    Jellyfin Forum Support Troubleshooting Re-issue of tone mapping
    Just trying to get your attention
    therealgamer9982
    2024-09-27, 08:57 PM
    (2024-09-27, 08:57 PM)TheDreadPirate Wrote: Did you install jellyfin-ffmpeg7?
    sudo apt install jellyfin-ffmpeg7
    It appears not
    therealgamer9982
    2024-09-27, 09:03 PM
    It appears that now its just a white/blank screen?
    Log: https://pastebin.com/9DZJ16Cd
    2024-09-27, 09:11 PM
    What is a black and white screen? The log you shared doesn't show anything was played.
    therealgamer9982
    2024-09-27, 09:15 PM
    (2024-09-27, 09:11 PM)TheDreadPirate Wrote: What is a black and white screen?  The log you shared doesn't show anything was played.
    I had the User Interface in the web for a minute, now it is just a blank screen
    2024-09-27, 09:20 PM (This post was last modified: 2024-09-27, 09:20 PM by TheDreadPirate. Edited 1 time in total.)
    Ctrl+f5, clear your browser cache or use a private/incognito window. There is probably an older, cached version of jellyfin-web in your browser.
    therealgamer9982
    2024-09-27, 09:22 PM (This post was last modified: 2024-09-27, 09:24 PM by therealgamer9982. Edited 1 time in total.)
    (2024-09-27, 09:20 PM)TheDreadPirate Wrote: Ctrl+f5, clear your browser cache or use a private/incognito window.  There is probably an older, cached version of jellyfin-web in your browser.
    I saw in my log somewhere that it dosent have the wwwroot file, which I think would probably be essential, so im going to try and re-install
    Edit: That in fact, did not fix it
    2024-09-27, 09:24 PM (This post was last modified: 2024-09-27, 09:25 PM by TheDreadPirate.)
    Negatory. Don't do that.
    Do what I stated, clear your browser cache. The "no www root" message is harmless. Not sure where it originates from, but it appears in my log and everyone else's log. Both 10.9 and 10.10.
    therealgamer9982
    2024-09-27, 09:26 PM (This post was last modified: 2024-09-27, 09:27 PM by therealgamer9982.)
    (2024-09-27, 09:24 PM)TheDreadPirate Wrote: Negatory.  Don't do that.
    Well I tried private browsing tab, it didnt work and I tried clearing the cache but that didnt work either. I did try re-installing but that didnt work either
    2024-09-27, 09:27 PM (This post was last modified: 2024-09-27, 09:28 PM by TheDreadPirate.)
    Farther up the log you will see that wwwroot is actually in /usr/share/jellyfin.
    sudo apt list --installed | grep jellyfin
    What is the output of that command?
    therealgamer9982
    2024-09-27, 09:28 PM (This post was last modified: 2024-09-27, 09:29 PM by therealgamer9982.)
    (2024-09-27, 09:27 PM)TheDreadPirate Wrote: Farther up the log you will see that wwwroot is actually in /usr/share/jellyfin.
    It is infact still not there, and there is only the web folder with one json file in it
    Output is
    jellyfin-ffmpeg7/unknown,now 7.0.2-2-noble amd64 [installed]
    jellyfin-server/now 2024092305+deb12 amd64 [installed,local]
