    Jellyfin Forum Support Troubleshooting SOLVED: Help with transcoding
    Slow transcoding issue.
    Deegee88
    2024-06-06, 06:38 PM
    I’m running 6.8.0-31-generic
    How did you get that screenshot? From the logs?
    Mine are just the lines of code etc that I copy into sourcebin.
    Only time I get anything close to that is if I click the (i) playback info in the dashboard.
    Jellyfin 10.10.3
    Ubuntu Desktop LTS 24.04
    Intel Xeon E5-1650 v3
    64GB DDR4
    2024-06-06, 06:47 PM
    In the player, click the gear in the bottom right and then playback info.
    What is the output of the following commands.
    sudo cat /sys/kernel/debug/dri/1/gt0/uc/guc_info
    sudo cat /sys/kernel/debug/dri/1/gt0/uc/huc_info
    grep i915 /var/log/dmesg*
    Deegee88
    2024-06-06, 06:51 PM
    sudo cat /sys/kernel/debug/dri/1/gt0/uc/guc_info:
    https://sourceb.in/uRXB9D9MEL
    https://sourceb.in/00YE56xqjz
    https://sourceb.in/2lCPQ31oH5
    Jellyfin 10.10.3
    64GB DDR4
    2024-06-06, 07:06 PM
    These are the only lines different from mine.
    kernel: i915 0000:05:00.0: [drm] Cannot find any crtc or sizes
    @gnattu @nyanmisaka
    Do you have any ideas? Is this a firmware level issue or something else I'm not aware of? Does it matter if a display is connect to the card or not?
    Deegee88
    2024-06-09, 02:07 PM
    Hi guys - just wondering if there has been any further thoughts on this?
    I've been having a look over the last couple of days but had no luck!
    Jellyfin 10.10.3
    64GB DDR4
    2024-06-09, 05:27 PM
    Do you have a monitor plugged into the system?
    Deegee88
    2024-06-09, 05:59 PM
    Ummm no - in neither of the GPUs
    I only access it remotely via SSH and don’t have the room to have it plugged into a monitor permanently.
    Could that seriously be what’s stopping it from working properly?
    Jellyfin 10.10.3
    64GB DDR4
    2024-06-09, 06:48 PM
    Maybe. I've heard that early firmware Intel Arc GPUs had weird behaviors when no monitor was plugged in. The problem is that easy firmware updates are only available in Intels Windows driver installer. I found a way Level1Techs thread for updating firmware in Linux, but haven't gotten around to trying it out.
    2024-06-09, 07:03 PM
    This process appears to work and is fairly straight forward.
    https://forum.level1techs.com/t/remember...nux/208736
    Update at your own risk. As with all firmware flashes, loss of power during the process is very very bad.
    One thing I almost missed was the "FW Data pack" download link.
    2024-06-09, 07:14 PM
    FYI, I was able to update my A380 with this process.
