    Jellyfin Forum Support Troubleshooting SOLVED: RK3588 Hardware Acceleration
    Orange Pi 5 Max Transcoding wont work
    wiguelito
    Country:Puerto Rico
    #11
    2024-09-01, 07:35 AM
    And how would I be able to verify if the av1dnode is enabled or not?
    wiguelito
    Country:Puerto Rico
    #12
    2024-09-01, 08:12 AM
    just tried using an old image to test, no diffrence. the old version i used for testing is 10.9.7
    nyanmisaka
    #13
    2024-09-01, 10:32 AM
    I meant the linux image is used by RK3588. Armbian, ubuntu-rockchip or something else?
    wiguelito
    Country:Puerto Rico
    #14
    2024-09-01, 05:06 PM (This post was last modified: 2024-09-01, 05:06 PM by wiguelito.)
    O, I'm using debian from the social manufacturers with omv on it.
    I meant soc
    nyanmisaka
    #15
    2024-09-01, 05:12 PM
    If only AV1 videos cannot be transcoded, please contact the manufacturer to have them update their device tree configuration like this. https://github.com/armbian/linux-rockchi...705d80ce27
    wiguelito
    Country:Puerto Rico
    #16
    2024-09-01, 05:14 PM
    last time i wrote to them and they didnt answer, but anyway i'll try again
    wiguelito
    Country:Puerto Rico
    #17
    2024-09-01, 05:26 PM
    i wrote in the forum of orange pi, lets see what they say, cause armbian is not thinking right now of making a img for the orange pi 5 max.
    wiguelito
    Country:Puerto Rico
    #18
    2024-09-01, 05:44 PM
    Thing is that with the test i performed, it was possible to convert the same exact movie that could not be transcoded into h264 with the ffmpeg directly, so i really dont get it.
    nyanmisaka
    #19
    2024-09-01, 06:18 PM
    I found orangepi's kernel source repo. They are indeed missing the av1d node.
    https://github.com/orangepi-xunlong/linu...x.dts#L432
    wiguelito
    Country:Puerto Rico
    #20
    2024-09-01, 11:54 PM
    Currently working to edit that. I'm no pro but haven't received any info from orange pi so decided to give it a shot. If I get to fix it I'll let you know, but it appears that orangepi has a big issue with this since my kernel has crashed for a third time by just doing apt upgrade.
