N/A time=00:00:09.13 bitrate=N/A speed=0.83x
    frame=  236 fps= 21 q=-0.0 size=N/A time=00:00:09.63 bitrate=N/A speed=0.837x
    frame=  248 fps= 21 q=-0.0 size=N/A time=00:00:10.13 bitrate=N/A speed=0.844x
    frame=  261 fps= 21 q=-0.0 size=N/A time=00:00:10.67 bitrate=N/A speed=0.854x
    frame=  273 fps= 21 q=-0.0 size=N/A time=00:00:11.17 bitrate=N/A speed=0.859x
    frame=  285 fps= 21 q=-0.0 size=N/A time=00:00:11.67 bitrate=N/A speed=0.865x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7726.mp4' for writing
    frame=  297 fps= 21 q=-0.0 size=N/A time=00:00:12.17 bitrate=N/A speed=0.869x
    frame=  310 fps= 21 q=-0.0 size=N/A time=00:00:12.72 bitrate=N/A speed=0.877x
    frame=  322 fps= 21 q=-0.0 size=N/A time=00:00:13.22 bitrate=N/A speed=0.881x
    frame=  334 fps= 22 q=-0.0 size=N/A time=00:00:13.72 bitrate=N/A speed=0.885x
    frame=  345 fps= 22 q=-0.0 size=N/A time=00:00:14.18 bitrate=N/A speed=0.886x
    frame=  355 fps= 22 q=-0.0 size=N/A time=00:00:14.59 bitrate=N/A speed=0.884x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7727.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 104919512 is out of range
    frame=  367 fps= 22 q=-0.0 size=N/A time=00:00:15.09 bitrate=N/A speed=0.888x
    frame=  378 fps= 22 q=-0.0 size=N/A time=00:00:15.55 bitrate=N/A speed=0.888x
    frame=  389 fps= 22 q=-0.0 size=N/A time=00:00:16.01 bitrate=N/A speed=0.889x
    frame=  399 fps= 22 q=-0.0 size=N/A time=00:00:16.43 bitrate=N/A speed=0.888x
    frame=  411 fps= 22 q=-0.0 size=N/A time=00:00:16.93 bitrate=N/A speed=0.891x
    frame=  423 fps= 22 q=-0.0 size=N/A time=00:00:17.43 bitrate=N/A speed=0.894x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7728.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 105063912 is out of range
    frame=  435 fps= 22 q=-0.0 size=N/A time=00:00:17.93 bitrate=N/A speed=0.896x
    frame=  447 fps= 22 q=-0.0 size=N/A time=00:00:18.43 bitrate=N/A speed=0.899x
    frame=  458 fps= 22 q=-0.0 size=N/A time=00:00:18.89 bitrate=N/A speed=0.899x
    frame=  469 fps= 22 q=-0.0 size=N/A time=00:00:19.35 bitrate=N/A speed= 0.9x
    frame=  480 fps= 22 q=-0.0 size=N/A time=00:00:19.81 bitrate=N/A speed= 0.9x
    frame=  489 fps= 22 q=-0.0 size=N/A time=00:00:20.18 bitrate=N/A speed=0.897x
    frame=  500 fps= 22 q=-0.0 size=N/A time=00:00:20.64 bitrate=N/A speed=0.897x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7729.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 105207272 is out of range
    frame=  510 fps= 22 q=-0.0 size=N/A time=00:00:21.06 bitrate=N/A speed=0.896x
    frame=  523 fps= 22 q=-0.0 size=N/A time=00:00:21.60 bitrate=N/A speed= 0.9x
    frame=  535 fps= 22 q=-0.0 size=N/A time=00:00:22.10 bitrate=N/A speed=0.902x
    frame=  549 fps= 22 q=-0.0 size=N/A time=00:00:22.68 bitrate=N/A speed=0.907x
    frame=  561 fps= 22 q=-0.0 size=N/A time=00:00:23.18 bitrate=N/A speed=0.909x
    frame=  574 fps= 22 q=-0.0 size=N/A time=00:00:23.73 bitrate=N/A speed=0.912x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7730.mp4' for writing
    frame=  585 fps= 22 q=-0.0 size=N/A time=00:00:24.19 bitrate=N/A speed=0.912x
    frame=  595 fps= 22 q=-0.0 size=N/A time=00:00:24.60 bitrate=N/A speed=0.911x
    frame=  606 fps= 22 q=-0.0 size=N/A time=00:00:25.06 bitrate=N/A speed=0.911x
    frame=  616 fps= 22 q=-0.0 size=N/A time=00:00:25.48 bitrate=N/A speed=0.91x
    frame=  627 fps= 22 q=-0.0 size=N/A time=00:00:25.94 bitrate=N/A speed=0.91x
    frame=  638 fps= 22 q=-0.0 size=N/A time=00:00:26.40 bitrate=N/A speed=0.91x
    frame=  648 fps= 22 q=-0.0 size=N/A time=00:00:26.81 bitrate=N/A speed=0.909x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7731.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 105495992 is out of range
    frame=  657 fps= 22 q=-0.0 size=N/A time=00:00:27.19 bitrate=N/A speed=0.906x
    frame=  668 fps= 22 q=-0.0 size=N/A time=00:00:27.65 bitrate=N/A speed=0.906x
    frame=  678 fps= 22 q=-0.0 size=N/A time=00:00:28.06 bitrate=N/A speed=0.905x
    frame=  688 fps= 22 q=-0.0 size=N/A time=00:00:28.48 bitrate=N/A speed=0.904x
    frame=  699 fps= 22 q=-0.0 size=N/A time=00:00:28.94 bitrate=N/A speed=0.904x
    frame=  712 fps= 22 q=-0.0 size=N/A time=00:00:29.48 bitrate=N/A speed=0.907x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7732.mp4' for writing
    frame=  723 fps= 22 q=-0.0 size=N/A time=00:00:29.94 bitrate=N/A speed=0.907x
    frame=  735 fps= 22 q=-0.0 size=N/A time=00:00:30.44 bitrate=N/A speed=0.908x
    frame=  747 fps= 22 q=-0.0 size=N/A time=00:00:30.94 bitrate=N/A speed=0.91x
    frame=  759 fps= 22 q=-0.0 size=N/A time=00:00:31.44 bitrate=N/A speed=0.911x
    frame=  771 fps= 22 q=-0.0 size=N/A time=00:00:31.94 bitrate=N/A speed=0.912x
    frame=  784 fps= 22 q=-0.0 size=N/A time=00:00:32.49 bitrate=N/A speed=0.915x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7733.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 105783768 is out of range
    frame=  797 fps= 22 q=-0.0 size=N/A time=00:00:33.03 bitrate=N/A speed=0.917x
    frame=  812 fps= 22 q=-0.0 size=N/A time=00:00:33.65 bitrate=N/A speed=0.922x
    frame=  826 fps= 22 q=-0.0 size=N/A time=00:00:34.24 bitrate=N/A speed=0.925x
    frame=  837 fps= 22 q=-0.0 size=N/A time=00:00:34.70 bitrate=N/A speed=0.925x
    frame=  848 fps= 22 q=-0.0 size=N/A time=00:00:35.16 bitrate=N/A speed=0.925x
    frame=  858 fps= 22 q=-0.0 size=N/A time=00:00:35.57 bitrate=N/A speed=0.924x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7734.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 105928152 is out of range
    frame=  869 fps= 22 q=-0.0 size=N/A time=00:00:36.03 bitrate=N/A speed=0.923x
    frame=  879 fps= 22 q=-0.0 size=N/A time=00:00:36.45 bitrate=N/A speed=0.922x
    frame=  889 fps= 22 q=-0.0 size=N/A time=00:00:36.87 bitrate=N/A speed=0.921x
    frame=  899 fps= 22 q=-0.0 size=N/A time=00:00:37.28 bitrate=N/A speed=0.92x
    frame=  910 fps= 22 q=-0.0 size=N/A time=00:00:37.74 bitrate=N/A speed=0.92x
    frame=  919 fps= 22 q=-0.0 size=N/A time=00:00:38.12 bitrate=N/A speed=0.918x
    frame=  929 fps= 22 q=-0.0 size=N/A time=00:00:38.53 bitrate=N/A speed=0.917x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7735.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 106072568 is out of range
    frame=  940 fps= 22 q=-0.0 size=N/A time=00:00:38.99 bitrate=N/A speed=0.917x
    frame=  951 fps= 22 q=-0.0 size=N/A time=00:00:39.45 bitrate=N/A speed=0.917x
    frame=  962 fps= 22 q=-0.0 size=N/A time=00:00:39.91 bitrate=N/A speed=0.917x
    frame=  973 fps= 22 q=-0.0 size=N/A time=00:00:40.37 bitrate=N/A speed=0.917x
    frame=  984 fps= 22 q=-0.0 size=N/A time=00:00:40.83 bitrate=N/A speed=0.917x
    frame=  995 fps= 22 q=-0.0 size=N/A time=00:00:41.29 bitrate=N/A speed=0.917x
    frame= 1006 fps= 22 q=-0.0 size=N/A time=00:00:41.75 bitrate=N/A speed=0.917x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7736.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 106214904 is out of range
    frame= 1017 fps= 22 q=-0.0 size=N/A time=00:00:42.20 bitrate=N/A speed=0.917x
    frame= 1027 fps= 22 q=-0.0 size=N/A time=00:00:42.62 bitrate=N/A speed=0.916x
    frame= 1038 fps= 22 q=-0.0 size=N/A time=00:00:43.08 bitrate=N/A speed=0.916x
    frame= 1048 fps= 22 q=-0.0 size=N/A time=00:00:43.50 bitrate=N/A speed=0.915x
    frame= 1060 fps= 22 q=-0.0 size=N/A time=00:00:44.00 bitrate=N/A speed=0.916x
    frame= 1071 fps= 22 q=-0.0 size=N/A time=00:00:44.46 bitrate=N/A speed=0.916x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7737.mp4' for writing
    frame= 1081 fps= 22 q=-0.0 size=N/A time=00:00:44.87 bitrate=N/A speed=0.915x
    frame= 1092 fps= 22 q=-0.0 size=N/A time=00:00:45.33 bitrate=N/A speed=0.915x
    frame= 1103 fps= 22 q=-0.0 size=N/A time=00:00:45.79 bitrate=N/A speed=0.915x
    frame= 1115 fps= 22 q=-0.0 size=N/A time=00:00:46.29 bitrate=N/A speed=0.916x
    frame= 1125 fps= 22 q=-0.0 size=N/A time=00:00:46.71 bitrate=N/A speed=0.915x
    frame= 1136 fps= 22 q=-0.0 size=N/A time=00:00:47.17 bitrate=N/A speed=0.915x
    frame= 1147 fps= 22 q=-0.0 size=N/A time=00:00:47.63 bitrate=N/A speed=0.915x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7738.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -8 / dts: 106502648 is out of range
    frame= 1158 fps= 22 q=-0.0 size=N/A time=00:00:48.08 bitrate=N/A speed=0.915x
    frame= 1169 fps= 22 q=-0.0 size=N/A time=00:00:48.54 bitrate=N/A speed=0.915x
    frame= 1179 fps= 22 q=-0.0 size=N/A time=00:00:48.96 bitrate=N/A speed=0.915x
    frame= 1191 fps= 22 q=-0.0 size=N/A time=00:00:49.46 bitrate=N/A speed=0.916x
    frame= 1201 fps= 22 q=-0.0 size=N/A time=00:00:49.88 bitrate=N/A speed=0.915x
    frame= 1213 fps= 22 q=-0.0 size=N/A time=00:00:50.38 bitrate=N/A speed=0.916x
    frame= 1223 fps= 22 q=-0.0 size=N/A time=00:00:50.80 bitrate=N/A speed=0.915x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7739.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -8 / dts: 106647032 is out of range
    frame= 1234 fps= 22 q=-0.0 size=N/A time=00:00:51.25 bitrate=N/A speed=0.915x
    frame= 1245 fps= 22 q=-0.0 size=N/A time=00:00:51.71 bitrate=N/A speed=0.915x
    frame= 1260 fps= 22 q=-0.0 size=N/A time=00:00:52.34 bitrate=N/A speed=0.918x
    frame= 1274 fps= 22 q=-0.0 size=N/A time=00:00:52.92 bitrate=N/A speed=0.92x
    frame= 1290 fps= 22 q=-0.0 size=N/A time=00:00:53.59 bitrate=N/A speed=0.924x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7740.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 106791368 is out of range
    frame= 1306 fps= 22 q=-0.0 size=N/A time=00:00:54.26 bitrate=N/A speed=0.927x
    frame= 1320 fps= 22 q=-0.0 size=N/A time=00:00:54.84 bitrate=N/A speed=0.929x
    frame= 1336 fps= 22 q=-0.0 size=N/A time=00:00:55.51 bitrate=N/A speed=0.932x
    frame= 1350 fps= 22 q=-0.0 size=N/A time=00:00:56.09 bitrate=N/A speed=0.934x
    frame= 1363 fps= 23 q=-0.0 size=N/A time=00:00:56.63 bitrate=N/A speed=0.936x
    [hls @ 0x7fd0a12c5a00] Opening '/config/transcodes/71c6d875ebfcb73676bbbd4e1072bfb7741.mp4' for writing
    [mp4 @ 0x7fd089817a00] Packet duration: -16 / dts: 106935752 is out of range
    frame= 1375 fps= 23 q=-0.0 size=N/A time=00:00:57.14 bitrate=N/A speed=0.936x
    2026-06-29, 10:29 PM
    The 780M doesn't have VC1 decoding. Meaning that during transcodes all the decoding is happening on the CPU before being shifted to the GPU for encoding.
