    Jellyfin Forum Support Troubleshooting Problems with 4K
    Problems with 4K
    Direct Play Suggested But Black Screen Firestick 4K
    nath69uk
    2023-09-27, 05:34 PM
    Hello all...
    I'm having issues with my Jellyfin install with Firestick 4Ks, the 4K Movies more often will play but with a black screen. Sometimes do not play at all saying an error was encountered.
    Any help would be greatly appreciated.
    2023-09-27, 06:38 PM
    We would need to see your jellyfin logs, ffmpeg logs, and what the media info for the video.
    nath69uk
    2023-09-27, 11:46 PM
    Jelly
    https://pastebin.com/dCYfDu8f
    FF
    https://pastebin.com/42Vt2t31
    Media
    https://pastebin.com/4qaieHCD
    2023-09-28, 12:28 AM
    This looks like a client side bug. But the transcoding is happening because the bitrate is higher than the client max. Try manually setting the max bitrate on the client to 120Mbps.
    nath69uk
    2023-09-28, 08:40 AM
    Adjusting the bitrate to 120mb allows the movie to play but all I have is a black screen.
    2023-09-28, 12:51 PM
    This sounds like a client side bug. IMO, your two options are to select a lower bit rate to force transcoding (if you have "Allow encoding in HEVC format" checked, uncheck it) or perhaps give the beta version of the Jellyfin Android TV app a try. You're not the first person with this kind of issue on a Firestick.
    https://github.com/jellyfin/jellyfin-androidtv/releases
    nath69uk
    2023-09-30, 02:43 PM (This post was last modified: 2023-09-30, 02:46 PM by nath69uk.)
    Thanks for the reply, Ive tried BETA and remains the same black screen with sound.
    One thing Ive noticed though is that when the screens black I lose everything. I cant even see the jellyfin slider or buttons.
    fezster
    2024-01-10, 10:08 AM
    This is because the file has both DolbyVision and HDR10+, which results in a black screen on Fire Tv Stick 4k Max. See this thread for more info: https://github.com/jellyfin/jellyfin-and...ssues/2630
    I have created a fix to force a HW transcode of these files with a new setting, which may work for you: https://forum.jellyfin.org/t-force-trans...ick-4k-max
