2023-08-14, 07:45 AM
(This post was last modified: 2023-10-01, 11:10 AM by happyvoid. Edited 4 times in total.)
Android 13.1 (ArrowOS)
Jellyfin 2.5.2
Connecting to Samsung GU43AU7179U TV works fine, however while image and sound play fine on Android device as soon as connection to Samsung TV is established, the image is mirrored. On the TV the image then is choppy, it is delayed and gets stuck for a few seconds. The sound is similarly choppy.
Jellyfin on iOS works fine via AirPlay - both image and sound are without artifacts and play smoothly.
While there is https://github.com/jellyfin/jellyfin-tizen is there a way to make screen cast from Android to Samsung TV work? https://smartdigihere.com/jellyfin-on-samsung-smart-tv/ mentions a few options but does not have info on screen cast.
Edit: Update: testing this with a second device running ArrowOS 13.1 and found Screen Cast works without issues on nabu device while when using lisa device getting the choppy image and audio.
Jellyfin 2.5.2
