    Jellyfin Forum Support Troubleshooting problem with subs and audio
    wolfgangam
    2024-03-14, 01:45 PM (This post was last modified: 2024-03-14, 03:41 PM by wolfgangam. Edited 2 times in total.)
    here is a log after replicating an error where I start the movie and it just stopped playing.
    also when I started it the second time, the subs were not synced, while they were perfectly fine when started from the beginning.
    https://pastebin.com/xSbhw4XE
    https://pastebin.com/wf13Faeu
    2024-03-14, 07:44 PM
    Can you repost those to https://sourceb.in/ ? My work PC blocks pastebin.
    wolfgangam
    2024-03-15, 01:53 PM
    one of them , yes
    https://sourceb.in/XnkOBVhZxE
    the other gives an error on sourcebin.... "invalid request data"
    2024-03-15, 07:35 PM
    Its probably too large. Can you zip the file and add it as an attachment here?
    wolfgangam
    2024-03-15, 08:13 PM
    yes, there you go
    .zip   Log.zip (Size: 13.67 KB / Downloads: 68)
    2024-03-15, 08:29 PM
    This could just be a WebOS issue. Everything, from the server side, looks ok. Get an Android TV dongle or Roku? I don't know what else you can do.
    Try installing the "Subtitle Extract" plugin then run it. It will pre-extract all your subtitles instead of extracting them on the fly.
    wolfgangam
    2024-03-17, 04:17 PM
    the movie in question doesn't have subs in the file, it separate SRT files and thee issue I'm having that sometimes the movie stops randomly as you saw, and also if I scroll the timeline to any point, the subs are no longer synced and I can not do any offset to fix them, it's like it does nothing.
