    Jellyfin Forum Support Troubleshooting Problem with movie identification
    cifri
    Country:Hungary
    2024-05-27, 09:10 AM
    Hi everyone,
    Automatic film identification works (TMDb).
    But if for some reason I want to replace the data using the "identification" option in the menu, it will not be updated.
    I usually use "identification" if it automatically recognizes the film incorrectly, or if OMDb has a better description or a better cover.
    The search result is fine, after I click on the cover I want, it doesn't update in the library.
    I tried to upload just the cover, it also doesn't update, but if I rewrite the title of the movie in the metadata, it's fine.
    However, if I switch to the other service provider (OMDb) in the library settings and update the desired movie, all data is updated, even the cover.
    I have this problem with versions 10.9.2 and 10.9.3, I don't know about 10.9.0-1, but it definitely worked before that.
    OptiPlex 7060 Micro 8GB
    Debian 12
    240GB Kingson SSD
    2, 4, 6, 8 TB HDD
    lx77
    2024-05-27, 03:05 PM
    Is the behavior the same for all files?
    Or does it only occur on folders/files with specific special characters?
    If so, you might wanna take a look at https://forum.jellyfin.org/t-solved-issu...nce-update
