    Jellyfin Forum Support Troubleshooting SOLVED: How to fix "WebRootPath was not found" error
    Prior to 10.9.1, Jellyfin started fine as a service via systemctl, now it fails to host the web client
    theolaa
    2024-05-13, 06:23 AM (This post was last modified: 2024-05-13, 06:43 AM by theolaa. Edited 2 times in total.)
    Hello, I recently updated my Jellyfin server to 10.9.1 which runs on a Linux Mint 20.3 box.
    Previously there was no issue starting Jellyfin as a service, but now I am getting this error when starting Jellyfin:
    May 12 22:58:42 THEO-FILE-SERVER jellyfin[1282]: [22:58:42] [WRN] The WebRootPath was not found: /var/lib/jellyfin/wwwroot. Static files may be unavailable.
    May 12 22:58:42 THEO-FILE-SERVER jellyfin[1282]: [22:58:42] [ERR] Hosting failed to start
    So it seems there is some issue with hosting the web client, but I don't know how to fix this.
    I would be very grateful if anyone has some advice for this situation.
    Thanks,
    Theo L
    Here is the full stack trace (retrieved using sudo systemctl status jellyfin -n 100):
    May 12 23:35:27 THEO-FILE-SERVER systemd[1]: Started Jellyfin Media Server.
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Jellyfin version: 10.9.1
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Environment Variables: ["[JELLYFIN_ADDITIONAL_OPTS, ]", "[JELLYFIN_FFMPEG_OPT, --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg]","[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_WEB_OPT, --webdir=/usr/share/jellyfin/web]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[JELLYFIN_USER, jellyfin]","[JELLYFIN_ARGS, $JELLYFIN_WEB_OPT $JELLYFIN_FFMPEG_OPT $JELLYFIN_SERVICE_OPT $JELLYFIN_NOWEBAPP_OPT $JELLFIN_ADDITIONAL_OPTS --datadir $JELLYFIN_DATA_DIR --configdir $JELLYFIN_CONFIG_DIR --logdir $JELLYFIN_LOG_DIR --cachedir $JELLYFIN_CACHE_DIR]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]"]
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--webdir=/usr/share/jellyfin/web", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Operating system: Linux Mint 20.3
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Architecture: X64
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] 64-Bit Process: True
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] User Interactive: True
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Processor count: 8
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Program data path: /var/lib/jellyfin
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Log directory path: /var/log/jellyfin
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Config directory path: /etc/jellyfin
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Cache path: /var/cache/jellyfin
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Web resources path: /usr/share/jellyfin/web
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Application directory: /usr/lib/jellyfin/bin/
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Setting cache path: /var/cache/jellyfin
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Loading assemblies
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Loaded assembly Jellyfin.Plugin.OpenSubtitles, Version=20.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/jellyfin/plugins/Open Subtitles_20.0.0.0/Jellyfin.Plugin.OpenSubtitles.dll
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Loaded assembly Jellyfin.Plugin.SubtitleExtract, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/jellyfin/plugins/Subtitle Extract_4.0.0.0/Jellyfin.Plugin.SubtitleExtract.dll
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Defined LAN addresses: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Defined LAN exclusions: []
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Using LAN addresses: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Using bind addresses: ["127.0.0.1", "192.168.0.100"]
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Remote IP filter is Allowlist
    May 12 23:35:30 THEO-FILE-SERVER jellyfin[1378]: [23:35:30] [INF] Filter list: []
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Loaded plugin: Open Subtitles 20.0.0.0
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Loaded plugin: Subtitle Extract 4.0.0.0
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Loaded plugin: TMDb 10.9.1.0
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Loaded plugin: Studio Images 10.9.1.0
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Loaded plugin: OMDb 10.9.1.0
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Loaded plugin: MusicBrainz 10.9.1.0
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Loaded plugin: AudioDB 10.9.1.0
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Kestrel is listening on 127.0.0.1
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Kestrel is listening on 192.168.0.100
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Kestrel is listening on 10.5.0.2
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [WRN] The WebRootPath was not found: /var/lib/jellyfin/wwwroot. Static files may be unavailable.
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [ERR] Hosting failed to start
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: System.Net.Sockets.SocketException (99): Cannot assign requested address
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at System.Net.Sockets.Socket.Bind(EndPoint localEP)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketTransportOptions.CreateDefaultBoundListenSocket(EndPoint endpoint)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketConnectionListener.Bind()
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketTransportFactory.BindAsync(EndPoint endpoint, CancellationToken cancellationToken)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Infrastructure.TransportManager.BindAsync(EndPoint endPoint, ConnectionDelegate connectionDelegate, EndpointConfig endpointConfig, CancellationToken cancellationToken)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServerImpl.<>c__DisplayClass28_0`1.<<StartAsync>g__OnBind|0>d.MoveNext()
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: --- End of stack trace from previous location ---
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindEndpointAsync(ListenOptions endpoint, AddressBindContext context, CancellationToken cancellationToken)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Core.ListenOptions.BindAsync(AddressBindContext context, CancellationToken cancellationToken)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.EndpointsStrategy.BindAsync(AddressBindContext context, CancellationToken cancellationToken)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindAsync(ListenOptions[] listenOptions, AddressBindContext context, Func`2 useHttps, CancellationToken cancellationToken)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServerImpl.BindAsync(CancellationToken cancellationToken)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServerImpl.StartAsync[TContext](IHttpApplication`1 application, CancellationToken cancellationToken)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.AspNetCore.Hosting.GenericWebHostService.StartAsync(CancellationToken cancellationToken)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.Extensions.Hosting.Internal.Host.<StartAsync>b__15_1(IHostedService service, CancellationToken token)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.Extensions.Hosting.Internal.Host.ForeachService[T](IEnumerable`1 services, CancellationToken token, Boolean concurrent, Boolean abortOnFirstException, List`1 exceptions, Func`3 operation)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [ERR] Kestrel failed to start! This is most likely due to an invalid address or port bind - correct your bind configuration in network.xml and try again
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [FTL] Error while starting server
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]:    at Jellyfin.Server.Program.StartServer(IServerApplicationPaths appPaths, StartupOptions options, IConfiguration startupConfig)
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Running query planner optimizations in the database... This might take a while
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Disposing CoreAppHost
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Disposing MusicBrainzArtistProvider
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Disposing MusicBrainzAlbumProvider
    May 12 23:35:34 THEO-FILE-SERVER jellyfin[1378]: [23:35:34] [INF] Disposing PluginManager
    May 12 23:35:34 THEO-FILE-SERVER systemd[1]: jellyfin.service: Succeeded.
    Jellyfin 10.9.3
    Ubuntu 24.04 LTS | Kernel 6.8
    Intel i3 10100
    8GB DDR4
    4TB File Server
    8TB Media Server
    12TB Backup media
    2024-05-13, 11:39 AM (This post was last modified: 2024-05-13, 11:40 AM by TheDreadPirate. Edited 1 time in total.)
    The WebRootPath message is harmless. I also see it in my log and it hasn't been a problem.
    The actual problem is this message.
    This sounds like you have another jellyfin instance running on the same port. Or you specified a bind IP that is no longer available.
    theolaa
    2024-05-13, 03:07 PM
    (2024-05-13, 11:39 AM)TheDreadPirate Wrote: This sounds like you have another jellyfin instance running on the same port.  Or you specified a bind IP that is no longer available.
    Interesting, do you know where I can find the config for the network settings?
    Jellyfin 10.9.3
    Intel i3 10100
    8GB DDR4
    4TB File Server
    8TB Media Server
    12TB Backup media
    2024-05-13, 04:38 PM
    /etc/jellyfin/network.xml has all your network related configs, including ports, bind addresses, LAN addresses, etc.
    theolaa
    2024-05-13, 06:16 PM
    (2024-05-13, 04:38 PM)TheDreadPirate Wrote: /etc/jellyfin/network.xml has all your network related configs, including ports, bind addresses, LAN addresses, etc.
    Thanks a bunch. I'll look into this when I'm home later.
    Jellyfin 10.9.3
    Intel i3 10100
    8GB DDR4
    4TB File Server
    8TB Media Server
    12TB Backup media
    theolaa
    2024-05-14, 12:06 AM
    Here is my network.xml file:
    <?xml version="1.0" encoding="utf-8"?>
    <NetworkConfiguration xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
      <BaseUrl />
      <EnableHttps>false</EnableHttps>
      <RequireHttps>false</RequireHttps>
      <CertificatePath />
      <CertificatePassword />
      <InternalHttpPort>8096</InternalHttpPort>
      <InternalHttpsPort>8920</InternalHttpsPort>
      <PublicHttpPort>8096</PublicHttpPort>
      <PublicHttpsPort>8920</PublicHttpsPort>
      <AutoDiscovery>true</AutoDiscovery>
      <EnableUPnP>false</EnableUPnP>
      <EnableIPv4>true</EnableIPv4>
      <EnableIPv6>false</EnableIPv6>
      <EnableRemoteAccess>true</EnableRemoteAccess>
      <LocalNetworkSubnets />
      <LocalNetworkAddresses />
      <KnownProxies />
      <IgnoreVirtualInterfaces>true</IgnoreVirtualInterfaces>
      <VirtualInterfaceNames>
        <string>veth</string>
      </VirtualInterfaceNames>
      <EnablePublishedServerUriByRequest>false</EnablePublishedServerUriByRequest>
      <PublishedServerUriBySubnet />
      <RemoteIPFilter />
      <IsRemoteIPFilterBlacklist>false</IsRemoteIPFilterBlacklist>
    </NetworkConfiguration>
    I ran a port scanner and I can confirm that I don't have any services running on either port 8096 or 8920. What did you mean earlier about specifying a bind IP that is no longer available? The file doesn't have any IPs specified anywhere, is it maybe missing something somewhere then?
    Jellyfin 10.9.3
    Intel i3 10100
    8GB DDR4
    4TB File Server
    8TB Media Server
    12TB Backup media
    theolaa
    2024-05-14, 12:45 AM (This post was last modified: 2024-05-14, 12:45 AM by theolaa. Edited 1 time in total.)
    I believe I have fixed the issue. I read that removing the network.xml file will cause the server to regenerate it on next startup, so I moved it to my Documents as a backup, and rebooted my machine. The jellyfin service then regenerated its network.xml file and successfully started itself. Thank you for your advice!
    Jellyfin 10.9.3
    Intel i3 10100
    8GB DDR4
    4TB File Server
    8TB Media Server
    12TB Backup media
