    Jellyfin Forum Support Troubleshooting Networking & Access Remote connection only work from same wifi?
    Mr-Brightside
    2023-11-02, 03:34 AM
    So, my jellyfin server has always worked fine on the local network.
    Now I want to setup remote access from the internet. I set it up, and it seemed to work, as entering the severs external IP address (double checked on whatsmyip.org) got me to my server. but when I tried actually accessing it from an external network it didn't work.
    Could this be a DNS issue? Routing issue?
    2023-11-02, 03:42 AM
    How did you set up your external access? Port forwarding? Would definitely recommend against that in favor of a more secure solution.
    To dig a little further we'd need to know your server OS. The generic answer is to check your firewall, open the necessary port there (e.g., ufw, Windows firewall). Other complex issues can include various ISP-implemented barriers to get around, but those are a bit out of my depth.
    If possible, reverse proxy is more secure and flexible than port forwarding. It can certainly be intimidating at first, but there are easy solutions depending on your host and installation method.
