    Jellyfin Forum Support Troubleshooting SOLVED: Collection problem
    Collection problem with recent updates
    Afgin
    Country:Finland
    #11
    2024-05-22, 05:08 PM
    (2024-05-22, 04:53 PM)TheDreadPirate Wrote: We can work through that.
    What is the output of this command?
    sudo cat /proc/mounts | egrep "/media/mutka/Seagatetwo|/media/mutka/Exos1"
    dev/sdb2 /media/mutka/Seagatetwo exfat rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,iocharset=utf8,errors=remount-ro 0 0
    /dev/sda2 /media/mutka/Exos1 ntfs3 rw,nosuid,nodev,relatime,uid=1000,gid=1000,windows_names,iocharset=utf8 0 0
    /dev/sdc2 /media/mutka/seagate ntfs3 rw,nosuid,nodev,relatime,uid=1000,gid=1000,windows_names,iocharset=utf8 0 0
    also added the third drive with same command
    2024-05-22, 05:36 PM
    sudo systemctl stop jellyfin
    sudo umount /media/mutka/Seagatetwo
    sudo umount /media/mutka/Exos1
    sudo umount /media/mutka/seagate
    sudo vim /etc/fstab
    At the bottom of /etc/fstab put this in
    /dev/sda2 /media/mutka/Exos1 ntfs defaults 0 0
    /dev/sdb2 /media/mutka/Seagatetwo exfat defaults 0 0
    /dev/sdc2 /media/mutka/seagate ntfs defaults 0 0
    Then save, quit.
    sudo mount -a
    This will mount all the drives defined in /etc/fstab.
    Let me know if you run into any problems.
    Afgin
    Country:Finland
    #13
    2024-05-22, 05:42 PM
    trying to unmount with umount. "target is busy" dunno which is using it
    2024-05-22, 05:58 PM
    Reboot. It will apply the new mount parameters during boot up.
    Afgin
    Country:Finland
    #15
    2024-05-22, 06:01 PM (This post was last modified: 2024-05-22, 06:05 PM by Afgin.)
    (2024-05-22, 05:58 PM)TheDreadPirate Wrote: Reboot.  It will apply the new mount parameters during boot up.
    Yea I did that, and this was a result after sudo mount -a
    ntfs-3g-mount: failed to access mountpoint /media/mutka/Exos1: No such file or directory
    mount: /media/mutka/Seagatetwo: mount point does not exist.
    # /etc/fstab: static file system information.
    # Use 'blkid' to print the universally unique identifier for a
    # device; this may be used with UUID= as a more robust way to name devices
    # that works even if disks are added and removed. See fstab(5).
    # <file system> <mount point> <type> <options> <dump> <pass>
    # / was on /dev/nvme0n1p2 during installation
    UUID=593b83f6-03bf-4388-bef1-424af1e22c05 / ext4 errors=remount-ro 0 1
    # /boot/efi was on /dev/nvme0n1p1 during installation
    UUID=8248-C7D1 /boot/efi vfat umask=0077 0 1
    /swapfile none swap sw 0 0
    this is what the fstab file looks like. does UUID things interfere? Tried also with putting hash infront of them
    Afgin
    Country:Finland
    #16
    2024-05-22, 06:10 PM
    I have an itch that the problem with the Exos is that it is asleep. In the disk management there is zzz icon. It has only woken up by pressing the icon. Then it wakes and mounts
    2024-05-22, 06:17 PM
    Ah. The place we told it to mount to doesn't exist. I assumed the folders were still there from the previous mounts.
    sudo mkdir -p /media/mutka/Exos1 /media/mutka/Seagatetwo /media/mutka/seagate
    Then try "sudo mount -a" or reboot.
    Afgin
    Country:Finland
    #18
    2024-05-22, 06:23 PM
    (2024-05-22, 06:17 PM)TheDreadPirate Wrote: Ah. The place we told it to mount to doesn't exist.  I assumed the folders were still there from the previous mounts.
    Hey. I did a reboot, and now it seems to auto mount! I didn't need to click on the icon. jellyfin server found and played the files straight. So it should be fine now I guess.
    Now that second part where mounting is ensured before jellyfin launches?
    2024-05-22, 06:32 PM (This post was last modified: 2024-05-22, 06:32 PM by TheDreadPirate. Edited 1 time in total.)
    You shouldn't need to do that part anymore.
    Afgin
    Country:Finland
    #20
    2024-05-22, 06:41 PM
    Seems to work right. Smiling-face
    You are amazing man! Thank you so much for helping me.
    Was kinda scared at one point that something will go very wrong, but it all went perfect in the end. Grinning-face
