    Jellyfin Forum Support Troubleshooting SOLVED: 4K Playback Issues on LG Smart TV with Jellyfin Web 10.10.3
    Toshels
    2024-11-22, 10:23 AM
    Hi everyone,
    I have Jellyfin set up in a Docker container using a 1050ti for transcoding. Everything works great on most devices (Windows, Android phone, PC), but I'm having an issue with my LG Smart TV running Jellyfin Web 10.10.3. When I try to play a 4K movie with Dolby TrueHD audio, the video takes a long time to load, plays for about 2 seconds, then goes back to loading for around 3 minutes.
    I’ve installed the NVIDIA container tools, and my driver version is 535.183.01 with CUDA version 12.2.
    As a newbie, I'm struggling to figure out why this is happening. Here’s my log file for reference, and I’ve also attached screenshots from the transcoding section. Any help would be appreciated!
    .txt   Log.txt (Size: 102.94 KB / Downloads: 124)
    2024-11-22, 01:54 PM
    AFAICT, the server side of things is fine. It is transcoding at 5x real time.
    BUT, the bit rate on the video is pretty high. ~65Mbps. Can you verify the speed and consistency of the network connection on your WebOS TV?
    Toshels
    2024-11-22, 09:09 PM
    (2024-11-22, 01:54 PM)TheDreadPirate Wrote: AFAICT, the server side of things is fine.  It is transcoding at 5x real time.
    You were right, my network connection wasnt fast enough. Switching to wired connection solved the issue.
