    Jellyfin Forum Support Troubleshooting SOLVED: Local Connection Issue
    Pages (3): « Previous 1 2 3
    Cannot connect devices on LAN to host server
    sammyg2005
    2024-07-24, 11:08 PM
    Okay so an update. I can connect to the server. My route tables were jacked up. Wiped them out and setup them up again. All devices connect. Of course now qbt doesnt want to connect through gluetun, but that is another issue. I appreciate all of your help.
    I did notice this line in the log is still empty even when connecting.
    [2024-07-24 14:40:01.464 -04:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Filtered interface addresses: []
    axute
    2024-11-14, 10:45 PM
    Same issue here, no access from LAN:
    [23:37:09] [INF] [26] Jellyfin.Networking.Manager.NetworkManager: Defined LAN subnets: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    [23:37:09] [INF] [26] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions: []
    [23:37:09] [INF] [26] Jellyfin.Networking.Manager.NetworkManager: Used LAN subnets: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    [23:37:09] [INF] [26] Jellyfin.Networking.Manager.NetworkManager: Filtered interface addresses: []
    [23:37:09] [INF] [26] Jellyfin.Networking.Manager.NetworkManager: Bind Addresses ["::"]
    [23:37:09] [INF] [26] Jellyfin.Networking.Manager.NetworkManager: Remote IP filter is Allowlist
    [23:37:09] [INF] [26] Jellyfin.Networking.Manager.NetworkManager: Filtered subnets: ["100.100.205.235/32"]
    bind address is 0.0.0.0
    I could only access over the Remote IP-Address (public ip > traefik), but this is not the way to see movies localy!
    Unraid UI:
    172.18.0.18:8096/TCP <=> 192.168.2.62:8096    <<< not working
    172.18.0.18:8020/TCP <=> 192.168.2.62:8920    <<< not working
    2024-11-14, 11:17 PM
    I'd need to see your docker compose. I'm assuming you are using bridge networking. Are you using "ports" or "expose" for port 8096?
    axute
    2024-11-15, 09:05 AM
    docker run
      -d
      --name='Jellyfin'
      --net='axute.local'
      --cpuset-cpus='3,5,7,11,13,15'
      --pids-limit 2048
      -e TZ="Europe/Berlin"
      -e HOST_OS="Unraid"
      -e HOST_HOSTNAME="Tower"
      -e HOST_CONTAINERNAME="Jellyfin"
      -e 'PUID'='99'
      -e 'PGID'='100'
      -l net.unraid.docker.managed=dockerman
      -l net.unraid.docker.webui='http://[IP]:[PORT:8096]/'
      -l net.unraid.docker.icon='https://raw.githubusercontent.com/SmartPhoneLover/unraid-docker-templates/main/templates/icons/jellyfin_200x200.png'
      -l 'traefik.enable'='true'
      -l 'traefik.http.routers.jellyfin.entrypoints'='https'
      -l 'traefik.http.routers.jellyfin.rule'='Host(`*******************`)'
      -l 'traefik.http.services.jellyfin.loadbalancer.server.port'='8096'
      -p '8096:8096/tcp'
      -p '8920:8020/tcp'
      -v '/mnt/user/Videos/':'/mnt/user/Videos':'rw'
      -v '/mnt/user/Musik/':'/mnt/user/Musik':'rw'
      -v '/mnt/user/cacheonly/jellyfin':'/cache':'rw'
      -v '/mnt/user/appdata/jellyfin':'/config':'rw'
      --device /dev/dri
      --group-add video
      --hostname Jellyfin
      --memory="2g" 'jellyfin/jellyfin'
    docker inspect Jellyfin
    "Networks": {
                    "axute.local": {
                        "IPAMConfig": null,
                        "Links": null,
                        "Aliases": [
                            "b501907c26ed",
                            "Jellyfin"
                        "NetworkID": "cbff1fd0fd0ef7dd17df94e3a405d7b007275b474cecfd9f8d45701c209b160f",
                        "EndpointID": "68b3135db92a4c4b389d62a1ad2d793071b97486f6d3bb6ad80fbc6f7ecb461d",
                        "Gateway": "172.18.0.1",
                        "IPAddress": "172.18.0.32",
                        "IPPrefixLen": 16,
                        "IPv6Gateway": "",
                        "GlobalIPv6Address": "",
                        "GlobalIPv6PrefixLen": 0,
                        "MacAddress": "02:42:ac:12:00:20",
                        "DriverOpts": null
    2024-11-15, 02:42 PM (This post was last modified: 2024-11-15, 02:43 PM by TheDreadPirate. Edited 1 time in total.)
    Can you remove the filtered subnet? You may need to manually remove it from /config/config/network.xml.
