    Jellyfin Forum Support Troubleshooting SOLVED: Audio but no video using Jellyfin Media Player
    2024-05-05, 02:07 AM (This post was last modified: 2024-05-05, 02:07 AM by TheDreadPirate.)
    C:\Users\yourUser\AppData\Local\JellyfinMediaPlayer\jellyfinmediaplayer.conf
    Can you provide a first run and second version of that file?
    Will
    2024-06-14, 06:56 PM
    I just updated Jellyfin server to 10.9.4 and Jellyfin play is now 1.11.1 and I'm still having the same issue.
    Jellyfin 10.9.4
    Fedora 40
    AMD Ryzen 7 2700X
    Asus ROG Strix B450-F
    32GB DDR4-3000
    Nvidia Quadro P620
    Samsung 970 EVO Plus 500GB
    WD Black SN750 1TB
    8 x WD Red 4TB, 4 x WD Green 2TB
    LSI 9300-16i
    2024-06-14, 07:54 PM
    Reinstall graphics drivers on the clients? IDK at this point.
    Will
    2024-06-18, 04:45 PM
    I managed to fix it. I noticed when I fully removed the media player from a different computer and installed the latest, on first launch none of the images or text lines up. I checked on the server side, and there actually was CSS code in the "Custom CSS Code" text box. I have no idea why it was there, but I removed it, and now everything works perfectly!
    Jellyfin 10.9.4
    Fedora 40
    AMD Ryzen 7 2700X
    32GB DDR4-3000
    Nvidia Quadro P620
    WD Black SN750 1TB
    LSI 9300-16i
    vanon
    2024-10-19, 02:12 AM
    (2024-05-02, 10:08 PM)TheDreadPirate Wrote: Uninstall, delete C:\Users\yourUser\appdata\local\jellyfinmediaplayer, reinstall.
    AV1 stopped playing for me (JMP 1.11.1, Windows 11, JF Server 10.9.11). Black screen with audio (info said it was directly playing). I did not uninstall, only removed the folder (\appdata\local\jellyfinmediaplayer) and that fixed it, AV1 is now playing fine. Thank you. Good to know where the settings are, quick and easy way to reset.
