    Jellyfin Forum Support Troubleshooting Seeking Help with Adding Media issue (LINUX)
    Having issue with Adding Media
    Gotta
    2024-09-30, 04:48 AM (This post was last modified: 2024-09-30, 04:50 AM by Gotta. Edited 1 time in total.)
    Hello, I'm having three issues at the moment.
    System:
      Kernel: 6.8.0-45-generic x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.18.1 tk: Gtk 3.24.33
        info: xfce4-panel wm: xfwm 4.18.0 vt: 7 dm: LightDM 1.30.0 Distro: Linux Mint 21.3 Virginia
        base: Ubuntu 22.04 jammy
    Jellyfin Server - 10.9.11
    --Problem 1--
    When i go to Add Media it gives me this Prompt
    "The path could not be found. Please ensure the path is valid and try again."
    using my google-fu i came across a few threads with people having similar issues.
    someone had mentioned Flatpaks run it as the USER / OWNER?
    and that the CLi of the updated installation the USER could be Jellyfin instead, and that you would have to give Read/Write Permissions to it (I have no idea how i would go about doing this)
    On the Previous version everything was working ( besides allowing outside connections to the server, which got me looking up the issue, and someone said it may because im using an out of date version? )
    it should be noted that the Media is stored on Multiple Hard Drives - im trying to add in, which is on another drive for example.
    Quote:/media/mert/New Volume/uTorrent
    --Problem 2--
    I'm currently having an issue where Outside connections are unable to connect to the server - which im starting to think it's a Linux issue, possibly Firewall, because i used to run Win10 host and it worked fine.
    --Problem 3--
    Because i installed via CLi - my old Jellyfin Server Icon tries to host the Previous Version and not 10.9.11 - i had to re-run "
    Here's the entire prompt of the installation process of the CLi command
    mert@mert:~$ curl https://repo.jellyfin.org/install-debuntu.sh | sudo bash
      % Total    % Received % Xferd  Average Speed  Time    Time    Time  Current
                                    Dload  Upload  Total  Spent    Left  Speed
      0    0    0    0    0    0      0      0 --:--:-- --:--:-- --:--:--    0[s100 10606  100 10606    0    0  92323      0 --:--:-- --:--:-- --:--:-- 93035
    Sorry, try again.
    [sudo] password for mert:
    > Determining optimal repository settings.
    Found the following details from '/etc/os-release':
      Real OS:            linuxmint
      Repository OS:      ubuntu
      Repository Release: jammy
      CPU Architecture:  amd64
    If this looks correct, press <Enter> now to continue installing Jellyfin.
    > Fetching repository signing key.
    > Installing Jellyfin repository into APT.
    Types: deb
    URIs: https://repo.jellyfin.org/ubuntu
    Suites: jammy
    Components: main
    Architectures: amd64
    Signed-By: /etc/apt/keyrings/jellyfin.gpg
    > Updating APT repositories.
    Hit:1 http://ubuntu.mirror.rafal.ca/ubuntu jammy InRelease
    Hit:2 http://ubuntu.mirror.rafal.ca/ubuntu jammy-updates InRelease
    Hit:3 http://ubuntu.mirror.rafal.ca/ubuntu jammy-backports InRelease
    Get:4 http://security.ubuntu.com/ubuntu jammy-security InRelease [129 kB]
    Ign:5 https://mirror.csclub.uwaterloo.ca/linuxmint-packages virginia InRelease
    Hit:6 https://mirror.csclub.uwaterloo.ca/linuxmint-packages virginia Release
    Get:8 https://repo.jellyfin.org/ubuntu jammy InRelease [6,660 B]
    Fetched 136 kB in 1s (246 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    All packages are up to date.
    > Installing Jellyfin.
    jellyfin is already the newest version (10.9.11+ubu2204).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    > Waiting 15 seconds for Jellyfin to fully start up.
    ● jellyfin.service - Jellyfin Media Server
        Loaded: loaded (/lib/systemd/system/jellyfin.service; enabled; vendor preset: enabled)
        Drop-In: /etc/systemd/system/jellyfin.service.d
                └─jellyfin.service.conf
        Active: active (running) since Mon 2024-09-30 03:33:08 EDT; 3h 55min left
      Main PID: 2052 (jellyfin)
          Tasks: 20 (limit: 154202)
        Memory: 283.4M
            CPU: 4.427s
        CGroup: /system.slice/jellyfin.service
                └─2052 /usr/bin/jellyfin --webdir=/usr/share/jellyfin/web --ffmpeg…
    Sep 30 03:33:10 mert jellyfin[2052]: [03:33:10] [INF] Available decoders: ["lib…
    Sep 30 03:33:10 mert jellyfin[2052]: [03:33:10] [INF] Available encoders: ["lib…
    Sep 30 03:33:11 mert jellyfin[2052]: [03:33:11] [INF] Available filters: ["dein…
    Sep 30 03:33:11 mert jellyfin[2052]: [03:33:11] [INF] Available hwaccel typ…an"]
    Sep 30 03:33:11 mert jellyfin[2052]: [03:33:11] [INF] FFmpeg: /usr/lib/jell…mpeg
    Sep 30 03:33:11 mert jellyfin[2052]: [03:33:11] [INF] ServerId: e5f30696996…0899
    Sep 30 03:33:11 mert jellyfin[2052]: [03:33:11] [INF] Core startup complete
    Sep 30 03:33:11 mert jellyfin[2052]: [03:33:11] [INF] Startup complete 0:00…5323
    Sep 30 03:33:13 mert jellyfin[2052]: [03:33:13] [INF] Clean up collections …onds
    Sep 30 03:33:14 mert jellyfin[2052]: [03:33:14] [INF] Update Plugins Comple…onds
    Hint: Some lines were ellipsized, use -l to show in full.
    You should see the service as 'active (running)' above. If not, use https://jellyfin.org/contact to find us for troubleshooting.
    You can access your new instance now at http://10.0.0.135:8096 in your web browser to finish setting up Jellyfin.
    Thank you for installing Jellyfin, and happy watching!
    Thanks, Chris
    2024-09-30, 01:44 PM
    This is your problem.
    This the udisk2 mount location for secondary storage.  udisk2 will place an ACL (access control list) on /media/mert, which is preventing the jellyfin user from accessing that location.  You could remove the ACL, but that is a temporary solution.  The proper solution is to mount this storage via /etc/fstab.
    I've written a guide for mounting drives via /etc/fstab.  And it doubles as a linux permissions primer to help understand why this happens.
    https://forum.jellyfin.org/t-mounting-lo...ons-primer
