    Jellyfin Forum Support Troubleshooting SOLVED: Playlist disappear right after library scan
    Rubén Navarro López
    Threads: 20
    2024-09-26, 09:02 PM
    okay so, I just need to change that and then reproduce the issue, right?
    After that, I should leave logging.default.json like it was?
    2024-09-26, 09:16 PM
    I wouldn't leave it on debug logging. It produces A LOT of log entries.
    Rubén Navarro López
    Threads: 20
    2024-09-27, 11:16 PM (This post was last modified: 2024-09-27, 11:18 PM by Rubén Navarro López. Edited 1 time in total.)
    Hi! I could get something related to my playlist.
    It was named "Recomendadas para halloween" or "Recomendadas halloween"... I know it's large, so I decided to upload it on pixeldrain, because pastebin wouldn't fit.
    Thanks in advance
    https://pixeldrain.com/u/WfG9kHqd
    In the file you can see this:
    [2024-09-27 18:10:17.193 +02:00] [INF] [25] Emby.Server.Implementations.Library.LibraryManager: Removing item, Type: "Folder", Name: "Decker", Path: "C:\Users\Plex\AppData\Local\Jellyfin\data\playlists\Decker", Id: f9bf8fff-e34a-e70e-2368-b249e3b91875
    [2024-09-27 18:10:17.200 +02:00] [INF] [25] Emby.Server.Implementations.Library.LibraryManager: Removing item, Type: "Folder", Name: "Recomendadas Halloween", Path: "C:\Users\Plex\AppData\Local\Jellyfin\data\playlists\Recomendadas Halloween", Id: 66a2d1e7-963b-6cda-124c-8a6881c62fd6
    [2024-09-27 18:10:17.207 +02:00] [INF] [25] Emby.Server.Implementations.Library.LibraryManager: Removing item, Type: "Playlist", Name: "Recomendadas para Halloween", Path: "C:\Users\Plex\AppData\Local\Jellyfin\data\playlists\Recomendadas para Halloween", Id: 84fde3e9-d1de-337a-57f9-c0d729a48095
    Don't know why it says "Removing item"...
    2024-09-28, 01:01 AM
    Do you have other apps accessing and or modifying the file? I'm not sure why files on your C drive would become inaccessible unless another app was modifying the file.
    Rubén Navarro López
    Threads: 20
    2024-09-28, 09:52 PM
    as far as I know, I have no apps, only teamviewer to access to the machine in the distance...
    Rubén Navarro López
    Threads: 20
    2024-09-29, 08:45 PM
    Any other thoughts?
    Are you able to create a "playlist" and don't remove it after a single scan?
    2024-09-29, 09:42 PM
    I've never had a playlist disappear. Both playlists created in Jellyfin and m3u playlists in my library folders.
    Rubén Navarro López
    Threads: 20
    2024-09-29, 11:57 PM (This post was last modified: 2024-10-01, 04:48 PM by Rubén Navarro López. Edited 5 times in total.)
    Probably we are not talking to the same thing?
    I'm not saying librarys, i'm saying playlist with the next steps: right click to a movie, add to playlist, create a new playlist... etc...
    I'm not native english, but I just needed to clarify that.
    EDIT: I marked it as solution, sry for that
    Rubén Navarro López
    Threads: 20
    2024-09-30, 12:09 AM (This post was last modified: 2024-09-30, 12:36 AM by Rubén Navarro López. Edited 4 times in total.)
    I tried to reinstall, but no luck on that...
    I could get new logs about this (now I understand how to get them everytime) and I can't see any reason for why Emby.Server.Implementations is deleting it (in this case is test and adDASF):
    02:28:53.803 +02:00] [INF] [25] Jellyfin.Plugin.PlaybackReporting.Data.PlaybackTracker: PlaybackTracker : Adding Stop Event : 09/30/2024 02:28:53
    [2024-09-30 02:28:53.805 +02:00] [INF] [25] Jellyfin.Plugin.PlaybackReporting.EventMonitorEntryPoint: Saving playback tracking activity in DB
    [2024-09-30 02:28:54.298 +02:00] [INF] [30] Jellyfin.Plugin.KodiSyncQueue.EntryPoints.UserSyncNotification: Started user data sync
    [2024-09-30 02:28:55.454 +02:00] [INF] [30] Jellyfin.Plugin.KodiSyncQueue.EntryPoints.UserSyncNotification: User Data Sync: User "Jolaru21" ("40d32112038b4e16b9a8c68b3a1a280a") posted 2 updates
    [2024-09-30 02:28:55.456 +02:00] [INF] [30] Jellyfin.Plugin.KodiSyncQueue.EntryPoints.UserSyncNotification: Finished user data sync, taking "00:00:01.1554489"
    [2024-09-30 02:29:23.232 +02:00] [INF] [30] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "192.168.1.18" request
    [2024-09-30 02:29:41.574 +02:00] [INF] [33] Jellyfin.Drawing.ImageProcessor: Creating image collage and saving to "C:\Users\Plex\AppData\Local\Jellyfin\cache\temp\bde7fbf16def47b3b30c1757bed8ccdb.png"
    [2024-09-30 02:29:41.892 +02:00] [INF] [33] Jellyfin.Drawing.ImageProcessor: Completed creation of image collage and saved to "C:\Users\Plex\AppData\Local\Jellyfin\cache\temp\bde7fbf16def47b3b30c1757bed8ccdb.png"
    [2024-09-30 02:29:56.049 +02:00] [INF] [27] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "192.168.1.18" closed
    [2024-09-30 02:29:56.363 +02:00] [INF] [6] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "79.116.39.18" request
    [2024-09-30 02:29:58.552 +02:00] [INF] [27] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "79.116.39.18" closed
    [2024-09-30 02:29:58.795 +02:00] [INF] [6] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "79.116.39.18" request
    [2024-09-30 02:30:01.573 +02:00] [INF] [27] Emby.Server.Implementations.IO.LibraryMonitor: Stopping directory watching for path "C:\Users\Plex\AppData\Local\Jellyfin\data\collections"
    [2024-09-30 02:30:01.577 +02:00] [INF] [27] Emby.Server.Implementations.IO.LibraryMonitor: Stopping directory watching for path "E:\Series"
    [2024-09-30 02:30:01.579 +02:00] [INF] [27] Emby.Server.Implementations.IO.LibraryMonitor: Stopping directory watching for path "F:\Pelis\Peliculas intocables"
    [2024-09-30 02:30:01.581 +02:00] [INF] [27] Emby.Server.Implementations.IO.LibraryMonitor: Stopping directory watching for path "E:\Anime\Peliculas"
    [2024-09-30 02:30:01.583 +02:00] [INF] [27] Emby.Server.Implementations.IO.LibraryMonitor: Stopping directory watching for path "E:\Anime\Series"
    [2024-09-30 02:30:01.585 +02:00] [INF] [27] Emby.Server.Implementations.IO.LibraryMonitor: Stopping directory watching for path "F:\Docuseries"
    [2024-09-30 02:30:01.586 +02:00] [INF] [27] Emby.Server.Implementations.IO.LibraryMonitor: Stopping directory watching for path "F:\Series y Peliculas Animadas"
    [2024-09-30 02:30:01.588 +02:00] [INF] [27] Emby.Server.Implementations.IO.LibraryMonitor: Stopping directory watching for path "F:\Docupelis"
    [2024-09-30 02:30:01.590 +02:00] [INF] [27] Emby.Server.Implementations.IO.LibraryMonitor: Stopping directory watching for path "F:\Pelis\Cine Clásico"
    [2024-09-30 02:30:01.591 +02:00] [INF] [27] Emby.Server.Implementations.IO.LibraryMonitor: Stopping directory watching for path "F:\Pelis\Conciertos"
    [2024-09-30 02:30:01.594 +02:00] [INF] [27] Emby.Server.Implementations.Library.LibraryManager: Validating media library
    [2024-09-30 02:30:03.977 +02:00] [INF] [21] Emby.Server.Implementations.Library.LibraryManager: Removing item, Type: "Folder", Name: "test", Path: "C:\Users\Plex\AppData\Local\Jellyfin\data\playlists\test", Id: 1b4cc9f8-9b47-e2f8-89c0-1dc068ac88e6
    [2024-09-30 02:30:03.993 +02:00] [INF] [21] Emby.Server.Implementations.Library.LibraryManager: Removing item, Type: "Playlist", Name: "adDASF", Path: "C:\Users\Plex\AppData\Local\Jellyfin\data\playlists\adDASF", Id: 2e144f17-51a4-7ce0-b7e3-0ed38b993cef
    EDIT: I found that I'm not the only one:
    https://github.com/jellyfin/jellyfin/issues/12008
    2024-09-30, 02:16 PM
    Ah. Ok. I definitely misunderstood. This has to be a playlist permission issue.
    I haven't been able to reproduce. I either have permissions from the start or not (for imported playlists). I've never had it give me permission then take it away later.
