    Jellyfin Forum Support Troubleshooting SOLVED: Problems during intel arc gpu settup
    Intel Arc gpu: Failed to set value 'opencl@va' for option 'init_hw_device': No such device
    thatscringebro
    2024-12-04, 04:59 PM
    (2024-12-04, 04:40 PM)TheDreadPirate Wrote: Whoops.  Didn't scroll down the output of your last command.
    I just remembered a similar post last week.
    https://forum.jellyfin.org/t-solved-a310...8#pid44348
    Something about BPO kernels not including some firmware needed by Arc.
    https://jellyfin.org/docs/general/admini...e-on-linux
    You will need to download and install the GuC and HuC firmware manually.  Or switch to Ubuntu 24.04, which includes a new enough kernel + the needed firmware already installed.
    Thank you so much! I have manually install the GuC and HuC firmware according to the jellyfin docs and now everything works as intended!
