    Jellyfin Forum Support Troubleshooting SOLVED: Jellyfin does not trancscode 4K HEVC in web player
    Pages (3): « Previous 1 2 3
    bioblatt
    2024-08-07, 08:01 PM
    update, I'm now on kernel 6.9.7+bpo-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.9.7-1~bpo12+1 (2024-07-03) x86_64 GNU/Linux
    and jellyfin 10.9.9 but the problem still occurs. My server can't transcode any 4K HEVC content via the web player using Firefox or on some devices in the Android Jellyfin app with the default player.
    bioblatt
    2024-08-07, 08:51 PM
    also upgrading to debian sid (6.10.3-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.10.3-1 (2024-08-04) x86_64 GNU/Linux) has not solved the issue
    2024-08-07, 09:00 PM
    Can you share some logs from these latest attempts?
    2024-08-07, 09:28 PM
    Oh. And screenshots of Dashboard > Playback. You haven't shared any since the first page of this thread.
    bioblatt
    2024-08-08, 05:49 PM (This post was last modified: 2024-08-08, 06:06 PM by bioblatt. Edited 3 times in total.)
    Sure Smiling-face here's everything:
    uname -r
    6.10.3-amd64
    lspci -nn | grep -Ei "3d|display|vga"
    00:02.0 VGA compatible controller [0300]: Intel Corporation RocketLake-S GT1 [UHD Graphics 730] [8086:4c8b] (rev 04)
    00:17.0 SATA controller [0106]: Intel Corporation Device [8086:43d2] (rev 11)
    apt policy intel-opencl-icd
    intel-opencl-icd:
      Installed: 24.22.29735.21-1
      Candidate: 24.22.29735.21-1
      Version table:
    *** 24.22.29735.21-1 500
            500 http://deb.debian.org/debian sid/main amd64 Packages
            100 /var/lib/dpkg/status
    sudo /usr/lib/jellyfin-ffmpeg/vainfo --display drm --device /dev/dri/renderD128
    Trying display: drm
    vainfo: VA-API version: 1.22 (libva 2.22.0)
    vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 24.2.5 (12561f6)
          VAProfileMPEG2Simple            : VAEntrypointEncSlice
          VAProfileMPEG2Main              : VAEntrypointEncSlice
          VAProfileH264Main              : VAEntrypointFEI
          VAProfileH264High              : VAEntrypointFEI
          VAProfileH264ConstrainedBaseline: VAEntrypointFEI
          VAProfileHEVCMain              : VAEntrypointEncSlice
          VAProfileHEVCMain              : VAEntrypointFEI
          VAProfileHEVCMain              : VAEntrypointEncSliceLP
          VAProfileHEVCMain10            : VAEntrypointEncSlice
          VAProfileHEVCMain10            : VAEntrypointEncSliceLP
          VAProfileVP9Profile0            : VAEntrypointEncSliceLP
          VAProfileVP9Profile1            : VAEntrypointVLD
          VAProfileVP9Profile1            : VAEntrypointEncSliceLP
          VAProfileVP9Profile2            : VAEntrypointEncSliceLP
          VAProfileVP9Profile3            : VAEntrypointVLD
          VAProfileVP9Profile3            : VAEntrypointEncSliceLP
          VAProfileHEVCMain12            : VAEntrypointVLD
          VAProfileHEVCMain12            : VAEntrypointEncSlice
          VAProfileHEVCMain422_10        : VAEntrypointVLD
          VAProfileHEVCMain422_10        : VAEntrypointEncSlice
          VAProfileHEVCMain422_12        : VAEntrypointVLD
          VAProfileHEVCMain422_12        : VAEntrypointEncSlice
          VAProfileHEVCMain444            : VAEntrypointVLD
          VAProfileHEVCMain444            : VAEntrypointEncSliceLP
          VAProfileHEVCMain444_10        : VAEntrypointVLD
          VAProfileHEVCMain444_10        : VAEntrypointEncSliceLP
          VAProfileHEVCMain444_12        : VAEntrypointVLD
          VAProfileHEVCSccMain            : VAEntrypointVLD
          VAProfileHEVCSccMain            : VAEntrypointEncSliceLP
          VAProfileHEVCSccMain10          : VAEntrypointVLD
          VAProfileHEVCSccMain10          : VAEntrypointEncSliceLP
          VAProfileHEVCSccMain444        : VAEntrypointVLD
          VAProfileHEVCSccMain444        : VAEntrypointEncSliceLP
          VAProfileAV1Profile0            : VAEntrypointVLD
          VAProfileHEVCSccMain444_10      : VAEntrypointVLD
          VAProfileHEVCSccMain444_10      : VAEntrypointEncSliceLP
    sudo /usr/lib/jellyfin-ffmpeg/ffmpeg -v verbose -init_hw_device vaapi=vaConfused-facedev/dri/renderD128 -init_hw_device opencl@va
      configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-opencl --enable-libdrm --enable-libxml2 --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libsvtav1 --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=amd64 --enable-libshaderc --enable-libplacebo --enable-vulkan --enable-vaapi --enable-amf --enable-libvpl --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc
    [AVHWDeviceContext @ 0x55ec69b83e80] libva: VA-API version 1.22.0
    [AVHWDeviceContext @ 0x55ec69b83e80] libva: Trying to open /usr/lib/jellyfin-ffmpeg/lib/dri/iHD_drv_video.so
    [AVHWDeviceContext @ 0x55ec69b83e80] libva: Found init function __vaDriverInit_1_22
    [AVHWDeviceContext @ 0x55ec69b83e80] libva: va_openDriver() returns 0
    [AVHWDeviceContext @ 0x55ec69b83e80] Initialised VAAPI connection: version 1.22
    [AVHWDeviceContext @ 0x55ec69b83e80] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 24.2.5 (12561f6).
    [AVHWDeviceContext @ 0x55ec69b83e80] Driver not found in known nonstandard list, using standard behaviour.
    [AVHWDeviceContext @ 0x55ec69b84340] 0.0: Intel(R) OpenCL Graphics / Intel(R) UHD Graphics 730
    [AVHWDeviceContext @ 0x55ec69b84340] Intel QSV to OpenCL mapping function found (clCreateFromVA_APIMediaSurfaceINTEL).
    [AVHWDeviceContext @ 0x55ec69b84340] Intel QSV in OpenCL acquire function found (clEnqueueAcquireVA_APIMediaSurfacesINTEL).
    [AVHWDeviceContext @ 0x55ec69b84340] Intel QSV in OpenCL release function found (clEnqueueReleaseVA_APIMediaSurfacesINTEL).
    sudo dmesg | grep i915
    [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.10.3-amd64 root=UUID=b32fc92a-481f-4336-ac9e-a6503cc3894c ro quiet splash i915.enable_guc=3
    [    0.029412] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.10.3-amd64 root=UUID=b32fc92a-481f-4336-ac9e-a6503cc3894c ro quiet splash i915.enable_guc=3
    [    3.031287] i915 0000:00:02.0: [drm] VT-d active for gfx access
    [    3.031290] i915 0000:00:02.0: vgaarb: deactivate vga console
    [    3.031328] i915 0000:00:02.0: [drm] Using Transparent Hugepages
    [    3.031755] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
    [    3.035125] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/rkl_dmc_ver2_03.bin (v2.3)
    [    3.288864] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/tgl_guc_70.1.1.bin version 70.1.1
    [    3.288868] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc_7.9.3.bin version 7.9.3
    [    3.292557] i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
    [    3.292876] i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
    [    3.292877] i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
    [    3.293142] i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
    [    3.293470] mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
    [    3.293578] i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
    [    3.293582] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
    [    3.297746] [drm] Initialized i915 1.6.0 20230929 for 0000:00:02.0 on minor 0
    [    3.328611] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
    [    3.360673] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
    [    3.392605] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
    [    3.424602] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
    sudo cat /sys/kernel/debug/dri/0/gt0/uc/guc_info
    GuC firmware: i915/tgl_guc_70.1.1.bin
            status: RUNNING
            version: found 70.1.1
            uCode: 277056 bytes
            RSA: 256 bytes
    GuC status 0x8003f0ec:
            Bootrom status = 0x76
            uKernel status = 0xf0
            MIA Core status = 0x3
    Scratch registers:
            0:    0x0
            1:    0x1633d7
            2:    0x44000
            3:    0x4
            4:    0x40
            5:    0x4ec
            6:    0x4c8b0004
            7:    0x0
            8:    0x0
            9:    0x0
            10:    0x0
            11:    0x0
            12:    0x0
            13:    0x0
            14:    0x0
            15:    0x0
    GuC logging stats:
            Relay full count: 0
            DEBUG:  flush count          0, overflow count          0
            CRASH:  flush count          0, overflow count          0
            CAPTURE:        flush count          0, overflow count          0
    CT enabled
    H2G Space: 4092
    Head: 0
    Tail: 0
    G2H Space: 12284
    Head: 0
    Tail: 0
    GuC Submission API Version: 1.0.0
    GuC Number Outstanding Submission G2H: 0
    GuC tasklet count: 0
    Requests in GuC submit tasklet:
    Global scheduling policies:
      DPC promote time  = 500000
      Max num work items = 15
      Flags              = 0
    sudo cat /sys/kernel/debug/dri/0/gt0/uc/huc_info
    HuC firmware: i915/tgl_huc_7.9.3.bin
            status: RUNNING
            version: found 7.9.3
            uCode: 589504 bytes
            RSA: 256 bytes
    HuC status: 0x00090001
    groups jellyfin
    jellyfin : jellyfin video input render
    These are all the loaded plugins:
    [2024-08-08 18:41:43.592 +02:00] [INF] Loaded plugin: "Bookshelf" "11.0.0.0"
    [2024-08-08 18:41:43.593 +02:00] [INF] Loaded plugin: "Playback Reporting" "15.0.0.0"
    [2024-08-08 18:41:43.594 +02:00] [INF] Loaded plugin: "Reports" "17.0.0.0"
    [2024-08-08 18:41:43.594 +02:00] [INF] Loaded plugin: "Session Cleaner" "4.0.0.0"
    [2024-08-08 18:41:43.595 +02:00] [INF] Loaded plugin: "TheTVDB" "15.0.0.0"
    [2024-08-08 18:41:43.596 +02:00] [INF] Loaded plugin: "TMDb Box Sets" "11.0.0.0"
    [2024-08-08 18:41:43.596 +02:00] [INF] Loaded plugin: "Transcode Killer" "3.0.0.0"
    [2024-08-08 18:41:43.597 +02:00] [INF] Loaded plugin: "Webhook" "15.0.0.0"
    [2024-08-08 18:41:43.597 +02:00] [INF] Loaded plugin: "TMDb" "10.9.9.0"
    [2024-08-08 18:41:43.597 +02:00] [INF] Loaded plugin: "Studio Images" "10.9.9.0"
    [2024-08-08 18:41:43.597 +02:00] [INF] Loaded plugin: "OMDb" "10.9.9.0"
    [2024-08-08 18:41:43.610 +02:00] [INF] Loaded plugin: "MusicBrainz" "10.9.9.0"
    [2024-08-08 18:41:43.610 +02:00] [INF] Loaded plugin: "AudioDB" "10.9.9.0"
    The movie plays fine in direct play on the Windows Jellyfin Media Player and my LG TV, so there's nothing wrong with the file.
    1080p HDR and SDR HEVC transcodes, it's only 4K HDR HEVC that's not working.
    .txt   jellyfin20240808.txt (Size: 8.62 KB / Downloads: 31)
    .txt   FFmpeg.Transcode-2024-08-08_18-55-18.txt (Size: 23.57 KB / Downloads: 52)
    2024-08-08, 06:05 PM
    On both Firefox and your Android phone (when using the web player), do they work when you set a max transcode resolution? I'm assuming neither of them are on 4K displays. I know that some users had issues with the Android web player when the transcoded video was 4K. But Firefox shouldn't have a problem with that.
    Either way. Try setting Settings > Playback (not the one in the dashboard) > Maximum Allowed Video Transcoding Resolution to 1080P.
    bioblatt
    2024-08-08, 06:11 PM (This post was last modified: 2024-08-08, 06:14 PM by bioblatt. Edited 1 time in total.)
    Still the same outcome for Firefox and Android using the web player.
    I tried Auto, 1080P and Screen Resolution with "Limit maximum supported video resolution" disabled/enabled.
    2024-08-08, 06:20 PM
    Just noticed this.
    bioblatt
    2024-08-08, 06:41 PM (This post was last modified: 2024-08-08, 06:46 PM by bioblatt. Edited 3 times in total.)
    Uninstalled the plugin. 4K HEVC transcodes.
    I feel soooo stupid now...
    Sorry for all the efforts of the past days/weeks. I thought the plugin does something completely different.
    Thank you so much for all the help!
    This makes now completely sense why it sometimes showed a split second of transcoded video.
