    Jellyfin Forum Support Troubleshooting Re-issue of tone mapping
    Just trying to get your attention
    therealgamer9982
    2024-09-27, 11:11 PM
    (2024-09-27, 09:28 PM)therealgamer9982 Wrote:
    (2024-09-27, 09:27 PM)TheDreadPirate Wrote: Farther up the log you will see that wwwroot is actually in /usr/share/jellyfin.
    It is infact still not there, and there is only the web folder with one json file in it
    sudo apt list --installed | grep jellyfin
    What is the output of that command?
    Output is
    jellyfin-ffmpeg7/unknown,now 7.0.2-2-noble amd64 [installed]
    jellyfin-server/now 2024092305+deb12 amd64 [installed,local]
    Hey So I found this issue that is very similar to mine: https://forum.jellyfin.org/t-solved-andr...ode=linear
    Would there be any way to rebuild the "standard" install of jellyfin?
    2024-09-28, 12:33 AM
    You'd have to purge Jellyfin and switch back to the stable repo.
    sudo mv /var/lib/jellyfin /var/lib/unstableJellyfin
    sudo mv /etc/jellyfin /etc/unstableJellyfin
    sudo apt purge jellyfin*
    Switch /etc/apt/sources.list.d/jellyfin.sources "Components" back to main.
    Then
    therealgamer9982
    2024-09-28, 12:37 AM
    (2024-09-28, 12:33 AM)TheDreadPirate Wrote: You'd have to purge Jellyfin and switch back to the stable repo.
    Then
    Ok, then how do I safely upgrade it to the beta
    therealgamer9982
    2024-09-28, 01:03 AM
    Then
    Now its, when transcoding, giving me a source playback error
    Log: https://pastebin.com/cfAUfNnf
    2024-09-28, 01:08 AM (This post was last modified: 2024-09-28, 01:09 AM by TheDreadPirate.)
    Go to the dashboard and tell me what the build number is? This was a bug in a release a couple weeks ago that I thought was fixed.
    Wait....is this 10.9.11 with jellyfin-ffmpeg7? If so.
    sudo apt remove jellyfin-ffmpeg7
    sudo apt install jellyfin-ffmpeg6
    therealgamer9982
    2024-09-28, 01:09 AM (This post was last modified: 2024-09-28, 01:13 AM by therealgamer9982. Edited 1 time in total.)
    (2024-09-28, 01:08 AM)TheDreadPirate Wrote: Go to the dashboard and tell me what the build number is?  This was a bug in a release a couple weeks ago that I thought was fixed.
    2024092305
    Its 10.10.0
    2024-09-28, 01:40 AM
    Oof.  I'm having HDR tone mapping issues of my own on 10.10.    Moai
    therealgamer9982
    2024-09-28, 01:45 AM
    (2024-09-28, 01:40 AM)TheDreadPirate Wrote: Oof.  I'm having HDR tone mapping issues of my own on 10.10.    Moai
    Thats fine, yours works at the very least.
    So what the heck is going on with mine?
    Log: https://pastebin.com/sAEnDdez
    2024-09-28, 01:46 AM
    Almost certainly a bug. Report it here. I'm about to report mine to the jellyfin-ffmpeg git.
    therealgamer9982
    2024-09-28, 01:47 AM
    (2024-09-28, 01:46 AM)TheDreadPirate Wrote: Almost certainly a bug.  Report it here.  I'm about to report mine to the jellyfin-ffmpeg git.
    What build version are you on?
