    Jellyfin Forum Support Troubleshooting Re-issue of tone mapping
    Pages (4): « Previous 1 2 3 4
    Just trying to get your attention
    2024-09-28, 01:58 AM (This post was last modified: 2024-09-28, 01:58 AM by TheDreadPirate.)
    Same build. 2024092305. The problem for you is that the TranscodeHelper on the server did not construct the ffmpeg command properly. There is a comma or bracket or something missing and parameters aren't being read in correctly. In my case, the VPP driver bundled with Jellyfin is borked.
    therealgamer9982
    2024-09-28, 02:15 AM
    (2024-09-28, 01:58 AM)TheDreadPirate Wrote: Same build.  2024092305.  The problem for you is that the TranscodeHelper on the server did not construct the ffmpeg command properly.  There is a comma or bracket or something missing and parameters aren't being read in correctly.  In my case, the VPP driver bundled with Jellyfin is borked.
    Well I made an issue. Man open source is great, but it can be a pain sometimes.
    therealgamer9982
    2024-09-28, 03:01 AM
    Oh yes, once they fix it, how will the update get to me?
    2024-09-28, 03:15 AM
    Unstable releases are pushed out once a week. If they merge a fix it should show up in the following week's update. You'd use "sudo apt update ; sudo apt upgrade" whenever that happens to pull down the updated packages.
    In my case I'd pull down the latest docker image.
    therealgamer9982
    2024-09-30, 10:58 PM
    (2024-09-28, 03:15 AM)TheDreadPirate Wrote: Unstable releases are pushed out once a week.  If they merge a fix it should show up in the following week's update.  You'd use "sudo apt update ; sudo apt upgrade" whenever that happens to pull down the updated packages.
    Welp it seems that the issue has in fact, gotten worse.
    Thats fun.
    therealgamer9982
    2024-09-30, 11:06 PM (This post was last modified: 2024-09-30, 11:28 PM by therealgamer9982. Edited 1 time in total.)
    I FOUND THIS
    [h264_vaapi @ 0x5bcd48a96000] Driver does not support some wanted packed headers (wanted 0xd, found 0x1).
    [hls @ 0x5bcd48a9bf40] Opening '/var/cache/jellyfin/transcodes/b2262b30b18b40fdfcda2e2f59e16637-1.mp4' for writing
    Output #0, hls, to '/var/cache/jellyfin/transcodes/b2262b30b18b40fdfcda2e2f59e16637.m3u8':
    Ok so Mr. Pirate (Im gonna call you that) can you please tell me what Mesa version you have and what VA-API version you have.
    therealgamer9982
    2024-10-01, 12:12 AM (This post was last modified: 2024-10-01, 01:15 AM by therealgamer9982. Edited 1 time in total.)
    so apparently vainfo and
    sudo /usr/lib/jellyfin-ffmpeg/vainfo --display drm --device /dev/dri/renderD128
    display different things...???
    AH HA! Apparently, it wasent decoding or tone mapping that was the problem, it was hardware encoding!
    gnattu
    #38
    2024-10-01, 01:29 AM
    If that is the case then welcome to the AMD encoder quality party. We have multiple user reported the quality issues about AMD encoders both in the forum and GitHub. Unfortunately we can do little if it is really the case. We have something way worse like reported here: https://github.com/jellyfin/jellyfin/discussions/12745
    therealgamer9982
    2024-10-01, 01:31 AM (This post was last modified: 2024-10-01, 01:38 AM by therealgamer9982. Edited 3 times in total.)
    (2024-10-01, 01:29 AM)gnattu Wrote: > it was hardware encoding
    Good thing my cpu is decent enough, cuz Ill just use that for now.
    But like...
    Whyyyyyyyyy....
    Whhyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy.........................................................
    Also, I have found that the only option that causes this crap is under hardware encoding, enable hardware encoding. The intel one (which im not even sure works on my amd gpu/cpu but whatev) works perfectly fine so what gives??
