    Jellyfin Forum Support Troubleshooting Problem kodi mode native
    Problem kodi mod native with jellyfin 10.9
    Omse
    Country:Morocco
    2024-05-18, 12:27 PM
    Salut
    J'utilise kodi avec kodi en mode natif depuis longtemps mais après la mise à jour jellyfin 10.9 le mode natif du plug-in jellyfin-kodi ne fonctionne plus
    Si quelqu'un a une solution
    Merci d'avance
    underdog
    2024-05-18, 08:41 PM
    As example:
    root > default > movies > options.xml
    Open this file and add the networkpath with your own settings
    Jellyfin 10.9.2
    Openmediavault 7
    Docker linuxserver
    Omse
    Country:Morocco
    2024-05-19, 12:04 AM
    Salut j'utilise kodi dans plusieurs devises (Zidoo-z9x. Et 2 box Android) Pouvez-vous m'expliquer encore plus ? MERCI
    Omse
    Country:Morocco
    2024-05-19, 12:13 AM
    For information zidoo-z9x works with Android and zdmc Android boxes with coreelec
    underdog
    2024-05-19, 11:27 AM
    There is really nothing more to explain. You change this in the server settings as described, then it should work on all Kodi clients. If it doesn't work for you, you have to change the jellyfin plugin to "addon" on all clients. Please also take another look at the documentation.
    My personal opinion: The entry "shared network path" should not have been removed from the library settings. I don't know if there was a compelling reason for this decision?
    Consequently, the setting "native" should also have been removed from "jellyfin for kodi".
    Translated with DeepL.com (free version)
    Jellyfin 10.9.2
    Openmediavault 7
    Docker linuxserver
    Omse
    Country:Morocco
    2024-05-19, 12:33 PM
    Thank you for the help
    Omse
    Country:Morocco
    2024-05-21, 07:47 AM
    Hi I followed your method and solved the problem. thanks again
